IClone7 Unreal Export - Root Bone Name
Posted By spaehling 7 Years Ago
spaehling
spaehling
Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)
Posts: 16, Visits: 243
Hey guys,
last days i found the time to import my CC3 Character into Iclone, make some facial animations and import everything into UE4.
Now i see a Problem. When i export to Unreal (using Unreal in export options), i get 2 different bones names for the root in CC3 and Iclone7.
Check Screenshot below:
TestUnrealExport_Skeleton = Character from CC3
TestFacial_Skeleton = Character from Iclone7
bone hiearchy is similiar, expect of the root bone. We have "root" from CC3 and "cc_base_boneroot" from Iclone7.
I tried to fix this, by importing the Iclone7 char to  Maya, rename it and export it, but then i lose all my MorphTargets on import in UE4.
But i think this is another topic and i gonna start another thread.
greetz Phil
https://forum.reallusion.com/uploads/images/6eaafa36-7ccd-450c-8146-3931.png
spaehling
spaehling
Update:
i also had a different problem. i wasn't able to rename root bone in maya, cause i lost morph targets. now iam able to rename root bone in maya, without losing blendshapes.
https://forum.reallusion.com/394212/Import-Character-to-UE4-with-MorphTargets-With-and-without-Maya-in-between
I was searching for a solution with Reallusion Team for this problem here aswell and we figured out, that the problem only exists on my Main Computer. On Laptop, Iclone export works
as expected. As soon we have a fix for this too, i will let forum know.
unitl this, try the workaround with import to maya, rename bone. and if you want to keep morph targets on ue4 import, just follow the solution in the other topic.
AKATheBoss
AKATheBoss
Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)
Posts: 9, Visits: 61
Hello there.
I had this issue too and found a solution. Here it is:
I imported my character to 3DXChange and then export it to unreal from there and it works fine now.
Don't know if 3DXChange renamed the bones or something but it works.
Hope this helps you :)
Have a nice day.
spaehling
spaehling
hey man,
thanks for you answer. i do not have this problem anymore. and i do not remember how i fixed it. but i it was a complete resinstall of windows. so after reinstall everything it worked again.
but great that you answered!
