IBL BAKING
Posted By wildstar 5 Years Ago
3
IBL BAKING
wildstar
wildstar
Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)
Posts: 1.2K, Visits: 5.1K
someone already posted on feedback tracker ibl backing is generating black images ????
Last Active: 3 days ago
Posts: 15.8K, Visits: 31.3K
wildstar (2/8/2020)
That was a bug a couple of versions ago but was supposed to be fixed...:unsure:
I just tried it, and it works for me.
wildstar
wildstar
i trying but i just getting black images , maybe i doing something wrong ???
Last Active: 6 days ago
Posts: 5.3K, Visits: 16.6K
I do not think it works. Most environment diffuse colors are OFF and more on a gray side with IBL baked at 2048x1024.
Worse yet, if you try to bake 4096x2048 iClone would crash.
But that is not all! After the crash you are in a terrible mess originally described in: https://forum.reallusion.com/431430/All-my-new-scenes-are-dark-no-texture-show-up-?PageIndex=1
The texture would not render correctly for any project you open after the crash.
As I did more digging at some point after the fix was introduced in IC7.71, I figured, with IBL baking only 2 maps are involved - diffuse and specular (though as I said, diffuse is not rendered correctly for most props in the scene in an IBL baked image).
For some reason RL force it on the fly into the registry. So when crash occurs during IBL bake, those values are retained in registry and do NOT reset while iClone loaded fresh after the crash.
Any projects opened after the crash would look like this:
76% of original size (was 661x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/fa7070ad-eaae-4c9d-b92b-9624.jpg
STILL does not look right to be with only diffuse and specular (but I leave it for RL to fix)
Temporary fix (to restore correct render) is to modify registry and disable restrictive diffuse/specular.
This is how 2 registry values look like after the crash during IBL bake:
76% of original size (was 661x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/a7905b4c-fb57-4952-93bf-3bfc.jpg
BOTH values have to be set to 0 (PLEASE EXERCISE CAUTION WHILE EDITING REGISTRY!)
76% of original size (was 661x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/4a96ac31-acc7-4c3c-9725-d3c3.jpg
And obviously after the fix all opened projects look normal:
76% of original size (was 661x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/c0a3e533-2863-4dd3-ba7f-3b99.jpg
I never had time to enter this into FT, but I will at some point...  :)
wildstar
wildstar
thx for your reply 4u2ges.
the problem i getting is when i try generate a ibl from my scene i got black images . if i do the things you show about edit registry
i will correct that ??? i believe this is comming wrong since 7.7. cause i never got problems with anterior versions to bake ibl.
wildstar
wildstar
i chekc my reg, and both values are on zero, i believe this is not the problem. :(
Am7add9
Am7add9
Posts: 468, Visits: 9.3K
do you place a dummy object in the correct area you want the cam and have it selected?
You have to pick a right center point (an object in the scene or a dummy) (around which the 360 would evolve).
Here is an IBL baked from the default Loft Scene (2048x1024). Center point is one of the pillows on a couch.
76% of original size (was 661x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/c0888c22-aabf-4079-a229-13fc.jpg
But I am not sure if it rendered correctly. Most diffuse maps with a few exceptions did not come out right!
Plus, I cannot render 4096x2048. If I do, it would crash iClone and then I need to fix it with registry.
So the registry hack I showed, is to fix iClone after the crash. Otherwise non of the projects would render correctly.
wildstar
wildstar
you got same results i got , dark images.
wildstar
wildstar
Am7add9 (2/8/2020)
yep
3
