Program Crashes
Posted By EvilGenius 12 Years Ago
Posted 12 Years Ago
Posts: 23.1K, Visits: 36.6K
EvilGenius (4/9/2013)
Unfortunately, that did not fix my issue.
Have you contacted our Support department regarding this problem?
If you supply your dxdiag.txt file we will be able to check your system for any obvious causes of the problem. Please use the Support Form below.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Thanks.
EvilGenius
EvilGenius
Posted 12 Years Ago
Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)
Posts: 255, Visits: 1.1K
EvilGenius
EvilGenius
Posted 12 Years Ago
jlittle (4/9/2013)
On a Win 7 machine the path is as follows:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Reallusion\CrazyTalk Animator\1.0
Jeff
Thanks Jeff, seems like that was it.
jlittle
jlittle
Posted 12 Years Ago
Posts: 1.9K, Visits: 17.3K
Jeff
EvilGenius
EvilGenius
Posted 12 Years Ago
On more than on instance I have lost some of my work because the program has crashed.
I have gotten used to having to save on a regular basis but honestly, I shouldn't have to. After looking into how to fix this issue once and for all I came across a forum posting in 2010 addressing the same issue. Here is a screenshot of that post
I attempted to perform this "fix" but my REALLUSION folder was not found in my registry in the area it was supposed to be in. The only suggestion as to why would be that maybe this method was not for a Windows 7 machine.
Can someone point me in the right direction? I did a registry search and found some of the reg files for the program but I do not want to alter the wrong file.
