Rokoko Motion Library data totally broken
Posted By aaron_vfx 3 Years Ago
aaron_vfx
aaron_vfx
Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)
Posts: 39, Visits: 114
Has anyone been able to bring in Rokoko Motion Library FBX files and have them work?
Everytime I bring them in a get a ton of errors, and nearly every options just breaks! When I did finally get it to work (by importing the FBX using one of the Mixamo profiles), then I cannot use this on ANY other character other than the motion dummy, because it just skins very strangely and everything just looks broken! mainly to do with the spine, and neck, things just look totally distorted!
If I try to import this into Unreal and retarget to another rig it breaks all over again!! But everything is fine with other animations, is Iclone just not very good at retargeting some animations?
I have opened a support ticket, I can only assume that Reallusion will say its the asset I imported that's the problem, and Rokoko will say its Iclone that's the problem.
Any helps would be great thanks!
Aaron
https://dev.epicgames.com/community/profile/Kp0v/AaronVFX
Threaded View
Threaded View
Forum Post Rokoko Motion Library data totally broken By aaron_vfx ( 3 Years Ago )
