Softcloth pass through
Posted By isaac3d 10 Years Ago
isaac3d
isaac3d
Posted 10 Years Ago
Veteran Member (616 reputation)Veteran Member (616 reputation)Veteran Member (616 reputation)Veteran Member (616 reputation)Veteran Member (616 reputation)Veteran Member (616 reputation)Veteran Member (616 reputation)Veteran Member (616 reputation)Veteran Member (616 reputation)
Last Active: 10 Years Ago
Posts: 7, Visits: 24
I'm sorry if you get this kind of question regularly, but I have been having a lot of problems with this. I have watched several videos on this topic (several times) and for the presenter its always click click click and perfect results! Unfortunately I don't know if my problems are lack of skill and experience or if there is a setting somewhere which needs to be switched on or off and I have yet to find it.
In the attached picture you can see genesis 2 female with a dress from DAZ3d. I have highlighted what I think are the important check boxes in red. I have also indicated that I have selected the general cloth properties. I have applied a weight map that I made myself in photoshop. As you can see, the lower part of the dress (where the weight map is white) passes through the figures legs.
It was my understanding that the weight map affected the physical properties of the softcloth (elasticity, mass etc) not the collision properties. Is that correct?
If I dial the brightness of the weight map down until it is very dark grey then the pass though is less. That seems to suggest that the weight map is affecting the collision. If that is so, how is it possible to get a very soft cloth that does pass through the figures body? I know that it is possible to add Collision Shapes to a figure. Is that the answer? I surely hope not. I hope that the mesh of the figure itself can be used as the rigid body.
Any advice would be welcome.
.75% of original size (was 670x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/94a1c534-1a47-4f6a-85a7-0c10.png
Threaded View
Threaded View
Forum Post Softcloth pass through By isaac3d ( 10 Years Ago )
Forum Post I think you already have figured it out. The avatar mesh could be used... By prabhatM ( 10 Years Ago )
Forum Post Ok, prabbhat, i do enjoy watching you offer support. but you don't... By planetstardragon ( 10 Years Ago )
Forum Post So guys, was that a yes or a no? Is the figure mesh itself the rigid... By isaac3d ( 10 Years Ago )
Forum Post I don't know if you've seen this tutorial, also, it should be noted... By planetstardragon ( 10 Years Ago )
Forum Post [quote][b]planetstardragon (6/1/2015)[/b][hr]Ok, prabbhat, i do... By prabhatM ( 10 Years Ago )
Forum Post Hi I did not sit and watch the 17 minute video but this is something... By duchess110 ( 10 Years Ago )
Forum Post Thanks for the replies. I have studied the video DAZ to iClone 6... By isaac3d ( 10 Years Ago )
Forum Post [quote][b]isaac3d (6/3/2015)[/b][hr]Thanks for the replies. I have... By prabhatM ( 10 Years Ago )
Forum Post [quote]prabhatM (6/3/2015)... As I understand, you have to select... By primaveranz ( 10 Years Ago )
Forum Post [quote][b]primaveranz (6/3/2015)[/b][hr][quote]prabhatM (6/3/2015)...... By prabhatM ( 10 Years Ago )
Forum Post Here is the manual page. Further links into more detail if you scroll... By Rampa ( 10 Years Ago )
Forum Post PrabhatM wrote "For some reason, I can not view your youtube link. It... By isaac3d ( 10 Years Ago )
Forum Post Hi Isaac3D, It is indeed the correct way! :) When you add a shape, it... By Rampa ( 10 Years Ago )
Forum Post as i had mentioned in my post earlier, the physics cloth settings are... By planetstardragon ( 10 Years Ago )
Forum Post It seems I was wrong, the character mesh is not used for preventing... By isaac3d ( 10 Years Ago )
Forum Post isaac3d . I was having the exact same problems as you and tried... By mrbrush ( 7 Years Ago )
