Preview Rendering takes forever
Posted By pka4916 7 Years Ago
3
pka4916
pka4916
Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)
Posts: 366, Visits: 1.4K
I tried that, and it's a little bit faster, but still takes forever.
If I look at Kai's video,  it takes seconde with a 1080 card.
I cannot get it that fast as in the video..
I almost want to ask for  project  or how someone else has all the setting for iclone and iray.
gordryd
gordryd
Last Active: 3 Months Ago
Posts: 730, Visits: 8.1K
The logs seem to show you are previewing in 'Photoreal' mode -- that will definitely take longer.  Try changing the mode to 'Interactive' and see if it improves.
pka4916
pka4916
ok made another test, just in case
Can you tell me if in the 1st part the GPU is not used again?
I made 3 sections
1= GPU+ CPU
2 = GPU
3= GPU + CPU  with Iclone Added to the control panel from Nvidia under Manage 3D settings.
I didn't see any improvement, but looks like the log is different.
GPU + CPU
  1.0   IRT    rend info : Initializing context.
  1.0   IRT    rend info : Creating irt render context (cache id: 0x0000000100000000).
  1.0   IRT    rend info : Shutting down irt render context.
  1.0   IRT    rend info : Resource assignment for host 0 has changed.
  1.0   IRAY   rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
  1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 5.54383 GiB available, display attached
  1.0   IRAY   rend info : iray photoreal CPU fallback is enabled.
GPU only
  1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 2.48881 GiB available, display attached
  1.14  IRAY   rend info : Received update to 00059 iterations after 65.311s.
  1.14  IRAY   rend info : Rendering with 1 device(s):
  1.14  IRAY   rend info :    CUDA device 0 (GeForce GTX 1070)
  1.14  IRAY   rend info : Rendering...
  1.16  IRAY   rend info : JIT-linking wavefront kernel in 0.064s
  1.16  IRAY   rend info : JIT-linking mega kernel in 0.035s
  1.17  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 0.101s
  1.22  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 12.8458 MiB for frame buffer
  1.17  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.000s)
  1.17  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
  1.14  IRAY   rend info : Received update to 00060 iterations after 69.493s.
  1.14  IRAY   rend info : Received update to 00062 iterations after 71.284s.
  1.14  IRAY   rend info : Received update to 00066 iterations after 74.658s.
  1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 2.48619 GiB available, display attached
  1.14  IRAY   rend info : Received update to 00074 iterations after 81.200s.
  1.14  IRAY   rend info : CPU: using 3 cores for rendering
  1.14  IRAY   rend info : Rendering with 2 device(s):
Here I added Iclone to the Nvideo Control Panel and checked always use GPU for this program
  1.14  IRAY   rend info : Allocating 1-layer frame buffer
  1.14  IRAY   rend info : Using interactive scheduling, architectural sampler unavailable, caustic sampler disabled
  1.14  IRAY   rend info : Initializing local rendering.
  1.8   IRAY   rend info : Using device 0 to build data for host
  1.8   IRAY   rend info : Importing lights for motion time 0
  1.8   IRAY   rend info : Initializing light hierarchy.
  1.8   IRAY   rend info : Light hierarchy initialization took 0.13s
  1.5   IRAY   rend info : CPU: Scene processed in 5.484s
  1.15  IRAY   rend info : CPU: Allocated 424.387 KiB for frame buffer
  1.2   IRAY   rend info : JIT-linking wavefront kernel in 1.354s
  1.2   IRAY   rend info : JIT-linking mega kernel in 0.032s
  1.6   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 6.940s
  1.15  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 12.4326 MiB for frame buffer
  1.6   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.056s)
  1.6   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
  1.14  IRAY   rend info : Received update to 00001 iterations after 8.034s.
  1.14  IRAY   rend info : Received update to 00002 iterations after 9.039s.
  1.14  IRAY   rend info : Received update to 00003 iterations after 10.044s.
  1.14  IRAY   rend info : Received update to 00004 iterations after 11.027s.
  1.14  IRAY   rend info : Received update to 00005 iterations after 12.024s.
  1.22  IRAY   rend info : CPU: Allocated 3.08456 MiB for frame buffer
  1.18  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 9.76251 MiB for frame buffer
  1.14  IRAY   rend info : Received update to 00006 iterations after 12.982s.
  1.14  IRAY   rend info : Received update to 00007 iterations after 14.241s.
  1.14  IRAY   rend info : Received update to 00008 iterations after 15.485s.
  1.14  IRAY   rend info : Received update to 00009 iterations after 16.764s.
  1.14  IRAY   rend info : Received update to 00010 iterations after 17.970s.
  1.14  IRAY   rend info : Received update to 00011 iterations after 19.233s.
  1.14  IRAY   rend info : Received update to 00012 iterations after 20.483s.
  1.14  IRAY   rend info : Received update to 00013 iterations after 21.739s.
  1.4   IRAY   rend info : CPU: Allocated 2.53677 MiB for frame buffer
  1.5   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 10.3103 MiB for frame buffer
  1.14  IRAY   rend info : Received update to 00014 iterations after 22.978s.
  1.14  IRAY   rend info : Received update to 00015 iterations after 23.984s.
  1.14  IRAY   rend info : Received update to 00017 iterations after 25.903s.
pka4916
pka4916
DroneMaster (2/8/2019)
pka4916 (2/8/2019)
Installed the 411.70 driver, and no difference..
The only other thing I can think of is your texture compression. Is it set to "none"? Me, I have it on medium. Also check how big the texture sizes you allow in your project settings. Other than that, I don't have a clue.
I tried Max / Medium  None.
Tried   2048 x 2048,   1024x1024,   512x512
It makes all no difference.
I just commented to another post (see above)   that might explain why it's not working for me.
pka4916
pka4916
justaviking (2/7/2019)
The key thing I'm seeing in the log you shared (thank you) is:
  1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 5.88661 GiB available, display attached
It seems to confirm my suspicion that you're rendering on your CPU.
Now the question is, "Why?"  I don't know, yet.
There is probably an Nvidia setting somewhere that can enable your GTX 1070 for Iray, or make it the default, or something like that.  I'm not sure where exactly that is.
I totally missed this post.
That is a good question,  I do see the GPU running up to 7.5 Gb.  but the logs tells me otherwise.
Maybe a staf Member can answer this one.
I checked the settings, and I don't see anything.
Are there other 1070 users out there?   I know Kai used a 1080..  Maybe he knows,  if he is watching this :)
DroneMaster
DroneMaster
Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)
Posts: 402, Visits: 11.6K
pka4916 (2/8/2019)
https://www.artstation.com/pascalcomics
https://www.renderosity.com/users/Pascal_Comics/gallery
https://www.deviantart.com/pascalcomics/gallery
pka4916
pka4916
I did notice that even if your done with a preview and close it,  it doesn't free up the GPU memory.
I start out with 4.5 Gb  and when doing is 2-3 times, it's at 7.5 Gb.
Even closing the preview doesn't release the memory. or whatever.
Played with all the settings, and the only one that makes somewhat a difference is when I change the preview screen size to 320x240 and zoom in.
The default 1000 x something,  is making is slow..   even 640x480 preview is slow.
How does the smartcache work?  do you need to enable something, since I don't see a difference.
Then I still have the fact, that once it's done, and I zoom in or move the camera, it's still take a long time before I can move again.. there is a huge deley between the movement
and the preview starts doing something.
pka4916
pka4916
DroneMaster (2/7/2019)
I've got the GTX 1080 t1 using the Nvidia 411.70 driver. It worked fast. I upgraded the driver to the latest 418.11 and I immediately got the GPU "out of memory" as soon as the render started. I rolled back the driver to 411.70 and everything is fast again. Don't know if this could be your problem.
I might have to do that,  even though I am not getting a memory error,  but I do have the latest driver installed
pka4916
pka4916
I only have 1 Graphics card. and that is the 1070
I did try uncheck CPU and then it seems to me, that there is no difference at all.
Last Active: Last Week
If you have complex scenes, it does help save resources if you hide anything in the Scene Manager that's not in view, reflects, or casts a shadow.
So if you have an animation with different camera angles, it would be better to render one camera angle at the time, allowing you to hide items that do not contribute to the scene.
3
