Preview Rendering takes forever
Posted By pka4916 7 Years Ago
3
pka4916
pka4916
Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)
Posts: 366, Visits: 1.4K
Not sure If I am missing something
But  I have an Nvidia 1070 GTX   and 64 Gb PC Memory
When I load an example project, and do preview rendering,  it takes forever...  it's been 10 minutes  and only 470 out of 1000 done
So I changed it to 200,  but still taking forever.
When i watched Kai's video it takes seconds... so  what am I missing here for the preview render?
Looking at the screen it uses the GPU and CPU for it.
pka4916
pka4916
another issue is,  every time i try to move the camera,    Iclone keeps Freezing up when I have the Iray preview up
Posts: 8.2K, Visits: 62.6K
Make sure that you are optimizing the VRAM usage of your card. That's what gives you the speed. If you go over your VRAM to system RAM, it will be really slow.
pka4916
pka4916
I checked the video, and setup like that as well.
It still takes forever..  every little move and it takes minutes before i can do something
Iclone keeps freezing up for a while, and then it does something.
Set the count to 150, and it still takes about 4-5 minutes.
idk why it takes so long.
Something is wrong, I think
Uninstall and reinstall iRay with a fresh download from your account.
Update your graphics driver. Make sure to do a custom install so you can totally replace the old driver.
Posts: 8.2K, Visits: 26.5K
1) I agrre with Rampa - something is definitely wrong.  It should not be THAT slow
2) Which "sample project" are you opening?
3) Are you on a laptop?
4) Are you sure it's running on your GPU and not your CPU?  Seems more likely to be an issue on a laptop because of the way they get configured for low-power operations.
4.1) Download the free "GPU-Z" and run that to monitor your graphics card while doing the test.  Does the GPU memory usage and "Load" increase when you open the project?  It is filling - and exceeding - your available VRAM memory on the graphics card?
pka4916
pka4916
I downloaded it this morning, and installed it, after removing it.
Will check again when I get home with the new install.
but before:
I load the project  and it's processing,  5 Gb is used out of 8  .  (in the main viewer it's using 0.5 Gb)
I am using the sample project that came with either a Training or default install I think.  Otherwise it's one of my many purchases.
It's located under projects at the top.  an house torned down on a hill seems like it.. with some trees.
I am using a Laptop indeed,   (https://www.asus.com/us/Laptops/ROG-G752VS)
Upgraded to 64 Gb Ram,  and 8 TB SSD space total
and a 1070 GTX card with 8 Gb
pka4916
pka4916
ok Tried it, and still the same problem..
it becomes impossible to work with Iray for me.
even 100 count, takes forever.. and freezing up.
pka4916
pka4916
Here is part of the log
  1.1   IRT    rend info : Shutting down irt render plugin.
  1.0   IMAGE  io   info : Loading image "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Cornea_20180912\RL_Cornea_20180912_resource_0.png", pixel type "Rgb", 1024x1024x1 pixels, 1 miplevel.
  1.0   SCENE  io   info : Loading module "::alg::base::core" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\alg\base\core.mdl".
  1.0   SCENE  io   info : Loading module "::nvidia::core_definitions" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\nvidia\core_definitions.mdl".
  1.0   SCENE  io   info : Loading module "::RL_Cornea_20180912" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Cornea_20180912.mdl".
   1.0   MDLC   comp warn : C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL\universal20181128.mdl(148,15): unused parameter 'Use_Map'
  1.0   MDLC   comp warn : C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL\universal20181128.mdl(157,16): unused parameter 'Default_Value'
  1.0   SCENE  io   info : Loading module "::RL::universal20181128" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL\universal20181128.mdl".
  1.0   SCENE  io   info : Loading module "::RL_Terrain" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Terrain.mdl".
  1.0   SCENE  io   info : Loading module "::RL::RL_light_ies_def" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL\RL_light_ies_def.mdl".
   1.0   IRT    rend info : Initializing context.
  1.0   IRT    rend info : Creating irt render context (cache id: 0x0000000100000000).
  1.0   IRT    rend info : Shutting down irt render context.
  1.0   IRT    rend info : Destroying context.
  1.0   IMAGE  io   info : Loading image "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Terrain\RL_Terrain_resource_0.png", pixel type "Rgb", 8x8x1 pixels, 1 miplevel.
  1.0   IMAGE  io   info : Loading image "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Terrain\RL_Terrain_resource_24.png", pixel type "Rgb", 8x8x1 pixels, 1 miplevel.
  1.0   IRT    rend info : Resource assignment for host 0 has changed.
  1.0   IRAY   rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
  1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 5.88661 GiB available, display attached
  1.0   IRAY   rend info : iray photoreal CPU fallback is enabled.
  1.0   IRT    rend info : Creating irt render context (cache id: 0x0000000100000001).
  1.2   IRAY   rend info : Updating geometry.
  1.2   IRAY   rend info : Using OptiX Prime ray tracing (5.0.1).
  1.2   IRAY   rend info : Importing scene graph.
  1.2   IRAY   rend info : Importing geometry for motion time 0
  1.2   IRAY   rend info : Geometry import (1 object with 7835k triangles, 1 instance yielding 7835k triangles) took 3.803642
  1.2   IRAY   rend info : Updating materials.
  1.2   MATCNV rend info : Material instance 'Standard_1(15)' uses MDL JIT compilation.
  1.2   MATCNV rend info : Material instance 'Standard_1(14)' uses MDL JIT compilation.
  1.2   MATCNV rend info : Material instance 'Standard_1(7)' uses MDL JIT compilation.
  1.2   MATCNV rend info : found 398 textures, 182 lambdas (80 unique)
  1.2   IRAY   rend info : Updating environment.
  1.2   IRAY   rend info : Updating backplate.
  1.2   IRAY   rend info : Updating lens.
  1.2   IRAY   rend info : Updating lights.
  1.2   IRAY   rend info : Updating object flags.
  1.2   IRAY   rend info : Updating caustic portals.
  1.2   IRAY   rend info : Updating decals.
  1.2   IRAY   rend info : Allocating 1-layer frame buffer
  1.2   IRAY   rend info : Using interactive scheduling, architectural sampler unavailable, caustic sampler disabled
  1.2   IRAY   rend info : Initializing local rendering.
  1.2   IRAY   rend info : CPU: using 3 cores for rendering
  1.2   IRAY   rend info : Rendering with 2 device(s):
  1.2   IRAY   rend info :    CUDA device 0 (GeForce GTX 1070)
  1.2   IRAY   rend info : Rendering...
  1.24  IRAY   rend info : Using device 0 to build data for host
  1.24  IRAY   rend info : Importing lights for motion time 0
  1.24  IRAY   rend info : Initializing light hierarchy.
  1.24  IRAY   rend info : Light hierarchy initialization took 0.00s
  1.26  IRAY   rend info : CPU: Scene processed in 3.241s
  1.24  IRAY   rend info : CPU: Allocated 419.074 KiB for frame buffer
  1.23  IRAY   rend info : JIT-linking wavefront kernel in 0.774s
  1.23  IRAY   rend info : JIT-linking mega kernel in 0.034s
  1.20  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 4.205s
  1.23  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 12.2511 MiB for frame buffer
  1.20  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.050s)
  1.20  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
  1.2   IRAY   rend info : Received update to 00001 iterations after 10.520s.
  1.18  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Prevent device timeout
  1.2   IRAY   rend info : Received update to 00002 iterations after 16.533s.
  1.2   IRAY   rend info : Received update to 00003 iterations after 22.515s.
  1.2   IRAY   rend info : Received update to 00004 iterations after 28.773s.
  1.22  IRAY   rend info : CPU: Allocated 3.22837 MiB for frame buffer
  1.7   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 9.43202 MiB for frame buffer
  1.2   IRAY   rend info : Received update to 00005 iterations after 34.554s.
  1.2   IRAY   rend info : Received update to 00006 iterations after 40.903s.
  1.2   IRAY   rend info : Received update to 00007 iterations after 47.081s.
  1.2   IRAY   rend info : Received update to 00008 iterations after 53.353s.
  1.2   IRAY   rend info : Received update to 00009 iterations after 59.536s.
  1.2   IRAY   rend info : Received update to 00010 iterations after 65.697s.
  1.2   IRAY   rend info : Received update to 00011 iterations after 71.974s.
  1.2   IRAY   rend info : Received update to 00012 iterations after 78.290s.
  1.2   IRAY   rend info : Received update to 00013 iterations after 84.466s.
  1.2   IRAY   rend info : Received update to 00014 iterations after 90.729s.
  1.2   IRAY   rend info : Received update to 00015 iterations after 96.995s.
  1.2   IRAY   rend info : Received update to 00016 iterations after 103.241s.
  1.2   IRAY   rend info : Received update to 00017 iterations after 109.332s.
  1.2   IRAY   rend info : Received update to 00018 iterations after 115.527s.
  1.2   IRAY   rend info : Received update to 00019 iterations after 121.602s.
  1.2   IRAY   rend info : Received update to 00021 iterations after 133.357s.
  1.2   IRAY   rend info : Received update to 00023 iterations after 145.181s.
  1.24  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Prevented device timeout
  1.22  IRAY   rend info : CPU: Allocated 2.85897 MiB for frame buffer
  1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 9.80142 MiB for frame buffer
  1.2   IRAY   rend info : Received update to 00025 iterations after 156.976s.
  1.12  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Prevented device timeout
  1.2   IRAY   rend info : Received update to 00027 iterations after 167.800s
  1.2   IRAY   rend info : Received update to 00030 iterations after 184.442s.
pka4916
pka4916
Any help is appreciated
3
