Preview Rendering takes forever
https://forum.reallusion.com/Topic404002.aspx
Print Topic | Close Window
By pka4916 - 7 Years Ago
Not sure If I am missing something
But  I have an Nvidia 1070 GTX   and 64 Gb PC Memory
When I load an example project, and do preview rendering,  it takes forever...  it's been 10 minutes  and only 470 out of 1000 done
So I changed it to 200,  but still taking forever.
When i watched Kai's video it takes seconds... so  what am I missing here for the preview render?
Looking at the screen it uses the GPU and CPU for it.
another issue is,  every time i try to move the camera,    Iclone keeps Freezing up when I have the Iray preview up
By Rampa - 7 Years Ago
Make sure that you are optimizing the VRAM usage of your card. That's what gives you the speed. If you go over your VRAM to system RAM, it will be really slow.
I checked the video, and setup like that as well.
It still takes forever..  every little move and it takes minutes before i can do something
Iclone keeps freezing up for a while, and then it does something.
Set the count to 150, and it still takes about 4-5 minutes.
idk why it takes so long.
Something is wrong, I think
Uninstall and reinstall iRay with a fresh download from your account.
Update your graphics driver. Make sure to do a custom install so you can totally replace the old driver.
By justaviking - 7 Years Ago
1) I agrre with Rampa - something is definitely wrong.  It should not be THAT slow
2) Which "sample project" are you opening?
3) Are you on a laptop?
4) Are you sure it's running on your GPU and not your CPU?  Seems more likely to be an issue on a laptop because of the way they get configured for low-power operations.
4.1) Download the free "GPU-Z" and run that to monitor your graphics card while doing the test.  Does the GPU memory usage and "Load" increase when you open the project?  It is filling - and exceeding - your available VRAM memory on the graphics card?
I downloaded it this morning, and installed it, after removing it.
Will check again when I get home with the new install.
but before:
I load the project  and it's processing,  5 Gb is used out of 8  .  (in the main viewer it's using 0.5 Gb)
I am using the sample project that came with either a Training or default install I think.  Otherwise it's one of my many purchases.
It's located under projects at the top.  an house torned down on a hill seems like it.. with some trees.
I am using a Laptop indeed,   (https://www.asus.com/us/Laptops/ROG-G752VS)
Upgraded to 64 Gb Ram,  and 8 TB SSD space total
and a 1070 GTX card with 8 Gb
ok Tried it, and still the same problem..
it becomes impossible to work with Iray for me.
even 100 count, takes forever.. and freezing up.
Here is part of the log
  1.1   IRT    rend info : Shutting down irt render plugin.
  1.0   IMAGE  io   info : Loading image "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Cornea_20180912\RL_Cornea_20180912_resource_0.png", pixel type "Rgb", 1024x1024x1 pixels, 1 miplevel.
  1.0   SCENE  io   info : Loading module "::alg::base::core" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\alg\base\core.mdl".
  1.0   SCENE  io   info : Loading module "::nvidia::core_definitions" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\nvidia\core_definitions.mdl".
  1.0   SCENE  io   info : Loading module "::RL_Cornea_20180912" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Cornea_20180912.mdl".
   1.0   MDLC   comp warn : C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL\universal20181128.mdl(148,15): unused parameter 'Use_Map'
  1.0   MDLC   comp warn : C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL\universal20181128.mdl(157,16): unused parameter 'Default_Value'
  1.0   SCENE  io   info : Loading module "::RL::universal20181128" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL\universal20181128.mdl".
  1.0   SCENE  io   info : Loading module "::RL_Terrain" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Terrain.mdl".
  1.0   SCENE  io   info : Loading module "::RL::RL_light_ies_def" from "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL\RL_light_ies_def.mdl".
   1.0   IRT    rend info : Initializing context.
  1.0   IRT    rend info : Creating irt render context (cache id: 0x0000000100000000).
  1.0   IRT    rend info : Shutting down irt render context.
  1.0   IRT    rend info : Destroying context.
  1.0   IMAGE  io   info : Loading image "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Terrain\RL_Terrain_resource_0.png", pixel type "Rgb", 8x8x1 pixels, 1 miplevel.
  1.0   IMAGE  io   info : Loading image "C:\Program Files\Reallusion\Shared Plugins\ICIrayRender\Mdl\RL_Terrain\RL_Terrain_resource_24.png", pixel type "Rgb", 8x8x1 pixels, 1 miplevel.
  1.0   IRT    rend info : Resource assignment for host 0 has changed.
  1.0   IRAY   rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
  1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 5.88661 GiB available, display attached
  1.0   IRAY   rend info : iray photoreal CPU fallback is enabled.
  1.0   IRT    rend info : Creating irt render context (cache id: 0x0000000100000001).
  1.2   IRAY   rend info : Updating geometry.
  1.2   IRAY   rend info : Using OptiX Prime ray tracing (5.0.1).
  1.2   IRAY   rend info : Importing scene graph.
  1.2   IRAY   rend info : Importing geometry for motion time 0
  1.2   IRAY   rend info : Geometry import (1 object with 7835k triangles, 1 instance yielding 7835k triangles) took 3.803642
  1.2   IRAY   rend info : Updating materials.
  1.2   MATCNV rend info : Material instance 'Standard_1(15)' uses MDL JIT compilation.
  1.2   MATCNV rend info : Material instance 'Standard_1(14)' uses MDL JIT compilation.
  1.2   MATCNV rend info : Material instance 'Standard_1(7)' uses MDL JIT compilation.
  1.2   MATCNV rend info : found 398 textures, 182 lambdas (80 unique)
  1.2   IRAY   rend info : Updating environment.
  1.2   IRAY   rend info : Updating backplate.
  1.2   IRAY   rend info : Updating lens.
  1.2   IRAY   rend info : Updating lights.
  1.2   IRAY   rend info : Updating object flags.
  1.2   IRAY   rend info : Updating caustic portals.
  1.2   IRAY   rend info : Updating decals.
  1.2   IRAY   rend info : Allocating 1-layer frame buffer
  1.2   IRAY   rend info : Using interactive scheduling, architectural sampler unavailable, caustic sampler disabled
  1.2   IRAY   rend info : Initializing local rendering.
  1.2   IRAY   rend info : CPU: using 3 cores for rendering
  1.2   IRAY   rend info : Rendering with 2 device(s):
  1.2   IRAY   rend info :    CUDA device 0 (GeForce GTX 1070)
  1.2   IRAY   rend info : Rendering...
  1.24  IRAY   rend info : Using device 0 to build data for host
  1.24  IRAY   rend info : Importing lights for motion time 0
  1.24  IRAY   rend info : Initializing light hierarchy.
  1.24  IRAY   rend info : Light hierarchy initialization took 0.00s
  1.26  IRAY   rend info : CPU: Scene processed in 3.241s
  1.24  IRAY   rend info : CPU: Allocated 419.074 KiB for frame buffer
  1.23  IRAY   rend info : JIT-linking wavefront kernel in 0.774s
  1.23  IRAY   rend info : JIT-linking mega kernel in 0.034s
  1.20  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 4.205s
  1.23  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 12.2511 MiB for frame buffer
  1.20  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.050s)
  1.20  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
  1.2   IRAY   rend info : Received update to 00001 iterations after 10.520s.
  1.18  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Prevent device timeout
  1.2   IRAY   rend info : Received update to 00002 iterations after 16.533s.
  1.2   IRAY   rend info : Received update to 00003 iterations after 22.515s.
  1.2   IRAY   rend info : Received update to 00004 iterations after 28.773s.
  1.22  IRAY   rend info : CPU: Allocated 3.22837 MiB for frame buffer
  1.7   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 9.43202 MiB for frame buffer
  1.2   IRAY   rend info : Received update to 00005 iterations after 34.554s.
  1.2   IRAY   rend info : Received update to 00006 iterations after 40.903s.
  1.2   IRAY   rend info : Received update to 00007 iterations after 47.081s.
  1.2   IRAY   rend info : Received update to 00008 iterations after 53.353s.
  1.2   IRAY   rend info : Received update to 00009 iterations after 59.536s.
  1.2   IRAY   rend info : Received update to 00010 iterations after 65.697s.
  1.2   IRAY   rend info : Received update to 00011 iterations after 71.974s.
  1.2   IRAY   rend info : Received update to 00012 iterations after 78.290s.
  1.2   IRAY   rend info : Received update to 00013 iterations after 84.466s.
  1.2   IRAY   rend info : Received update to 00014 iterations after 90.729s.
  1.2   IRAY   rend info : Received update to 00015 iterations after 96.995s.
  1.2   IRAY   rend info : Received update to 00016 iterations after 103.241s.
  1.2   IRAY   rend info : Received update to 00017 iterations after 109.332s.
  1.2   IRAY   rend info : Received update to 00018 iterations after 115.527s.
  1.2   IRAY   rend info : Received update to 00019 iterations after 121.602s.
  1.2   IRAY   rend info : Received update to 00021 iterations after 133.357s.
  1.2   IRAY   rend info : Received update to 00023 iterations after 145.181s.
  1.24  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Prevented device timeout
  1.22  IRAY   rend info : CPU: Allocated 2.85897 MiB for frame buffer
  1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 9.80142 MiB for frame buffer
  1.2   IRAY   rend info : Received update to 00025 iterations after 156.976s.
  1.12  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Prevented device timeout
  1.2   IRAY   rend info : Received update to 00027 iterations after 167.800s
  1.2   IRAY   rend info : Received update to 00030 iterations after 184.442s.
Any help is appreciated
The key thing I'm seeing in the log you shared (thank you) is:
It seems to confirm my suspicion that you're rendering on your CPU.
Now the question is, "Why?"  I don't know, yet.
There is probably an Nvidia setting somewhere that can enable your GTX 1070 for Iray, or make it the default, or something like that.  I'm not sure where exactly that is.
By ckalan1 - 7 Years Ago
I am having the same problem.
I think these are the pertinent lines from the iray render log.
1.6 IRAY rend error: CUDA device 0 (GeForce GTX 1080 Ti): Kernel [6] (EnvironmentMatte ) failed after 0.008s
1.6 IRAY rend error: CUDA device 0 (GeForce GTX 1080 Ti): an illegal instruction was encountered (while launching CUDA renderer in core_renderer_wf.cpp:771)
1.6 IRAY rend error: CUDA device 0 (GeForce GTX 1080 Ti): Failed to launch renderer
1.2 IRAY rend error: CUDA device 0 (GeForce GTX 1080 Ti): Device failed while rendering
1.3 IRAY rend error: CUDA device 1 (GeForce GTX 1080 Ti): an illegal instruction was encountered (while allocating memory)
1.3 IRAY rend error: CUDA device 1 (GeForce GTX 1080 Ti): Failed to allocate 4 B
1.3 IRAY rend info : CUDA device 1 (GeForce GTX 1080 Ti): Used for display, optimizing for interactive usage (performance could be sacrificed)
1.6 IRAY rend error: CUDA device 1 (GeForce GTX 1080 Ti): an illegal instruction was encountered (while allocating memory)
1.6 IRAY rend error: CUDA device 1 (GeForce GTX 1080 Ti): Failed to allocate 120 B
1.6 IRAY rend error: CUDA device 1 (GeForce GTX 1080 Ti): an illegal instruction was encountered (while resolving mapped memory)
1.6 IRAY rend error: CUDA device 1 (GeForce GTX 1080 Ti): an illegal instruction was encountered (while launching CUDA ior stack renderer in core_cuda_host.cpp:385)
1.3 IRAY rend error: CUDA device 1 (GeForce GTX 1080 Ti): Failed to update ior stack
1.3 IRAY rend error: CUDA device 1 (GeForce GTX 1080 Ti): Device failed while rendering
1.3 IRAY rend warn : All available GPUs failed.
1.3 IRAY rend warn : No devices activated. Enabling CPU fallback.
1.3 IRAY rend warn : Re-rendering iteration because of device failure
1.2 IRAY rend error: All workers failed: aborting render
1.3 IRAY rend error: CUDA device 1 (GeForce GTX 1080 Ti): an illegal instruction was encountered (while de-allocating memory)
1.2 IRAY rend error: CUDA device 0 (GeForce GTX 1080 Ti): an illegal instruction was encountered (while de-allocating memory)
BTW I used IRAY in DAZ studio and everything worked fine there. Also, I have been using IRAY in iclone since it came out without any problems until yesterday. I have all the latest drivers. I have already uninstalled and reinstalled the plugin.
Any help would be much appreciated.
Thanks,
Craig
By Peter (RL) - 7 Years Ago
pka4916 (2/7/2019)
Try going into your "Iray Render Settings" and click on "Hardware Settings". Now check to see which graphics cards are listed and ensure the right one is checked.
Then for the purposes of testing, take out the check from CPU which will force the Iray rendering to use only the chosen graphics card. Does this improve or worsen the time it takes to preview render?
https://forum.reallusion.com/uploads/images/cb1f87eb-e89b-4136-830b-398c.png
By DroneMaster - 7 Years Ago
I've got the GTX 1080 t1 using the Nvidia 411.70 driver. It worked fast. I upgraded the driver to the latest 418.11 and I immediately got the GPU "out of memory" as soon as the render started. I rolled back the driver to 411.70 and everything is fast again. Don't know if this could be your problem.
Thanks for the tip. I rolled back to the older driver and now IRAY is working again with small projects. It seems to be having problems with complex scenes.
FYI - The new driver worked in Daz Studio as well as the old driver.
Craig
ckalan1 (2/7/2019)
Glad it helped. As for the complicated scenes, I loaded a project with a bunch of Speed Tree grasses and trees and sunflowers and iRay choked and disappeared off the screen but it left iClone standing. I guess that's a good thing.
By animagic - 7 Years Ago
If you have complex scenes, it does help save resources if you hide anything in the Scene Manager that's not in view, reflects, or casts a shadow.
So if you have an animation with different camera angles, it would be better to render one camera angle at the time, allowing you to hide items that do not contribute to the scene.
I only have 1 Graphics card. and that is the 1070
I did try uncheck CPU and then it seems to me, that there is no difference at all.
DroneMaster (2/7/2019)
I might have to do that,  even though I am not getting a memory error,  but I do have the latest driver installed
Installed the 411.70 driver, and no difference.
I did notice that even if your done with a preview and close it,  it doesn't free up the GPU memory.
I start out with 4.5 Gb  and when doing is 2-3 times, it's at 7.5 Gb.
Even closing the preview doesn't release the memory. or whatever.
Played with all the settings, and the only one that makes somewhat a difference is when I change the preview screen size to 320x240 and zoom in.
The default 1000 x something,  is making is slow..   even 640x480 preview is slow.
How does the smartcache work?  do you need to enable something, since I don't see a difference.
Then I still have the fact, that once it's done, and I zoom in or move the camera, it's still take a long time before I can move again.. there is a huge deley between the movement
and the preview starts doing something.
pka4916 (2/8/2019)
Installed the 411.70 driver, and no difference..
The only other thing I can think of is your texture compression. Is it set to "none"? Me, I have it on medium. Also check how big the texture sizes you allow in your project settings. Other than that, I don't have a clue.
justaviking (2/7/2019)
I totally missed this post.
That is a good question,  I do see the GPU running up to 7.5 Gb.  but the logs tells me otherwise.
Maybe a staf Member can answer this one.
I checked the settings, and I don't see anything.
Are there other 1070 users out there?   I know Kai used a 1080..  Maybe he knows,  if he is watching this :)
DroneMaster (2/8/2019)
pka4916 (2/8/2019)
I tried Max / Medium  None.
Tried   2048 x 2048,   1024x1024,   512x512
It makes all no difference.
I just commented to another post (see above)   that might explain why it's not working for me.
ok made another test, just in case
Can you tell me if in the 1st part the GPU is not used again?
I made 3 sections
1= GPU+ CPU
2 = GPU
3= GPU + CPU  with Iclone Added to the control panel from Nvidia under Manage 3D settings.
I didn't see any improvement, but looks like the log is different.
GPU + CPU
  1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 5.54383 GiB available, display attached
GPU only
  1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 2.48881 GiB available, display attached
  1.14  IRAY   rend info : Received update to 00059 iterations after 65.311s.
  1.14  IRAY   rend info : Rendering with 1 device(s):
  1.14  IRAY   rend info :    CUDA device 0 (GeForce GTX 1070)
  1.14  IRAY   rend info : Rendering...
  1.16  IRAY   rend info : JIT-linking wavefront kernel in 0.064s
  1.16  IRAY   rend info : JIT-linking mega kernel in 0.035s
  1.17  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 0.101s
  1.22  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 12.8458 MiB for frame buffer
  1.17  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.000s)
  1.17  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
  1.14  IRAY   rend info : Received update to 00060 iterations after 69.493s.
  1.14  IRAY   rend info : Received update to 00062 iterations after 71.284s.
  1.14  IRAY   rend info : Received update to 00066 iterations after 74.658s.
  1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 2.48619 GiB available, display attached
  1.14  IRAY   rend info : Received update to 00074 iterations after 81.200s.
  1.14  IRAY   rend info : CPU: using 3 cores for rendering
  1.14  IRAY   rend info : Rendering with 2 device(s):
Here I added Iclone to the Nvideo Control Panel and checked always use GPU for this program
  1.14  IRAY   rend info : Allocating 1-layer frame buffer
  1.14  IRAY   rend info : Using interactive scheduling, architectural sampler unavailable, caustic sampler disabled
  1.14  IRAY   rend info : Initializing local rendering.
  1.8   IRAY   rend info : Using device 0 to build data for host
  1.8   IRAY   rend info : Importing lights for motion time 0
  1.8   IRAY   rend info : Initializing light hierarchy.
  1.8   IRAY   rend info : Light hierarchy initialization took 0.13s
  1.5   IRAY   rend info : CPU: Scene processed in 5.484s
  1.15  IRAY   rend info : CPU: Allocated 424.387 KiB for frame buffer
  1.2   IRAY   rend info : JIT-linking wavefront kernel in 1.354s
  1.2   IRAY   rend info : JIT-linking mega kernel in 0.032s
  1.6   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 6.940s
  1.15  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 12.4326 MiB for frame buffer
  1.6   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.056s)
  1.6   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
  1.14  IRAY   rend info : Received update to 00001 iterations after 8.034s.
  1.14  IRAY   rend info : Received update to 00002 iterations after 9.039s.
  1.14  IRAY   rend info : Received update to 00003 iterations after 10.044s.
  1.14  IRAY   rend info : Received update to 00004 iterations after 11.027s.
  1.14  IRAY   rend info : Received update to 00005 iterations after 12.024s.
  1.22  IRAY   rend info : CPU: Allocated 3.08456 MiB for frame buffer
  1.18  IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 9.76251 MiB for frame buffer
  1.14  IRAY   rend info : Received update to 00006 iterations after 12.982s.
  1.14  IRAY   rend info : Received update to 00007 iterations after 14.241s.
  1.14  IRAY   rend info : Received update to 00008 iterations after 15.485s.
  1.14  IRAY   rend info : Received update to 00009 iterations after 16.764s.
  1.14  IRAY   rend info : Received update to 00010 iterations after 17.970s.
  1.14  IRAY   rend info : Received update to 00011 iterations after 19.233s.
  1.14  IRAY   rend info : Received update to 00012 iterations after 20.483s.
  1.14  IRAY   rend info : Received update to 00013 iterations after 21.739s.
  1.4   IRAY   rend info : CPU: Allocated 2.53677 MiB for frame buffer
  1.5   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 10.3103 MiB for frame buffer
  1.14  IRAY   rend info : Received update to 00014 iterations after 22.978s.
  1.14  IRAY   rend info : Received update to 00015 iterations after 23.984s.
  1.14  IRAY   rend info : Received update to 00017 iterations after 25.903s.
By gordryd - 7 Years Ago
The logs seem to show you are previewing in 'Photoreal' mode -- that will definitely take longer.  Try changing the mode to 'Interactive' and see if it improves.
I tried that, and it's a little bit faster, but still takes forever.
If I look at Kai's video,  it takes seconde with a 1080 card.
I cannot get it that fast as in the video..
I almost want to ask for  project  or how someone else has all the setting for iclone and iray.
