Preview Rendering takes forever
Posted By pka4916 7 Years Ago
pka4916
pka4916
Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)
Posts: 366, Visits: 1.4K
Not sure If I am missing something
But  I have an Nvidia 1070 GTX   and 64 Gb PC Memory
When I load an example project, and do preview rendering,  it takes forever...  it's been 10 minutes  and only 470 out of 1000 done
So I changed it to 200,  but still taking forever.
When i watched Kai's video it takes seconds... so  what am I missing here for the preview render?
Looking at the screen it uses the GPU and CPU for it.
Threaded View
Threaded View
Forum Post Preview Rendering takes forever By pka4916 ( 7 Years Ago )
Forum Post another issue is, every time i try to move the camera, Iclone... By pka4916 ( 7 Years Ago )
Forum Post Make sure that you are optimizing the VRAM usage of your card. That's... By Rampa ( 7 Years Ago )
Forum Post I checked the video, and setup like that as well. It still takes... By pka4916 ( 7 Years Ago )
Forum Post Something is wrong, I think Uninstall and reinstall iRay with a fresh... By Rampa ( 7 Years Ago )
Forum Post 1) I agrre with Rampa - something is definitely wrong. It should not... By justaviking ( 7 Years Ago )
Forum Post I downloaded it this morning, and installed it, after removing it.... By pka4916 ( 7 Years Ago )
Forum Post ok Tried it, and still the same problem.. it becomes impossible to... By pka4916 ( 7 Years Ago )
Forum Post Here is part of the log 1.1 IRT rend info : Shutting... By pka4916 ( 7 Years Ago )
Forum Post Any help is appreciated By pka4916 ( 7 Years Ago )
Forum Post The key thing I'm seeing in the log you shared (thank you) is:... By justaviking ( 7 Years Ago )
Forum Post I am having the same problem. I think these are the pertinent lines... By ckalan1 ( 7 Years Ago )
Forum Post [quote][b]justaviking (2/7/2019)[/b][hr]The key thing I'm seeing in... By pka4916 ( 7 Years Ago )
Forum Post [quote][b]pka4916 (2/7/2019)[/b][hr] Any help is appreciated... By Peter (RL) ( 7 Years Ago )
Forum Post I only have 1 Graphics card. and that is the 1070 I did try uncheck... By pka4916 ( 7 Years Ago )
Forum Post I've got the GTX 1080 t1 using the Nvidia 411.70 driver. It worked... By DroneMaster ( 7 Years Ago )
Forum Post Thanks for the tip. I rolled back to the older driver and now IRAY is... By ckalan1 ( 7 Years Ago )
Forum Post [quote][b]ckalan1 (2/7/2019)[/b][hr] It seems to be having problems... By DroneMaster ( 7 Years Ago )
Forum Post [quote][b]DroneMaster (2/7/2019)[/b][hr]I've got the GTX 1080 t1 using... By pka4916 ( 7 Years Ago )
Forum Post If you have complex scenes, it does help save resources if you hide... By animagic ( 7 Years Ago )
Forum Post Installed the 411.70 driver, and no difference. I did notice that even... By pka4916 ( 7 Years Ago )
Forum Post [quote][b]pka4916 (2/8/2019)[/b][hr]Installed the 411.70 driver, and... By DroneMaster ( 7 Years Ago )
Forum Post [quote][b]DroneMaster (2/8/2019)[/b][hr][quote][b]pka4916... By pka4916 ( 7 Years Ago )
Forum Post ok made another test, just in case Can you tell me if in the 1st part... By pka4916 ( 7 Years Ago )
Forum Post The logs seem to show you are previewing in 'Photoreal' mode -- that... By gordryd ( 7 Years Ago )
Forum Post I tried that, and it's a little bit faster, but still takes forever.... By pka4916 ( 7 Years Ago )
