DialogCallback crashes iclone 7 . A bug or a scripting error?
Posted By frank_461853 3 Years Ago
frank_461853
frank_461853
Senior Member (395 reputation)Senior Member (395 reputation)Senior Member (395 reputation)Senior Member (395 reputation)Senior Member (395 reputation)Senior Member (395 reputation)Senior Member (395 reputation)Senior Member (395 reputation)Senior Member (395 reputation)
Posts: 26, Visits: 96
in my plugin i copied this from one of the examples on the iclone python site
class DialogCallback(RLPy.RDialogCallback):
    def __init__(self):
        RLPy.RDialogCallback.__init__(self)
    def OnDialogHide(self):
        RLPy.RDialogCallback.__hide__(self)
        print("The dialog window is Hidden")
    def OnDialogShow(self):
        print("The dialog window is Shown")
    def OnDialogClose(self):
        RLPy.RDialogCallback.__close__(self)
        print("The dialog window is Closed")
        return True
and this
       dock_window = RLPy.RUi.CreateRDockWidget()
    dock_window.SetWindowTitle("SetStage")
    dock_window.SetAllowedAreas(RLPy.EDockWidgetAreas_RightDockWidgetArea)
    hide_button = QtWidgets.QPushButton(text="Hide", minimumHeight=24)
    hide_button.clicked.connect(lambda: dock_window.Hide())
    #show_button = QtWidgets.QPushButton(text="Show", minimumHeight=24)
    #show_button.clicked.connect(lambda: dock_window.Show())
    main_widget = QtWidgets.QWidget()
    main_widget.setLayout(QtWidgets.QHBoxLayout())
    #main_widget.layout().addWidget(hide_button)
    #main_widget.layout().addWidget(show_button)
    Stage_One= QtWidgets.QPushButton(text="1", minimumHeight=24)
    Stage_One.clicked.connect(lambda: set_Lights(1))
    Stage_Two= QtWidgets.QPushButton(text="2", minimumHeight=24)
    Stage_Two.clicked.connect(lambda: set_Lights(2))
    Stage_Three= QtWidgets.QPushButton(text="3", minimumHeight=24)
    Stage_Three.clicked.connect(lambda: set_Lights(3))
    Stage_Four= QtWidgets.QPushButton(text="4", minimumHeight=24)
    Stage_Four.clicked.connect(lambda: set_Lights(4))
    Stage_Five= QtWidgets.QPushButton(text="5", minimumHeight=24)
    Stage_Five.clicked.connect(lambda: set_Lights(5))
    main_widget.layout().addWidget(Stage_One)
    main_widget.layout().addWidget(Stage_Two)
    main_widget.layout().addWidget(Stage_Three)
    main_widget.layout().addWidget(Stage_Four)
    main_widget.layout().addWidget(Stage_Five)
    dock = wrapInstance(int(dock_window.GetWindow()), QtWidgets.QDockWidget)
    dock.setFixedWidth(300)
    dock.setWidget(main_widget)
    dialog_callback = DialogCallback()
    dialog_register_id = dock_window.RegisterEventCallback(dialog_callback)
    dock_window.Show()
when i run the script the dialog moves and behaves fine. it shows the message "The dialog is shown" in the logging console. however if i click the close button on the dialog or try to dock it, it crashes iclone. is this a bug or is there something wrong with the code?
Thank you
3 Years Ago by frank_461853
philipjie117
philipjie117
Posted Last Year
New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)
Posts: 6, Visits: 108
Hey, frank. It may be too late, but I still want to share my attempt with you.
I met the same crash. I found that if delete the code "RLPy.RDialogCallback.__hide__(self)" in OnDialogHide(self) and "RLPy.RDialogCallback.__close__(self)" in OnDialogClose(self), iClone 7 will not crash. The problem seems to be solved.
