Walvince
Walvince
Visits: 798
Hi, I' trying to follow this tutorial but I've got a problem from the beginning...  When I add the PBR material to the prop, nothing happens. Well visually because technically in the material tab I can see that all seems ok (there's texture settings, etc).
Previously I saw a problem that could be the same. When I add water (props/water/still normal), it only add a monochrome surface with no water effect. I noticed that the diffuse map was empty, so it's probably the problem here but I guess it's not normal and that's there is a problem somwhere (files missing ?)
Posts: 8.0K,
Visits: 25.7K
Hi. Can you add a couple screen shots, please?
Is it safe to assume you're adding the PBR material using the drag-and-drop technique shown at the beginning of the tutorial you linked? What are you applying the material to? An iClone primitive (plane, cube, etc.) or a more complicated item, one that might have multiple materials?
iClone 7... Character Creator... Substance Designer/Painter... Blender... Audacity... Desktop (homebuilt) - Windows 7, i7-3770k CPU, GTX 1080 GPU (8GB), 16GB RAM, Asus P8Z77-V Pro motherboard, 1TB SSD, terabytes of disk space, dual monitors. Laptop - Windows 10, MSI GS63VR STEALTH-252, 16GB RAM, GTX 1060 (6GB), 256GB SSD and 1TB HDD
Walvince
Walvince
Visits: 798
Well I am doing the exact same thing (I think) than in the tutorial, so I drag & drop the concrete_pavement substance on the soft cloth 64x64. Here is the global window after applying the material :  Then the Modify panel parameters :  And the content :
Posts: 8.0K,
Visits: 25.7K
Try changing this setting (see picture) to "High."
Walvince
Walvince
Visits: 798
Wonderfull, that was it ! Thanks a lot ! Displacement Map and Substance were unchecked in the preferences, I didn't know we could customized that. Thanks for your help
3 Years Ago by
Walvince
