Can't use PBR substances
Posted By Walvince 7 Years Ago
annette.wilson1227
annette.wilson1227
New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)
Posts: 1, Visits: 67
You are so right, I tried everything but your solution.
thank you
rustybee255
rustybee255
New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)
Posts: 3, Visits: 94
Thx Walvince! Sometimes the most obvious adjustments are the most difficult to try :-)
Walvince
Walvince
Last Active: 6 Months Ago
Posts: 99, Visits: 972
Wonderfull, that was it ! Thanks a lot !
Displacement Map and Substance were unchecked in the preferences, I didn't know we could customized that. Thanks for your help :)
Posts: 8.2K, Visits: 26.5K
Try changing this setting (see picture) to "High."
https://forum.reallusion.com/uploads/images/cff69400-d839-4aaa-9168-b6c8.jpg
Walvince
Walvince
Well I am doing the exact same thing (I think) than in the tutorial, so I drag & drop the concrete_pavement substance on the soft cloth 64x64.
Here is the global window after applying the material :
https://forum.reallusion.com/uploads/images/cbb922c3-2994-4d26-a699-6911.png
Then the Modify panel parameters :
https://forum.reallusion.com/uploads/images/bbb8a49c-4d78-499f-9182-cbd5.png
And the content :
https://forum.reallusion.com/uploads/images/f9d61641-bde5-49b3-9614-a5e5.png
Hi.
Can you add a couple screen shots, please?
Is it safe to assume you're adding the PBR material using the drag-and-drop technique shown at the beginning of the tutorial you linked?
What are you applying the material to?  An iClone primitive (plane, cube, etc.) or a more complicated item, one that might have multiple materials?
Walvince
Walvince
Hi,
I' trying to follow this tutorial but I've got a problem from the beginning... :doze:
When I add the PBR material to the prop, nothing happens. Well visually because technically in the material tab I can see that all seems ok (there's texture settings, etc).
Previously I saw a problem that could be the same. When I add water (props/water/still normal), it only add a monochrome surface with no water effect. I noticed that the diffuse map was empty, so it's probably the problem here but I guess it's not normal and that's there is a problem somwhere (files missing ?)
