Exposure With False Colors
Posted By GOETZIWOOD STUDIOS 6 Years Ago
3
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)
Posts: 1.2K, Visits: 7.2K
Nowadays, movies Directors of Photography use more and more what is called "False Colors" in order to control and set the camera exposure. They barely use light meters anymore for this, only for checking contrast on their subjects from different light sources.
With digital cameras you can directly see in realtime what the sensor is capturing so it is easy to make some adjustments directly by looking at that result, False Colors being a way to be more precise than doing it just by "eye". This is also a way to decouple exposure "values" from specifics from the camera (ISO or rather Gain, Aperture, Shutter, ND filters, ..) to a normalized 0% to 100% range (you will see sometime the term IRE but this is nothing more than percentage really). If you light an object to be in the 20% to 30% range, it will look the same, ultimately, whatever combinaison of Gain, Aperture, Shutter you set on different camera (in terms of exposure that is).
Using False Color is nothing more than applying a colored gradient to the luminosity of your image. So you can have red near black areas and yellow or white near the brightest areas. Here is one I made in Photoshop:
https://forum.reallusion.com/uploads/images/2e69e25a-66d7-438b-b516-5dbe.jpg
Colors from left to right will be applied on your image areas from full dark to full bright.This gradient one is a bit more complicated than a simple gradient.
Notice there is a middle range that has a kind of brownish gradient of color. This is what we call the Skintone range and it is supposed to show where should be exposed your subject (face) to be correctly exposed while maintaining sufficient space for informations above (lighter) and below (darker). This is obviously relatively subjective and each DP has his preferences (depending on the quality of the camera sensor, its "color science" and obviously its dynamic range). I chosen mine to be between 20% and 60% which is a bit wide (you will usually see 50% to 70% in movies) but this is due to the very limited dynamic range of what we get from the iClone renderer without proper Tone Mapping.
Notice there are also extreme areas, on the left (red) and right (white), kind of a safeguard zones. You don't want to have 0 information in some areas of your image nor clipped informations (except on purpose like lights and some reflection highlights).
So what do I do with that gradient ? I've created a special effect LUT for iClone so I can apply this gradient directly to the final image. Download the attached FalseColors_20-60.rar file that contains a FalseColors_20-60.iEffect file and put it in your effect template.
Now lets try it in iClone. Load the sample PRB Materials project and go to the frame 1640:
https://forum.reallusion.com/uploads/images/30213335-35ca-4e0e-824e-e959.jpg
Go to the Visual -> Effect Tab and remove the 2 default ColorAdjust effects. Then load the iEffect you got from here. Activate only the "FalseColors_20-60 effect, you should now see something like that:
https://forum.reallusion.com/uploads/images/3d30c76e-06d9-4115-b72f-43e3.jpg
We can clearly see there are white and yellow on some critical areas on the dummy material objects that shows those are overexposed.
We will try to start from scratch, disable the IBL light and the 3 scene lights, then I like to start with the "ambient" lighting by playing with the IBL strength so that there are information in the dark areas, try to remove reds but not too much strength, just so we start to see the skintone in some places:
https://forum.reallusion.com/uploads/images/68865444-bd0e-4030-b64d-521e.jpg
And if you deactivate the False Colors you should have something like that:
https://forum.reallusion.com/uploads/images/90c23f0c-73f7-408c-892d-aaab.jpg
And this is exactly what we want, an ambient lit scene without 0/red area. Now we can play with the scene Key light, Rim and Fill lights until we get something we like while being careful to not introduce too much yellow and avoid white area except where it makes sense (direct light and reflection highlights):
https://forum.reallusion.com/uploads/images/1ec15a51-861b-4b79-a583-80e8.jpg
And the resulting exposed image:
https://forum.reallusion.com/uploads/images/c7367a00-98e7-43e4-aee4-d65e.jpg
Now if you carefully compare this result with the first image after we opened the scene you will notice that we have been able to retrieve valid color information from the white dummy "iClone7_MaterialBall_04" that had large clipped areas in its high lit areas. Accordingly, we have retrieved valid color information from the yellow "iClone7_MaterialBall_07" that had large "burnt" areas in its high lit areas.
By using this False Color method to control the exposure of the rendering of our images we clearly see that we can precisely adjust any kind of combinaison and quantity of light sources (HDRI IBL Lights GI etc..) so the image will be perfectly exposed. No area with black value, no burnt nor clipped areas unless on purpose.
We really are "in control" and as such we can have consistent exposure from one shot to another one, from scene to scene.
Of course you are not obliged to use this particular LUT/Gradient, you can create your own that may better suit your style, as long as it protects you from absolute dark areas as well as burnt and clipped ones.
guy rabiller | GOETZIWOOD STUDIOS
"N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
FalseColors_20-60.rar (167 views, 134.00 KB)
wildstar
wildstar
Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)
Last Active: 9 Months Ago
Posts: 1.2K, Visits: 5.1K
thx for that, i will give it a look , and talk about later
wildstar
wildstar
Warped Reality VFX
Warped Reality VFX
Posts: 386, Visits: 8.4K
Hello, GOETZIWOOD STUDIOS thank you for taking the time to make this tutorial.
And sharing your knowledge in this area, much appreciated.
Best Regards.
Kevin L.
Warped Reality VFX.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
@Kevin L
Thanks for letting me know Kevin, You're welcome.
Thank you for this , Guy. I have been attempting to improve the cinematographic look of my latest movie, so this is very timely and helpful. So much to learn...:unsure:
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
@animagic
You're very welcome Job, I'm glad this is helpful!
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
I often talk about this "PBRish"/"Plausible Realistic" look I'm seeking, but I have to admit I don't post much results.
So for the sake of illustration, here is one:
https://forum.reallusion.com/uploads/images/22232dbc-1781-49f4-9a16-03c2.png
I have used False Colors of course, to control the exposure, I'm also using the Highlight Desaturation LUT. Here is what the False Colors show:
https://forum.reallusion.com/uploads/images/0e9d201f-6a1e-4d5f-84d0-978c.png
As you can see I'm respecting the rules, there is no or barely white (clipped) area, there is no red (no information) area neither. The "ambient" lighting is high enough (but not too high) so there is a lot of details visible in the darker areas (light blue) and strong shadows are where they are needed (dark blue) thanks to the help given by Ambient Occlusion.
I like to think it works well in this "PBRish"/"Plausible Realistic" spirit. It is by no mean photorealistic, but neither "gamish"/"stylized", at least to me. And I like to believe that some peoples may think at first this is rendered with some kind of pathtracer like iRay. The impression won't last long through scrutiny of course but what's important is to "sell" the look quickly. Don't forget we are in the context of doing movies here, not still images. So what's really count is the action and characters performance. And if the look is plausible enough to not disturb the audience then that would be a win to me. At least that's my strategy.
By the way, the character shown here is an old one, not a CC3.2 + DHS one, so he only has "PBR" materials and can and will be improved a lot.
Also, the image is not artistically "Color Graded", it is just correctly exposed, right from the camera.
Anyway, I really would like to have your feedback about this
"PBRish"/"Plausible Realistic" spirit and approach, do not hesitate to comment.
Perhaps you think it is not realistic enough, that's fine with me and we can discuss it. Or perhaps not stylized enough.
Or it is something in between that would work ok or on the contrary perhaps disturb the audience ?
In any case, feel free to share your thoughts and arguments, I don't bite ;)
mtakerkart
mtakerkart
Last Active: 3 Months Ago
Posts: 3.2K, Visits: 29.2K
Very cool Guy . May you can make a 15 sec video render with some camera dolly and a new cc3 character whit idle motion ?
sonic7
sonic7
Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)
Posts: 1.7K, Visits: 19.4K
Hi Guy .... Your approach certainly retains detail from highlights right through to the low-light areas - and has a distinctive look. I think it's a personal taste thing. Expanding your range (0-255) to occupy 14-250, (as a reference - of what I'm more 'used to') and comparing before and after, I'd say yours somehow has a more 'cinematic' feel, whereas the 14-250 although 'punchier' is now somewhat more 'video-like'.
https://forum.reallusion.com/uploads/images/b4b11512-423f-463b-b71a-9d86.png
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :(  - yikes! ...
MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram iClone-7.93  3DXChange Pipeline 7.81  CC-3 Pipeline 3.44  Live Face  HeadShot  Brekel Pro-Body  Popcorn FX  iRAY  Kinect V2  DaVinci Resolve17  Mixcraft 8.1
3
