Exposure With False Colors
Posted By GOETZIWOOD STUDIOS 7 Years Ago
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)
Posts: 1.2K, Visits: 7.2K
Hi,
Nowadays, movies Directors of Photography use more and more what is called "False Colors" in order to control and set the camera exposure. They barely use light meters anymore for this, only for checking contrast on their subjects from different light sources.
With digital cameras you can directly see in realtime what the sensor is capturing so it is easy to make some adjustments directly by looking at that result, False Colors being a way to be more precise than doing it just by "eye". This is also a way to decouple exposure "values" from specifics from the camera (ISO or rather Gain, Aperture, Shutter, ND filters, ..) to a normalized 0% to 100% range (you will see sometime the term IRE but this is nothing more than percentage really). If you light an object to be in the 20% to 30% range, it will look the same, ultimately, whatever combinaison of Gain, Aperture, Shutter you set on different camera (in terms of exposure that is).
Using False Color is nothing more than applying a colored gradient to the luminosity of your image. So you can have red near black areas and yellow or white near the brightest areas. Here is one I made in Photoshop:
https://forum.reallusion.com/uploads/images/2e69e25a-66d7-438b-b516-5dbe.jpg
Colors from left to right will be applied on your image areas from full dark to full bright.This gradient one is a bit more complicated than a simple gradient.
Notice there is a middle range that has a kind of brownish gradient of color. This is what we call the Skintone range and it is supposed to show where should be exposed your subject (face) to be correctly exposed while maintaining sufficient space for informations above (lighter) and below (darker). This is obviously relatively subjective and each DP has his preferences (depending on the quality of the camera sensor, its "color science" and obviously its dynamic range). I chosen mine to be between 20% and 60% which is a bit wide (you will usually see 50% to 70% in movies) but this is due to the very limited dynamic range of what we get from the iClone renderer without proper Tone Mapping.
Notice there are also extreme areas, on the left (red) and right (white), kind of a safeguard zones. You don't want to have 0 information in some areas of your image nor clipped informations (except on purpose like lights and some reflection highlights).
So what do I do with that gradient ? I've created a special effect LUT for iClone so I can apply this gradient directly to the final image. Download the attached FalseColors_20-60.rar file that contains a FalseColors_20-60.iEffect file and put it in your effect template.
Now lets try it in iClone. Load the sample PRB Materials project and go to the frame 1640:
https://forum.reallusion.com/uploads/images/30213335-35ca-4e0e-824e-e959.jpg
Go to the Visual -> Effect Tab and remove the 2 default ColorAdjust effects. Then load the iEffect you got from here. Activate only the "FalseColors_20-60 effect, you should now see something like that:
https://forum.reallusion.com/uploads/images/3d30c76e-06d9-4115-b72f-43e3.jpg
We can clearly see there are white and yellow on some critical areas on the dummy material objects that shows those are overexposed.
We will try to start from scratch, disable the IBL light and the 3 scene lights, then I like to start with the "ambient" lighting by playing with the IBL strength so that there are information in the dark areas, try to remove reds but not too much strength, just so we start to see the skintone in some places:
https://forum.reallusion.com/uploads/images/68865444-bd0e-4030-b64d-521e.jpg
And if you deactivate the False Colors you should have something like that:
https://forum.reallusion.com/uploads/images/90c23f0c-73f7-408c-892d-aaab.jpg
And this is exactly what we want, an ambient lit scene without 0/red area. Now we can play with the scene Key light, Rim and Fill lights until we get something we like while being careful to not introduce too much yellow and avoid white area except where it makes sense (direct light and reflection highlights):
https://forum.reallusion.com/uploads/images/1ec15a51-861b-4b79-a583-80e8.jpg
And the resulting exposed image:
https://forum.reallusion.com/uploads/images/c7367a00-98e7-43e4-aee4-d65e.jpg
Now if you carefully compare this result with the first image after we opened the scene you will notice that we have been able to retrieve valid color information from the white dummy "iClone7_MaterialBall_04" that had large clipped areas in its high lit areas. Accordingly, we have retrieved valid color information from the yellow "iClone7_MaterialBall_07" that had large "burnt" areas in its high lit areas.
By using this False Color method to control the exposure of the rendering of our images we clearly see that we can precisely adjust any kind of combinaison and quantity of light sources (HDRI IBL Lights GI etc..) so the image will be perfectly exposed. No area with black value, no burnt nor clipped areas unless on purpose.
We really are "in control" and as such we can have consistent exposure from one shot to another one, from scene to scene.
Of course you are not obliged to use this particular LUT/Gradient, you can create your own that may better suit your style, as long as it protects you from absolute dark areas as well as burnt and clipped ones.
guy rabiller | GOETZIWOOD STUDIOS
"N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
FalseColors_20-60.rar (192 views, 134.00 KB)
Threaded View
Threaded View
Forum Post Exposure With False Colors By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post thx for that, i will give it a look , and talk about later By wildstar ( 7 Years Ago )
Forum Post Hello, GOETZIWOOD STUDIOS thank you for taking the time to make this... By Warped Reality VFX ( 7 Years Ago )
Forum Post @Kevin L Thanks for letting me know Kevin, You're welcome. By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post Thank you for this , Guy. I have been attempting to improve the... By animagic ( 7 Years Ago )
Forum Post @animagic You're very welcome Job, I'm glad this is helpful! By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post I often talk about this "PBRish"/"Plausible Realistic" look I'm... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post Very cool Guy . May you can make a 15 sec video render with some... By mtakerkart ( 7 Years Ago )
Forum Post Hi Guy .... Your approach certainly retains detail from highlights... By sonic7 ( 7 Years Ago )
Forum Post [quote][b]mtakerkart (12/6/2019)[/b][hr]../.. May you can make a 15... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post Hi Guy .... My point was simply to compare two ranges to see how your... By sonic7 ( 7 Years Ago )
Forum Post [quote][b]sonic7 (12/7/2019)[/b][hr] Hi Guy .... My point was simply... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post The motion blur's effect is certainly noticeable on the wall monitor... By sonic7 ( 7 Years Ago )
Forum Post [quote][b]sonic7 (12/7/2019)[/b][hr] The motion blur's effect is... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post Yeah, you'd be looking on a better monitor than me, plus yours is the... By sonic7 ( 7 Years Ago )
Forum Post Yeah - that last one looks good to me! - Interestingly, fyi, the 3... By sonic7 ( 7 Years Ago )
Forum Post [quote][b]sonic7 (12/7/2019)[/b][hr] Yeah - that last one looks good... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post Lol - yes 1/50 the size !!! But even so, that last one does look... By sonic7 ( 7 Years Ago )
Forum Post [quote][b]sonic7 (12/7/2019)[/b][hr] Lol - yes 1/50 the size !!! But... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post I sent the last video to Vimeo and the quality is definitely better.... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post Yes Guy, the Vimeo version definately looks better - the file size of... By sonic7 ( 7 Years Ago )
Forum Post @mtakerkart Sure. @sonic7 I'm not sure to follow you. I mean, what is... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post To properly conclude this topic, I wanted to do a "proper" version of... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post Hi and thanks for sharing this information, I've been playing around... By nealtucker ( 7 Years Ago )
Forum Post @nealtucker You're welcome. I'm glad you find it useful. By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post The same method in lighting and exposure can be applied with very... By GOETZIWOOD STUDIOS ( 7 Years Ago )
Forum Post Again great info, I would love you to do a video walkthrough of how... By nealtucker ( 7 Years Ago )
Forum Post [quote][b]nealtucker (12/12/2019)[/b][hr]Again great info, I would... By GOETZIWOOD STUDIOS ( 7 Years Ago )
