OFFICIAL iClone 6.01 Issues Thread
Posted By Peter (RL) 11 Years Ago
3
4
5
6
7
29
Posted 11 Years Ago
Hi Everyone,
iClone 6.01 has now been released along with the Indigo Plugin 1.01.
You can update using LiveUpdate, or from your Member Account under Patch/Bonus, or by going to Help > Check For Update in iClone 6.
IMPORTANT: If you have iClone 6 and Indigo RT, then you must update both iClone 6 to version 6.01 and the Indigo Plugin to version 1.01. If you don't update the Indigo Plugin, iClone 6 will not launch correctly.
Can you please post all issues, bugs, glitches, etc. that you find with the iClone 6.01 release here.
Of course feel free to post general feedback in your own threads but it will be great if we can keep outstanding issues and bugs here in this official thread. It will make it easier for the development team to track any outstanding problems and get them fixed quickly.
Please do try to provide your full system specs and a description of the problem when posting issues as this will help greatly. If you can provide step by step information so we can repeat the problem even better.
Thanks.
v6.01 (6.01.1312.1) released 12th January-15
Added:
  • "Non-DRM Content" folder under "Not Installed" folder for early content pack in Pack Template of Content Manager.
  • Accurate function for transforming by holding down the shift key while using traditional iClone gizmo (Ctrl+Q).
  • iClone 6 Standard official released.
  • "Reset" function for Edit Motion Layer in non-human character.
  • "Ctrl + K" hotkey for Duplicate function.
  • Additional Indigo parameters in Indigo Settings:
    • Tone Mapping
    • Align Indigo light to iClone light
    • Supersampling Factor
  • Added Global settings for Facial Expression & Viseme Strength.
  • Added world/local switch for physics initial force.
Enhanced:
  • Insert Frame performance in timeline editing.
  • Update the default Grid color in preference settings.
  • Interface Visual Enhancement:
    • Fixed some visual defects for small font interface.
    • Reduced color saturation in toolbar divider for gray color theme.
  • Content Enhancement: Optimized default values for following content:
    • Sky tool props
    • Tessellation template props
    • Flag Props in Softcloth
Fixed:
  • Fixed: Some early content cannot be loaded into iClone 6.
  • Fixed: Content pack view miss displaced because of pack name using special character (e.g. Machines of War using "/").
  • Fixed: Content Manager input string in Search box and the item's tips displayed Content ID in Pack Template.
  • Fixed: Pack View shows .ink file extension name on content items in Content Manager.
  • Fixed: Warning message for removing animation when opening the Proportion edit tool even for characters without animation.
  • Fixed: Break viseme clip caused possible crash.
  • Fixed: Modifier button not disabled when motion clip is not selected.
  • Fixed some behavior defects for all spin buttons:
    • Fixed: Value not updated correctly
    • Fixed: Input incorrect value in textbox, doesn't auto-convert to correct
    • Fixed: Values now max out at 360 (e.g. value 360, press up spin button became 1)
  • Fixed: Constraint button not disabled when parent constraint is cancelled.
  • Fixed: Dragging a .sbsar file from Explorer to 3D view does not successfully add Substance material.
  • Fixed: Cutting and pasting a video clip adds key to the timeline.
  • Fixed: Frame rate disabled in some condition when exporting image sequences.
  • Fixed: When changing voice clip speed, wave view was not updating correctly.
  • Fixed: Switching from world to local in transform movement didn't work in Edit Path mode.
  • Fixed: When exiting planting mode for tree or grasses, mouse cursor didn't update properly.
  • Fixed: Creating a Script from the Menu and choosing a .wav format caused crashes in certain environments.
  • Fixed: Mirror function didn't work correctly in Facial Feature Detail Settings.
  • Fixed: Voice and lips not synced when using 50% speed recording in Face Puppet.
  • Fixed: Switching the Bound Axis caused possible crash when adjusting character collision shape.
  • Fixed: Value back to default when adjusting Diagonal parameter for a particle object once play and stop.
  • Fixed: Possible crash while selecting outer control point for Right/Left Face in Facial Feature Detail Settings, with Mirror option checked.
  • Fixed: Substance texture size stays at 1024x1024 after being baked.
  • Fixed: Indigo rendering for some basic shapes (e.g. Cylinder) causes visual defects.
  • Fixed: Substance objects would occasionally disappear when rendering with Indigo.
  • Fixed: Indigo rendering failed when rendering an .igq file for the first time.
Alien Maniac
Alien Maniac
Posted 11 Years Ago
Posts: 693, Visits: 2.1K
Update patches installed. So, IC6 loads faster. While working with particles...... turning off/on emitter settings leads to a program green screen. Hu? Also does this when I am in the Scene settings menu clicking show/hide particle. Either does not hide or make it invisible. This did not happen before the update patchs.
Note: appears only to happen with particles.
I am currently rendering a scene in Indigo RT plugin......I will see if all is ok or?
MSI GT683DX Win 7 hp 64bit quad core
i7 2670 QM CPU
2.2 Ghz 16GB Ram HD 750GB and 1TB external
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram,  2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor  External data drives total 7 TB. and an AUDIO Studio Recording system.
pompel_4
pompel_4
Posted 11 Years Ago
Posts: 87, Visits: 199
after updating - DRM routin, then crash - "app Iclone stopped working".
brand468
brand468
Posted 11 Years Ago
Posts: 231, Visits: 7.8K
Tried to install update 6.01.1312.1 but after a crash I cant start iClone.
After the long verification of the DRM content, iClone crash.
Message comes up "iClone AP has stopped working"
Tried reeboot but same problem.
My computer: Intel i7-7700K 4.2Hhz 64Gb, Windows 10, GeForce GTX 1080 + GeForce GTX 1070, Phillips monitor 40" 4K  3840x2160 + 2x28"
brand468
brand468
Posted 11 Years Ago
Installed the iClone Render Plugin 101 patch, and now iClone works with 6.01 patch :)
jann
jann
Posted 11 Years Ago
Posts: 146, Visits: 4.5K
brand468 (1/12/2015)
Same here. Installing the Indigo plugin patch solved the problem.
pompel_4
pompel_4
Posted 11 Years Ago
Same here. Also installed the Indigo plugin patch and solved the problem.
Agonos
Agonos
Posted 11 Years Ago
Last Active: 7 Years Ago
Posts: 1.1K, Visits: 3.1K
After the same crash, I went to download the patch "iClone_Render_Plugin_101_Patch" available from my accountin the "Patch / Bonus" section. Now everything works again normally. Old projects even loadable without causing crash now. But we still can not change the faces of IC6 avatars ("Create face" is absent). And I still have problems with the "Glare".
Whatever the type that I have chosen, I have a line diagonally.
https://www.youtube.com/watch?v=Jt-Pr8y1fRA&feature=youtu.be
Windows 8.1 ‎(X64)‎
Intel Core i5 4670K 3.40 GHz
Socket: Socket 1150 LGA
Mother card MSI Z87-G45 GAMING (MS-7821) 1.0
14 Go DDR3
GPU NVIDIA GeForce GTX 770
pumeco
pumeco
Posted 11 Years Ago
Distinguished Member (6.2K reputation)Distinguished Member (6.2K reputation)Distinguished Member (6.2K reputation)Distinguished Member (6.2K reputation)Distinguished Member (6.2K reputation)Distinguished Member (6.2K reputation)Distinguished Member (6.2K reputation)Distinguished Member (6.2K reputation)Distinguished Member (6.2K reputation)
Group: Banned Members
Last Active: 9 Years Ago
Posts: 1.3K, Visits: 3.2K
Is the update available for those using the Trial version?
I can't find a way to update it or download it.
giannigodi
giannigodi
Posted 11 Years Ago
Veteran Member (924 reputation)Veteran Member (924 reputation)Veteran Member (924 reputation)Veteran Member (924 reputation)Veteran Member (924 reputation)Veteran Member (924 reputation)Veteran Member (924 reputation)Veteran Member (924 reputation)Veteran Member (924 reputation)
Posts: 25, Visits: 583
After last patch installation: iC 6.01,1312.1 and Indigo plugin patch, iClone 6 does not crash any more. Tks very much :D
My computer: Intel i7-3770 3.4Hhz 16Gb RAM, Windows 7 ultimate, GeForce GTX 660
3
4
5
6
7
29
