OFFICIAL iClone 6.01 Issues Thread
Posted By Peter (RL) 11 Years Ago
Posted 11 Years Ago
Posts: 23.1K, Visits: 36.6K
Hi Everyone,
iClone 6.01 has now been released along with the Indigo Plugin 1.01.
You can update using LiveUpdate, or from your Member Account under Patch/Bonus, or by going to Help > Check For Update in iClone 6.
IMPORTANT: If you have iClone 6 and Indigo RT, then you must update both iClone 6 to version 6.01 and the Indigo Plugin to version 1.01. If you don't update the Indigo Plugin, iClone 6 will not launch correctly.
Can you please post all issues, bugs, glitches, etc. that you find with the iClone 6.01 release here.
Of course feel free to post general feedback in your own threads but it will be great if we can keep outstanding issues and bugs here in this official thread. It will make it easier for the development team to track any outstanding problems and get them fixed quickly.
Please do try to provide your full system specs and a description of the problem when posting issues as this will help greatly. If you can provide step by step information so we can repeat the problem even better.
Thanks.
v6.01 (6.01.1312.1) released 12th January-15
Added:
  • "Non-DRM Content" folder under "Not Installed" folder for early content pack in Pack Template of Content Manager.
  • Accurate function for transforming by holding down the shift key while using traditional iClone gizmo (Ctrl+Q).
  • iClone 6 Standard official released.
  • "Reset" function for Edit Motion Layer in non-human character.
  • "Ctrl + K" hotkey for Duplicate function.
  • Additional Indigo parameters in Indigo Settings:
    • Tone Mapping
    • Align Indigo light to iClone light
    • Supersampling Factor
  • Added Global settings for Facial Expression & Viseme Strength.
  • Added world/local switch for physics initial force.
Enhanced:
  • Insert Frame performance in timeline editing.
  • Update the default Grid color in preference settings.
  • Interface Visual Enhancement:
    • Fixed some visual defects for small font interface.
    • Reduced color saturation in toolbar divider for gray color theme.
  • Content Enhancement: Optimized default values for following content:
    • Sky tool props
    • Tessellation template props
    • Flag Props in Softcloth
Fixed:
  • Fixed: Some early content cannot be loaded into iClone 6.
  • Fixed: Content pack view miss displaced because of pack name using special character (e.g. Machines of War using "/").
  • Fixed: Content Manager input string in Search box and the item's tips displayed Content ID in Pack Template.
  • Fixed: Pack View shows .ink file extension name on content items in Content Manager.
  • Fixed: Warning message for removing animation when opening the Proportion edit tool even for characters without animation.
  • Fixed: Break viseme clip caused possible crash.
  • Fixed: Modifier button not disabled when motion clip is not selected.
  • Fixed some behavior defects for all spin buttons:
    • Fixed: Value not updated correctly
    • Fixed: Input incorrect value in textbox, doesn't auto-convert to correct
    • Fixed: Values now max out at 360 (e.g. value 360, press up spin button became 1)
  • Fixed: Constraint button not disabled when parent constraint is cancelled.
  • Fixed: Dragging a .sbsar file from Explorer to 3D view does not successfully add Substance material.
  • Fixed: Cutting and pasting a video clip adds key to the timeline.
  • Fixed: Frame rate disabled in some condition when exporting image sequences.
  • Fixed: When changing voice clip speed, wave view was not updating correctly.
  • Fixed: Switching from world to local in transform movement didn't work in Edit Path mode.
  • Fixed: When exiting planting mode for tree or grasses, mouse cursor didn't update properly.
  • Fixed: Creating a Script from the Menu and choosing a .wav format caused crashes in certain environments.
  • Fixed: Mirror function didn't work correctly in Facial Feature Detail Settings.
  • Fixed: Voice and lips not synced when using 50% speed recording in Face Puppet.
  • Fixed: Switching the Bound Axis caused possible crash when adjusting character collision shape.
  • Fixed: Value back to default when adjusting Diagonal parameter for a particle object once play and stop.
  • Fixed: Possible crash while selecting outer control point for Right/Left Face in Facial Feature Detail Settings, with Mirror option checked.
  • Fixed: Substance texture size stays at 1024x1024 after being baked.
  • Fixed: Indigo rendering for some basic shapes (e.g. Cylinder) causes visual defects.
  • Fixed: Substance objects would occasionally disappear when rendering with Indigo.
  • Fixed: Indigo rendering failed when rendering an .igq file for the first time.
Threaded View
Threaded View
Forum Post OFFICIAL iClone 6.01 Issues Thread By Peter (RL) ( 11 Years Ago )
Forum Post Update patches installed. So, IC6 loads faster. While working with... By Alien Maniac ( 11 Years Ago )
Forum Post after updating - DRM routin, then crash - "app Iclone stopped... By pompel_4 ( 11 Years Ago )
Forum Post Tried to install update 6.01.1312.1 but after a crash I cant start... By brand468 ( 11 Years Ago )
Forum Post Installed the iClone Render Plugin 101 patch, and now iClone works... By brand468 ( 11 Years Ago )
Forum Post [quote][b]brand468 (1/12/2015)[/b][hr]Installed the iClone Render... By jann ( 11 Years Ago )
Forum Post Same here. Also installed the Indigo plugin patch and solved the... By pompel_4 ( 11 Years Ago )
Forum Post After the same crash, I went to download the patch... By Agonos ( 11 Years Ago )
Forum Post [quote][b]Agonos (1/12/2015)[/b][hr]After the same crash, I went to... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (1/13/2015)[/b][hr] The G6 characters are... By Agonos ( 11 Years Ago )
Forum Post After updating iclone 6 and the Indingo Plugin i got this... By hj ( 11 Years Ago )
Forum Post [quote][b]Agonos (1/13/2015)[/b][hr][quote][b]Peter (RL)... By Soya_RL ( 11 Years Ago )
Forum Post [quote][b]soyasu (1/15/2015)[/b][hr] Dear Agonos, The Glare Type of... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (1/15/2015)[/b][hr][quote][b]soyasu... By Soya_RL ( 11 Years Ago )
Forum Post Is the update available for those using the Trial version? I can't... By pumeco ( 11 Years Ago )
Forum Post [quote][b]pumeco (1/12/2015)[/b][hr] Is the update available for those... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (1/13/2015)[/b][hr][quote][b]pumeco... By pumeco ( 11 Years Ago )
Forum Post After last patch installation: iC 6.01,1312.1 and Indigo plugin patch,... By giannigodi ( 11 Years Ago )
Forum Post Hi Peter (RL). Thank you very much for 6.01. Corrected, I'm... By menro28 ( 11 Years Ago )
Forum Post I don't know if I am the only person with this problem but I cannot... By Bigboss ( 11 Years Ago )
Forum Post [quote][b]Bigboss (1/12/2015)[/b][hr] Reallusion Support suggested... By Soya_RL ( 11 Years Ago )
Forum Post Thanks soyasu, I have iC6.01 working now but I still cannot install... By Bigboss ( 11 Years Ago )
Forum Post [quote][b]Bigboss (1/13/2015)[/b][hr]Thanks soyasu, I have iC6.01... By Soya_RL ( 11 Years Ago )
Forum Post Hello Big Boss, I have the same problem as yourself, I've literally... By kenmatthews ( 11 Years Ago )
Forum Post Hi!!! indigo tab: export size: nothing comes out. tracing... By menro28 ( 11 Years Ago )
Forum Post [quote][b]menro28 (1/12/2015)[/b][hr]Hi!!! indigo tab: export... By Keith_MPS ( 11 Years Ago )
Forum Post [quote][b]gnasche (1/13/2015)[/b][hr][quote][b]menro28... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (1/13/2015)[/b][hr][quote][b]gnasche... By Soya_RL ( 11 Years Ago )
Forum Post [quote][b]soyasu (1/13/2015)[/b][hr][quote][b]animagic... By Keith_MPS ( 11 Years Ago )
Forum Post Today is day 4 of the same problem with the update. Just received... By jack-london ( 11 Years Ago )
Forum Post [quote][b]jack-london (1/15/2015)[/b][hr]"The system cannot find the... By justaviking ( 11 Years Ago )
Forum Post [quote][b]jack-london (1/15/2015)[/b][hr]Today is day 4 of the same... By Soya_RL ( 11 Years Ago )
Forum Post hi , same here (no option). But you can tweak inside indigo ;) All... By Sen ( 11 Years Ago )
Forum Post Ok a small update... To see the indigo patch in your bonus-patch... By Bigboss ( 11 Years Ago )
Forum Post [quote][b]Bigboss (1/12/2015)[/b][hr]Ok a small update... To see the... By Peter (RL) ( 11 Years Ago )
Forum Post Patch seems to be good with me so far...[b]But[/b] ...looks like... By mark ( 11 Years Ago )
Forum Post [quote][b]mark (1/13/2015)[/b][hr]Patch seems to be good with me so... By Soya_RL ( 11 Years Ago )
Forum Post And wouldn't it be a good idea to have the "Remove All Animation"... By mark ( 11 Years Ago )
Forum Post 1-12-2015 I have iClone 6.0 / Indigo RT. Downloaded and udated... By jack-london ( 11 Years Ago )
Forum Post [quote][b]jack-london (1/13/2015)[/b][hr]1-12-2015 I have iClone 6.0... By justaviking ( 11 Years Ago )
Forum Post [quote][b]jack-london (1/13/2015)[/b][hr]1-12-2015 I have iClone... By Soya_RL ( 11 Years Ago )
Forum Post I believe this was reported before, but HDR does not work correctly... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (1/13/2015)[/b][hr]I believe thiswas reported... By Keith_MPS ( 11 Years Ago )
Forum Post [quote][b]gnasche (1/13/2015)[/b][hr][quote][b]animagic... By animagic ( 11 Years Ago )
Forum Post After installing the new IC6 patch, and the Indigo patch and launching... By james_muia ( 11 Years Ago )
Forum Post This is something else, I reported previously. I really like the face... By animagic ( 11 Years Ago )
Forum Post One more for the today: the render quality setting for video (MP4,... By animagic ( 11 Years Ago )
Forum Post Level of Detail BUG !!! [u]In Preference setting[/u], If I check LoD... By Jen Arrow ( 11 Years Ago )
Forum Post [quote][b]Jen Arrow (1/13/2015)[/b][hr]Level of Detail BUG !!! [u]In... By Soya_RL ( 11 Years Ago )
Forum Post Hi Peter, I have a question regarding content directory import to... By LeeHounshell ( 11 Years Ago )
Forum Post [quote][b]LeeHounshell (1/13/2015)[/b][hr]Hi Peter, I have a... By Soya_RL ( 11 Years Ago )
Forum Post Thank you! I was able to make it work. By LeeHounshell ( 11 Years Ago )
Forum Post Look At Camera Set Free is not functioning [b]at all[/b] [center]... By Cricky ( 11 Years Ago )
Forum Post [quote][b]Cricky (1/13/2015)[/b][hr]Look At Camera Set Free is not... By Soya_RL ( 11 Years Ago )
Forum Post @justaviking: Thank you !! @wires: Thank you !! Thanks RL for the... By Supergerry ( 11 Years Ago )
Forum Post @hj, Just go to your account and enter - copy & paste - the serial... By wires ( 11 Years Ago )
Forum Post hi Gerry thank you :):):) i forgot it :crying::crying::crying: ... By hj ( 11 Years Ago )
Forum Post Iclone to Indigo Export bug that forces Iclone to crash has not been... By sbaerman ( 11 Years Ago )
Forum Post [quote][b]sbaerman (1/13/2015)[/b][hr]Iclone to Indigo Export bug that... By justaviking ( 11 Years Ago )
Forum Post the bug that makes clone crash in more complex scenes. Iclone plugin... By sbaerman ( 11 Years Ago )
Forum Post Nice job on the patch, RL team! This patch improved the general speed... By VegFile ( 11 Years Ago )
Forum Post well so much for that, i downloaded the patch and the indigo update... By redrubyslippers ( 11 Years Ago )
Forum Post [quote][b]redrubyslippers (1/13/2015)[/b][hr]well so much for that, i... By Soya_RL ( 11 Years Ago )
Forum Post Yesterday I received the live update of iClone6 and the Indigo Render... By pinguintje ( 11 Years Ago )
Forum Post I just wanted to report that I just downloaded the Indigo update and... By theschemer ( 11 Years Ago )
Forum Post Strange Shadows if you use hats :w00t: (Yes, they are 2 Sided) Issue... By RB3006 ( 11 Years Ago )
Forum Post First the good thing: v6 now loads my most important v5 project. Fine!... By madicloner ( 11 Years Ago )
Forum Post I don't think that shadow problem is new with iC6 Robert. I had to... By mark ( 11 Years Ago )
Forum Post Hi Sovasu, THX for the reply but why the SpeedTree Letters... By Jen Arrow ( 11 Years Ago )
Forum Post [quote][b]Jen Arrow (1/14/2015)[/b][hr]Hi Sovasu, THX for the reply... By Soya_RL ( 11 Years Ago )
Forum Post Peter- I had 6.0 installed and never found any content even though I... By KenCoon ( 11 Years Ago )
Forum Post Ken, there are three downloads you need. If you go to your member page... By animagic ( 11 Years Ago )
Forum Post Yes and they said they had been installed in my iClone one just said... By KenCoon ( 11 Years Ago )
Forum Post Has anyone downloaded the content pack since the 6.01 update? Is it... By pumeco ( 11 Years Ago )
Forum Post @pumeco: I don't think there were any changes in the content pack. It... By animagic ( 11 Years Ago )
Forum Post I still don't have any content even though they have been downloaded... By KenCoon ( 11 Years Ago )
Forum Post [quote][b]kencoon7 (1/14/2015)[/b][hr]I still don't have any content... By theschemer ( 11 Years Ago )
Forum Post Thanks Job, looks like I misinterpreted the announcement in the... By pumeco ( 11 Years Ago )
Forum Post The image sequence frame rate is now adjustable, thank you! :w00t:... By animagic ( 11 Years Ago )
Forum Post When editing motion layers it would be very beneficial to drag the... By DELETED2 ( 11 Years Ago )
Forum Post Not funny. I have just bought a new computer for this and have been... By KenCoon ( 11 Years Ago )
Forum Post Ken, Did you ever get your password sorted out and are able to... By theschemer ( 11 Years Ago )
Forum Post ... By DELETED2 ( 11 Years Ago )
Forum Post [quote][b]Armstrong (1/14/2015)[/b][hr] ... By theschemer ( 11 Years Ago )
Forum Post I am on kindle now. I found out it only does this on the forum. I... By KenCoon ( 11 Years Ago )
Forum Post So did you try going to the help drop down menu in iClone 6 and click... By theschemer ( 11 Years Ago )
Forum Post I will have to check that in the morning. I am not near the computer... By KenCoon ( 11 Years Ago )
Forum Post [quote][b]KenCoon (1/14/2015)[/b][hr]I will have to check that in the... By theschemer ( 11 Years Ago )
Forum Post @pumeco totally agree with both your interventions. No frame rate... By Draian63 ( 11 Years Ago )
Forum Post [b]@Job[/b] Yup, same here, frame rate is greyed out for AVI now.... By pumeco ( 11 Years Ago )
Forum Post [quote][b]pumeco (1/14/2015)[/b][hr] [b]@Job[/b]I'm curious to know... By animagic ( 11 Years Ago )
Forum Post In preference (ctrl + p), IC6 (in custom mode of course) is unable to... By Agonos ( 11 Years Ago )
Forum Post Time Line Switcher does not match when the name is changed in the... By Cricky ( 11 Years Ago )
Forum Post [quote][b]Cricky (1/14/2015)[/b][hr]Time Line Switcher does not match... By justaviking ( 11 Years Ago )
Forum Post [quote][b]Cricky (1/14/2015)[/b][hr]Time Line Switcher does not match... By Soya_RL ( 11 Years Ago )
Forum Post This is only conditional an issue - but we need it badly, if the physX... By madicloner ( 11 Years Ago )
Forum Post I FEEL STUPID. The content was there all the time. I had to click... By KenCoon ( 11 Years Ago )
Forum Post 3dxpro and Iclone 6 issue. Installed Iclone 6 then installed... By hattori kun ( 11 Years Ago )
Forum Post [quote][b]hattori kun (1/15/2015)[/b][hr]3dxpro and Iclone 6 issue.... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (1/15/2015)[/b][hr]Unfortunately, it has been... By justaviking ( 11 Years Ago )
Forum Post I don't remember this being reported in the "Issues" thread yet (6.0... By justaviking ( 11 Years Ago )
Forum Post [quote][b]animagic (1/15/2015)[/b][hr][quote][b]hattori kun... By hattori kun ( 11 Years Ago )
Forum Post According to this you just need 3dxpro to import to Iclone 6.... By hattori kun ( 11 Years Ago )
Forum Post Modifying Facial Features in IC6 deletes animation. Not sure... By Galfridus ( 11 Years Ago )
Forum Post [quote][b]Galfridus (1/15/2015)[/b][hr] Modifying Facial Features in... By Soya_RL ( 11 Years Ago )
Forum Post [b]@Madicloner[/b] Check out the new request I made in the request... By pumeco ( 11 Years Ago )
Forum Post Than you Soyasu. Maybe it would be nice if Peter adds in the first... By Agonos ( 11 Years Ago )
Forum Post Creating speech with a .WAV file works for me. I've tested this with... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (1/15/2015)[/b][hr]Creating speech with a .WAV file... By justaviking ( 11 Years Ago )
Forum Post We can use the "wav" files with "iclone6" except those being... By Agonos ( 11 Years Ago )
Forum Post No uninstall on trialthat I can find wanted to install full version .... By nat woi ( 11 Years Ago )
Forum Post Version 6.01 crashes when I use "search" Version 6.00 search worked... By lpatter ( 11 Years Ago )
Forum Post Not sure whether this is a bug or whether I'm doing something wrong,... By pumeco ( 11 Years Ago )
Forum Post [quote][b]pumeco (1/16/2015)[/b][hr] Not sure whether this is a bug... By Cricky ( 11 Years Ago )
Forum Post In a discussion elsewhere on the board, Mark reported that he had... By animagic ( 11 Years Ago )
Forum Post Thank you for the prompt response Soya, concerning "bug" with deleted... By Galfridus ( 11 Years Ago )
Forum Post [quote][b]Galfridus (1/16/2015)[/b][hr] As expected, I noticed with... By Soya_RL ( 11 Years Ago )
Forum Post I have just created and characterized a Makehuman avatar, and need to... By Rampa ( 11 Years Ago )
Forum Post Still the bug exists, if you export longer frame scenes (20-80 frames)... By sbaerman ( 11 Years Ago )
Forum Post Not sure if this has been mentioned... If I go to modify collision... By namunger ( 11 Years Ago )
Forum Post [quote][b]namunger (1/16/2015)[/b][hr]Not sure if this has been... By madicloner ( 11 Years Ago )
Forum Post [quote][b]madicloner (1/17/2015)[/b][hr][quote][b]namunger... By Soya_RL ( 11 Years Ago )
Forum Post [quote][b]soyasu (1/19/2015)[/b][hr][quote][b]madicloner... By Rampa ( 11 Years Ago )
Forum Post [quote][b]namunger (1/16/2015)[/b][hr]Not sure if this has been... By elektron2kim ( 11 Years Ago )
Forum Post [b]Repeatable bug for Soft Cloth Dynamics:[/b] I think I know why... By pumeco ( 11 Years Ago )
Forum Post I haven't read all the problems and hope I'm not repeating a bug or... By rgreenidge ( 11 Years Ago )
Forum Post OK, I don't know if there is a reward for the weirdest bug, but I... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic It's a very small project, so I'm attaching it here... By Agonos ( 11 Years Ago )
Forum Post Animagic : Watch this video. The option "auto" triple shadows. In... By Agonos ( 11 Years Ago )
Forum Post [quote][b]Agonos (1/17/2015)[/b][hr]Animagic : Watch this video. The... By animagic ( 11 Years Ago )
Forum Post [b]@Job[/b] I think that's down to the way Shadows work in iClone... By pumeco ( 11 Years Ago )
Forum Post @Agonos: Thanks for trying. It is a ZIP file with an .iProject file in... By animagic ( 11 Years Ago )
Forum Post I was having a strange shadow artifact show up on a scene I was... By planetstardragon ( 11 Years Ago )
Forum Post [quote][b]planetstardragon (1/17/2015)[/b][hr]I was having a strange... By mark ( 11 Years Ago )
Forum Post [quote][b]mark (1/17/2015)[/b][hr][quote][b]planetstardragon... By planetstardragon ( 11 Years Ago )
Forum Post Animagic, now that my new computer stuff is working. Like you I wanted... By rgreenidge ( 11 Years Ago )
Forum Post The Search feature in the Content Tab is not so handy. I tried to find... By theschemer ( 11 Years Ago )
Forum Post Hello RL, I found the following problem. In the timeline I display... By RobertoColombo ( 11 Years Ago )
Forum Post .[quote][b]RobertoColombo (1/17/2015)[/b][hr]Hello RL, I found the... By wires ( 11 Years Ago )
Forum Post @rgreenidge: RL (Soya) monitors this thread, so it is a good place to... By animagic ( 11 Years Ago )
Forum Post theschemer: I have the same problem! I have to wait a long time... By Jen Arrow ( 11 Years Ago )
Forum Post Hi Gerry, damn... you are right!!! :) ... and now I understand how... By RobertoColombo ( 11 Years Ago )
Forum Post Ok... I try a new one... not sure it has already reported. 1. empty... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (1/18/2015)[/b][hr]Ok... I try a new one...... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (1/18/2015)[/b][hr][quote][b]RobertoColombo... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (1/18/2015)[/b][hr]I tried to right-click... By justaviking ( 11 Years Ago )
Forum Post Roberto: It's a bug ! I have the same problem... You can disable... By Jen Arrow ( 11 Years Ago )
Forum Post quote][b]soyasu (1/19/2015)[/b][hr][quote][b]animagic... By Agonos ( 11 Years Ago )
Forum Post [quote][b]Agonos (1/19/2015)[/b][hr]quote][b]soyasu... By justaviking ( 11 Years Ago )
Forum Post Strange Hat Shadow in iC6 .... (Hat is 2 sided) @ Mark ..... I did... By RB3006 ( 11 Years Ago )
Forum Post [quote][b]RB3006 (1/18/2015)[/b][hr]Strange Hat Shadow in iC6 ....... By Bellatrix ( 11 Years Ago )
Forum Post I can confirm Roberto's problem. The Set Free button remains... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (1/19/2015)[/b][hr]I can confirm Roberto's problem.... By justaviking ( 11 Years Ago )
Forum Post [quote][b]animagic (1/19/2015)[/b][hr]I can confirm Roberto's problem.... By Soya_RL ( 11 Years Ago )
Forum Post Viking: I'm running iClone 6.01 and i think that's the reason of the... By Jen Arrow ( 11 Years Ago )
Forum Post Default Pinned cloth example props in IC6. IC6 online help... By Galfridus ( 11 Years Ago )
Forum Post Something else _ Convert Position to Path - is not working. ... By Cricky ( 11 Years Ago )
Forum Post Hello all. Can't we copy and past a "path "? Why can not I delete my... By Agonos ( 11 Years Ago )
Forum Post [color="#DD5555"]|ISSUE| With Paint Toon Levels To Full White,... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post Can't render a project in IC 6.01 beyond default 1,800 frames. I... By Ron12345 ( 11 Years Ago )
Forum Post i wonder if that bug is related to a similar bug I was experiencing in... By planetstardragon ( 11 Years Ago )
Forum Post [quote][b]Ron12345 (1/20/2015)[/b][hr]Can't render a project in IC... By justaviking ( 11 Years Ago )
Forum Post @Ron: That is strange indeed. It seems you have all the right... By animagic ( 11 Years Ago )
Forum Post Hi Peter, I would like to post something but I just can't find how to... By DenLac ( 11 Years Ago )
Forum Post I have the exact same problem with it not rendering the amount of... By musicaz ( 11 Years Ago )
Forum Post Yes, there are special versions for querulant individuals...:P By animagic ( 11 Years Ago )
Forum Post i thought it was against the forums rules By musicaz ( 11 Years Ago )
Forum Post OK, I did a test tonight and was able to render a project longer than... By animagic ( 11 Years Ago )
Forum Post Indigo crashes all the time. I get a white screen, it freezes, and I... By pi-qui ( 11 Years Ago )
Forum Post [quote][b]pi-qui (1/21/2015)[/b][hr]Indigo crashes all the time. I get... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (1/21/2015)[/b][hr][quote][b]pi-qui... By wires ( 11 Years Ago )
Forum Post [quote][b]wires (1/21/2015)[/b][hr]Unless pi-qui has purchased Indigo... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (1/21/2015)[/b][hr][quote][b]wires... By wires ( 11 Years Ago )
Forum Post Animagic and Rampa have already recognized it right and I can also... By Postfrosch ( 11 Years Ago )
Forum Post Hi Postfrosch, Animagic, Rampa, and all, here is a work-around for... By RobertoColombo ( 11 Years Ago )
Forum Post [quote]Hi Postfrosch, Animagic, Rampa, and all, here is a... By Postfrosch ( 11 Years Ago )
Forum Post Yes, for sure they need to fix it. But at least we are not blocked... By RobertoColombo ( 11 Years Ago )
Forum Post I had my 1st IC6 crash ( finally... I was tired to have a working... By RobertoColombo ( 11 Years Ago )
Forum Post @Roberto, I've had good success with the "Restore" feature. I think... By justaviking ( 11 Years Ago )
Forum Post As to project length: the projects I'm working on in iClone 6 started... By animagic ( 11 Years Ago )
Forum Post @Dennis: I also do save quite often (right now at version 41 for the... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (1/22/2015)[/b][hr]@Dennis: I also do save... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (1/22/2015)[/b][hr][quote][b]RobertoColombo... By RobertoColombo ( 11 Years Ago )
Forum Post [color="#DD5555"]|BUG| iClone Fails To Properly Save Layouts With... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post Can't render beyond 1,899 frames Tech emailed that it is a bug to be... By Ron12345 ( 11 Years Ago )
Forum Post so I tak:sick::sick:e it.. 6.1 won't be coming soon.. I was so looking... By mr_vidius ( 11 Years Ago )
Forum Post My iClone 6.2 beta crashes when I click Soft vs Soft Collision. Does... By RB3006 ( 11 Years Ago )
Forum Post Edit Motion Layer window for Non-Human animation editing must have... By RobertoColombo ( 11 Years Ago )
Forum Post Deleting a range of frames from a project has the undesirable effect... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (1/25/2015)[/b][hr] I have also found that a very... By RobertoColombo ( 11 Years Ago )
Forum Post Bug found in IC6.02xxx: spring no longer works after resizing Avatar ... By Supergerry ( 11 Years Ago )
Forum Post Another for the "not a bug, but a missing crucial feature" pile... ... By namunger ( 11 Years Ago )
Forum Post [quote][b]namunger (1/27/2015)[/b][hr]Another for the "not a bug, but... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [quote][b]grabiller (1/27/2015)[/b][hr][quote][b]namunger... By namunger ( 11 Years Ago )
Forum Post [color="#DD5555"]|ISSUE| Animated Substances Do Not Animate In... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [color="#DD5555"]|ISSUE| IndigoRT Camera And iClone Camera Do Not... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [quote][b]grabiller (1/28/2015)[/b][hr][color="#DD5555"]|ISSUE|... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (1/28/2015)[/b][hr] REQUEST: Could you post... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post Thanks, Guy. For the record, I believed you. It's just nice to have... By justaviking ( 11 Years Ago )
Forum Post Same test as done by Guy with a standard project. iClone: Indigo... By wires ( 11 Years Ago )
Forum Post I think most of these bugs are listed but I will write them down just... By urbanlamb ( 11 Years Ago )
Forum Post Okay, I know that this is one of those "uh, dude, that's nice" issues... By jamesknine ( 11 Years Ago )
Forum Post [quote][b]jamesknine (1/29/2015)[/b][hr]However, iClone 6's text... By animagic ( 11 Years Ago )
Forum Post [quote] You could try that. I have not used it myself, so I don't... By jamesknine ( 11 Years Ago )
Forum Post [quote][b]jamesknine (1/29/2015)[/b][hr]Okay, I know that this is one... By JimmyB7 ( 11 Years Ago )
Forum Post [quote][b]JimmyB7 (1/30/2015)[/b][hr]"Mark In/Out of Playback/Export... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (1/30/2015)[/b][hr][quote][b]JimmyB7... By JimmyB7 ( 11 Years Ago )
Forum Post Hi, not sure if it has been already reported, but it seems that it... By RobertoColombo ( 11 Years Ago )
Forum Post I have an issue that I don't recall from before the patch and that is... By animagic ( 11 Years Ago )
Forum Post BUG FOUND IN IC6.02BETA: Deleting Motion from Bodyparts in the... By Supergerry ( 11 Years Ago )
Forum Post [quote][b]Supergerry (2/1/2015)[/b][hr]BUG FOUND IN IC6.02BETA:... By animagic ( 11 Years Ago )
Forum Post I`m missing the Autoblink --> Edit in 3dxchange button as contained in... By Supergerry ( 11 Years Ago )
Forum Post Hi, I found that several controls of the PARTICLE system have a... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (2/1/2015)[/b][hr]Hi, I found that several... By hestera ( 11 Years Ago )
Forum Post [quote][b]hestera (2/1/2015)[/b][hr][quote][b]RobertoColombo... By RobertoColombo ( 11 Years Ago )
Forum Post Convert Position to Path not working. In this post , user... By wires ( 11 Years Ago )
Forum Post [quote][b]wires (2/1/2015)[/b][hr] Convert Position to Path not... By Peter (RL) ( 11 Years Ago )
Forum Post Next BUG found (IC 6.02 BETA DX11): The GLOSSINESS slider in the... By Supergerry ( 11 Years Ago )
Forum Post [quote][b]Supergerry (2/1/2015)[/b][hr]Next BUG found (IC 6.02 BETA... By animagic ( 11 Years Ago )
Forum Post That's so funny I just found that mislabeled "Remove Motion" typo and... By mark ( 11 Years Ago )
Forum Post ... 2 right hands are still much better than two left hands ... :) ... By Supergerry ( 11 Years Ago )
Forum Post It would be good to have some feedback from RL about what reported... By animagic ( 11 Years Ago )
Forum Post REFRACTION bug Reflection bug is known, easily replicated, and... By Bellatrix ( 11 Years Ago )
Forum Post I just noticed this. It may only be me and my system but thought I'd... By mark ( 11 Years Ago )
Forum Post [quote]It may only be me and my system but thought I'd get it out... By vidi ( 11 Years Ago )
Forum Post Thanks vidi!!:D By mark ( 11 Years Ago )
Forum Post Hi Mark, I tried the same, with Mason, I can also confirm the... By RobertoColombo ( 11 Years Ago )
Forum Post That's good I guess!!:P :P Has anybody tried any other body-parts... By mark ( 11 Years Ago )
Forum Post I tried it with a regular walk forward and got the same results. The... By animagic ( 11 Years Ago )
Forum Post Thanks Job. That's kinda what I found out. Just need to keep iC5 close... By mark ( 11 Years Ago )
Forum Post Very Weird results here also, [b]however[/b], i tried it a second time... By nlprod1 ( 11 Years Ago )
Forum Post Found another bug (IC6.02BETA DX11): - Load a DAZ Genesis figure... By Supergerry ( 11 Years Ago )
Forum Post [color="#DD5555"]|CRASH| When Trying To Access Network Shared Folder... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [color="#DD5555"]|ISSUE| 3DXchange Sets Bump Maps As Normal Maps When... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post That drive me crazy, that I can not more easy select all Items... By vidi ( 11 Years Ago )
Forum Post The "Fishing net" n the "Softcloth Props" section of the "Phics Props"... By lpatter ( 11 Years Ago )
Forum Post [quote][b]lpatter (2/5/2015)[/b][hr]I am posting here just in case... By animagic ( 11 Years Ago )
Forum Post 2 odd behaviors of Materials that I'm not sure are bugs or just... By Bellatrix ( 11 Years Ago )
Forum Post [color="#DD5555"]|BUG| Loading Sub-Props Materials From Disk Corrupts... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [color="#55DD55"]|WISH| Ability To Save Rendered Image Sequences As... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [quote][b]grabiller (2/5/2015)[/b][hr][color="#55DD55"]|WISH| Ability... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (2/5/2015)[/b][hr][quote][b]grabiller... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [quote][b]animagic (2/5/2015)[/b][hr][quote][b]grabiller... By prabhatM ( 11 Years Ago )
Forum Post [quote][b]prabhatM (2/5/2015)[/b][hr][quote][b]animagic... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [quote][b]grabiller (2/5/2015)[/b][hr][quote][b]prabhatM... By prabhatM ( 11 Years Ago )
Forum Post [quote][b]prabhatM (2/5/2015)[/b][hr][quote][b]grabiller... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [quote][b]grabiller (2/5/2015)[/b][hr] Right, you mean even with... By prabhatM ( 11 Years Ago )
Forum Post If it helps, I must inform you that I have tested the patch "DX11 to... By Agonos ( 11 Years Ago )
Forum Post Duplicate while rotating does not work. Holding the CTRL key... By wires ( 11 Years Ago )
Forum Post [color="#DD5555"]|ISSUE| FPS Slider From iClone5 Export Is Missing In... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post BUG found (for me...): Material editor: - Select multiple mesh... By Supergerry ( 11 Years Ago )
Forum Post I found this problem (bug?) : whatever I individually change the X, Y,... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (2/5/2015)[/b][hr]I found this problem (bug?)... By animagic ( 11 Years Ago )
Forum Post I wonder about that too, Roberto. It was nice when we got feedback. I... By animagic ( 11 Years Ago )
Forum Post Hey Guys, did you know the main Forum for iC6 is still missing from... By Tarampa Studios ( 11 Years Ago )
Forum Post @Bleetz, The "iClone --> General" forum is the CURRENT version.... By justaviking ( 11 Years Ago )
Forum Post Just curious: what would the main part of the forum be about... By animagic ( 11 Years Ago )
Forum Post Crash, crash crash. I got tired of it, so I had to trouble shoot. Last... By rgreenidge ( 11 Years Ago )
Forum Post --- BUGS ---- Control + Z does not undo that far back when adding... By james_muia ( 11 Years Ago )
Forum Post @ James, [quote]Control + Z does not undo that far back when adding... By wires ( 11 Years Ago )
Forum Post 100 undo's. Which clearly doesn't work. By james_muia ( 11 Years Ago )
Forum Post BUG: UI Windows do not stay expanded, and re-position themselves to a... By james_muia ( 11 Years Ago )
Forum Post BUG: After iclone crashes, it asks you to restore. Once you choose a... By james_muia ( 11 Years Ago )
Forum Post [quote][b]james_muia (2/8/2015)[/b][hr]BUG: After iclone crashes, it... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (2/8/2015)[/b][hr][quote][b]james_muia... By justaviking ( 11 Years Ago )
Forum Post [quote][b]animagic (2/8/2015)[/b][hr][quote][b]james_muia... By james_muia ( 11 Years Ago )
Forum Post [quote][b]james_muia (2/8/2015)[/b][hr] Yes I see the message that the... By animagic ( 11 Years Ago )
Forum Post MOTION Addition There is a weird motion problem when adding more than... By lpatter ( 11 Years Ago )
Forum Post [quote][b]lpatter (2/10/2015)[/b][hr]MOTION Addition There is a weird... By duchess110 ( 11 Years Ago )
Forum Post Like James above I found that window resizing every time I open is a... By rgreenidge ( 11 Years Ago )
Forum Post Hi, not sure if already reported: when I add a .wav file... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (2/8/2015)[/b][hr]Hi, not sure if already... By mark ( 11 Years Ago )
Forum Post I'm waiting for the Reallusion team to possibly find a answer because... By rgreenidge ( 11 Years Ago )
Forum Post [quote][b]rgreenidge (2/8/2015)[/b][hr]I'm waiting for the Reallusion... By justaviking ( 11 Years Ago )
Forum Post This issue concerns a tool that is missing in iClone 6 Pro, the BVH... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (2/9/2015)[/b][hr]This issue concerns a tool that... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post I realize that. This is just for those iClone 6 Pro users that don't... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (2/9/2015)[/b][hr]I realize that. This is just for... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post So I have finished a model I was working on and alls good until I... By bluemidget666 ( 11 Years Ago )
Forum Post [quote][b]bluemidget666 (2/9/2015)[/b][hr] So I have finished a model... By Cricky ( 11 Years Ago )
Forum Post Hi Cricky Yep it has a hole under the top, I'll cap it and try... By bluemidget666 ( 11 Years Ago )
Forum Post Hello, this is an obvious bug and was on 01/22/15 already reported:... By Postfrosch ( 11 Years Ago )
Forum Post Hi Everyone, iClone 6.02 has now been officially... By Peter (RL) ( 11 Years Ago )
