markhammontree
markhammontree
Visits: 39
What was the fix for this issue? CC3 was working, I updated it to the latest patch and that error showed up. I removed CC3 and reinstalled, I have fresh install of iClone as well.
Thanks.
fromsouthgames
fromsouthgames
Visits: 222
@ mkibria I had the same issue. I solve it reinstaling goz for Zbrush
c68
Visits: 4.8K
I really hope this gets a fix in the next update! The offset when I reimport a piece of cloth from MD into CC3 makes it not really fun ... This is my Pipeline: 1. Export CC3 character in T-Pose as OBJ --> 2. Import OBJ as avatar to MD --> 3. Export Cloth as OBJ from MD --> 4. Create new Accessory in CC3 and load the exported OBJ Of course, you can manually correct the offset... but thats an extra step in the pipeline and not very precise... (if you have to redo it later...)
Tom4891
Tom4891
Visits: 220
When switching to "Skin" with activated editor the Makeup gets invisible. Is this really intended? Haven't worked with it much yet but intuitively I expected that I could have the option to have both active for better visualisation of the final look. 75% of original size (was 668x19) - Click to enlarge 75% of original size (was 668x19) - Click to enlarge
Tom4891
Tom4891
Visits: 220
Adding a second tattoo as an additional layer. Second tattoo layer does not appear in the list. No access to the second tattoo (or the following). 75% of original size (was 668x19) - Click to enlarge
Visits: 31.3K
When working on the skin, which can be quite subtle, you don't want the makeup to be in the way, that is why it is made invisible.
Jean-Sé
Jean-Sé
Visits: 4.1K
You need to change the material to « arm » instead of « head »
m.altajer93
m.altajer93
Visits: 52
Hello Everyone ,
Please If anyone can tell me the deference between the Standalone and 4 in one Bundle packages ? Its not clear I mean what I will get from Standalone package ?
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Please If anyone can tell me the deference between the Standalone and 4 in one Bundle packages ? Its not clear I mean what I will get from Standalone package ? I do not understand this question in connection with "4 in1 Bundle": What do you mean for a "stand-alone package"? CC3 Premium? This program has more functions than the CC 3 that is supplied free with Iclone
The 4 in 1 bundle contains the additional package for the CC 3.3 in connection with the new CC3 + avatars: - Ultimate morph -Realistic Human Skin - MakeUp + SFX as well as the "SkinGem Premium PlugIn" with which one has some additional features as opposed to the freely supplied SkinGen module.
You can / have to buy these packages if you buy the "Stand-Alone CC3 Premium" program
Greets from Germany Postfrosch
-------------------------------------------------------------- 75% of original size (was 668x19) - Click to enlarge
jackx1325
jackx1325
Visits: 34
I try to load an asset and failed to load comes up then the program freezes. The following error message appears forcing me to shutdown the program. 75% of original size (was 668x19) - Click to enlarge
