OFFICIAL Character Creator 3.3, 3.31 and 3.32 Issues Thread
Posted By Peter (RL) 5 Years Ago
13
14
15
16
17
19
Posts: 23.1K, Visits: 36.6K
Postfrosch (8/10/2020)
CC 3.3 does NOT delete the Skingen Temp files from the Temp folder after exiting the program.
Large amounts of files are left behind and have to be removed by hand (or CC Cleaner).
Operating system Win 10 (up to date)
Greets from Germany
Postfrosch
Hi Postfrosch... You can manually clear the cache from your CC3 Preferences. Please see the link below which shows where to find this option.
https://manual.reallusion.com/Character_Creator_3/ENU/3/Content/Character_Creator_3/3.3/04_Introducing_the_User_Interface/Dynamic-Texture-Editor-Section.htm
c68 (8/18/2020)
I really hope this gets a fix in the next update! The offset when I reimport a piece of cloth from MD into CC3 makes it not really fun ...
This is my Pipeline:
1. Export CC3 character in T-Pose as OBJ --> 2. Import OBJ as avatar to MD --> 3. Export Cloth as OBJ from MD --> 4. Create new Accessory in CC3 and load the exported OBJ
Of course, you can manually correct the offset... but thats an extra step in the pipeline and not very precise... (if you have to redo it later...)
Hi... Thanks for the feedback. This issue should be fixed in the next update due at the end of August.
c68
c68
Veteran Member (733 reputation)Veteran Member (733 reputation)Veteran Member (733 reputation)Veteran Member (733 reputation)Veteran Member (733 reputation)Veteran Member (733 reputation)Veteran Member (733 reputation)Veteran Member (733 reputation)Veteran Member (733 reputation)
Posts: 81, Visits: 4.8K
Great! Thanks for the info! :)
TopOneTone
TopOneTone
Posts: 329, Visits: 3.2K
I hope the update is coming really soon as I cannot use CC3 at all. I have checked all my drivers are up to date, reset the Nvidia settings back to factory default, uninstalled CC3 and re-installed but still I get the following :
75% of original size (was 671x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/96127957-27f7-408c-94ab-7136.pngII then try to open a project and get :
75% of original size (was 671x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/e623c2cb-c57b-4ce4-ba4a-07e8.png
which is then followed by
75% of original size (was 671x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/9acf639e-743e-4ebe-9290-0a4e.png
RLord321
RLord321
Senior Member (322 reputation)Senior Member (322 reputation)Senior Member (322 reputation)Senior Member (322 reputation)Senior Member (322 reputation)Senior Member (322 reputation)Senior Member (322 reputation)Senior Member (322 reputation)Senior Member (322 reputation)
Posts: 11, Visits: 97
Is there a way to revert back to CC3 version 3.22?  Ever since I upgraded to version 3.3, I can't create characters because of export/import issues into Unity or 99% of the time, it freezes on start up.  I used to like this product until now.
Postfrosch
Postfrosch
Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)
Posts: 6.9K, Visits: 18.4K
Hi Peter,
thnaks fpr your answer
Greets Postfrosch
75% of original size (was 671x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/cd9c9a06-21a5-44c5-9f67-6810.jpg
TopOneTone
TopOneTone
Finally think I have solved the issues I was having with iclone and CC3. Having checked the nvidia and windows drivers were current, reinstalled all the software, reset the nvidia controller to default settings and still I could not open a project in CC3 and iclone would not render.  I then decided to ignore some earlier advice, that was saying that in the nvidia control panel 3D settings ensure iclone and CC3 were set to "Application Controlled". I restored the Global Setting to default and then changed all the program settings for iclone and CC3 to "Use Global Setting (Off)" which instantly rectified my problems in both products.
Might not be the cure for all the current issues, but its certainly a very simple option to test and I wish I had tried it a week ago before I tried everything else.
Cheers,
Tony
RLord321 (8/31/2020)
We have the new 3.31 update coming very soon now (hopefully this week). This will likely resolve the issue you are having. If it doesn't, then please contact Technical Support who may be able to help with the 3.22 version. However, please be aware that any characters you have created or edited using 3.3 will no longer work in 3.22.
jfenwick89
jfenwick89
New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)
Posts: 3, Visits: 13
i am having the same issue. did you find a solution yet. i have a thumbnail preview on the toolbar but the program wont open to use. also unable to close out prompt unless using task manager. also running 2080 TI/ AMD 3700x and 128 GB
jfenwick89
jfenwick89
 I HAVE FULLY DOWNLOADED THE ULTIMATE PIPELINE 4-1 version 3.3 AND WHEN ATTEMPTING TO OPEN CC3 IT WILL FLASH AND SHOW A THUMBNAIL ON THE TOOLBAR AND ABLE TO PREVIEW WHEN HOVERED OVER. CANNOT CLOSE OUT THUMBNAIL WITHOUT TASK MANAGER. I HAVE ROLLBACKED MY DRIVERS AS FAR AS POSSIBLE WITH THE NVIDIA 2080 TI. UNINSTALLED AND REINSTALLED PROGRAM. THE PROBLEM CONTINUALLY FLASHES AND WILL NOT OPEN FOR ME TO USE. HAS ANYONE CAME ACROSS THIS PROBLEM OR HAVE ANY SOLUTIONS?
13
14
15
16
17
19
