SLIDING FEET! Halp!
Posted By Devdevdev 5 Years Ago
SLIDING FEET! Halp!
Devdevdev
Devdevdev
Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)
Posts: 12, Visits: 87
Hi! Getting a little frustrated here, hoping for a solid explaination or best practice.
EDITED 4.25.2020*****    https://youtu.be/05d01pBx74A     **********
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^example youtube video
I have been animating with iClone since about 2015 to create animation loops for 2D fighting games.
This issue I am about to explain has come and gone and I don't understand why some updates I have this issues and then other updates the problem is gone.
Current Version: iClone 7.72.3818.1
PROCESS:
I import my custom character that uses the iClone standard animation rig ( iAvatar or CC3 Character Creator file directly exported to iC7)
I select the character and press 'N' to dial up 'Edit Motion Layer'.
I left click the LOCK icons adjacent to the feet (ankles?)
After turning the LOCKs on, I click on the 'hip bone' and I either do a soft rotation (press E) or move hip position on z,x,y axis (press 'W')
Using the options listed above I make very soft movement adjustments to hip rotation and hip's Z position to create an animation loop (Think standing Idle stance)
PROBLEM:
The feet on the animation loop slide around instead of staying stationary.
This has come and gone with different updates in iClone 6 or 7 and I would love to know why and how I can end this problem. My process hasn't changed but something has in the appliaction
Thanks!!! :)
Ps: Perfect world, it would be great if we could dial into the actual x,y,z, coordinates via the UI and just copy the position of said bone and apply it to desired frames.
If I am an idiot and have missed a glaring option, please, call me out!
:D
Threaded View
Threaded View
Forum Post SLIDING FEET! Halp! By Devdevdev ( 5 Years Ago )
Forum Post [quote][b]X-MiGuPLAY (4/24/2020)[/b][hr]Hi! Getting a little... By videodv ( 5 Years Ago )
Forum Post Thanks Chris - I don't think you understood exactly what is happening.... By Devdevdev ( 5 Years Ago )
Forum Post just replying to your comment to be sure you get a notification. I... By Devdevdev ( 5 Years Ago )
Forum Post When you first open the Edit Motion Layer panel, the feet are locked... By Rampa ( 5 Years Ago )
Forum Post Here's the video https://youtu.be/05d01pBx74A By Devdevdev ( 5 Years Ago )
Forum Post When this issue becomes overly annoying and well over the level I can... By 4u2ges ( 5 Years Ago )
Forum Post Thanks for the link! By Devdevdev ( 5 Years Ago )
Forum Post Someone posted the solution and then deleted the comment - or atleast,... By Devdevdev ( 5 Years Ago )
Forum Post Did you ever figure out how to fix the sliding feet issue? I’m having... By shadybearbklyn ( 5 Years Ago )
Forum Post When you enable Reach Effectors you animate feet with Reach Effector... By 4u2ges ( 5 Years Ago )
Forum Post Hi. Is this the motion ruler tool you have in the background of the... By AlbinosGambit ( 5 Years Ago )
Forum Post You could also go back to iclone 2: :hehe: Now, RL doesn't... By tripfreak ( 5 Years Ago )
Forum Post I don't remember it working in iClone 2...:unsure: A button is easily... By animagic ( 5 Years Ago )
Forum Post reach effectors and foot contact helped in my test case. By Procrastinator ( 5 Years Ago )
Forum Post Thanks for the input, much appreciated:-) [quote][b]Procrastinator... By AlbinosGambit ( 5 Years Ago )
