SLIDING FEET! Halp!
Posted By Devdevdev 6 Years Ago
AlbinosGambit
AlbinosGambit
Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)
Posts: 162, Visits: 478
Thanks for the input, much appreciated:-)
Procrastinator (5/7/2020)
reach effectors and foot contact helped in my test case.
WIN 10, COOLERMASTER MASTERCASE 500H, MSI GAMING PRO CARBON X470 RGB, AMD Ryzen 7 2700X CPU, MSI GeForce GTX 1650 GAMING X - 4GB GDDR5 RAM GPU, Corsair Vengeance RGB PRO DDR4 3200MHz 16GB RAM, SSD M.2 Corsair Force Series MP510 480 GB, SEAGATE BARRACUDA 3.5 HDD 4 TB.
Best regards
Albin
(AlbinosGambit)
Procrastinator
Procrastinator
Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)
Posts: 76, Visits: 980
AlbinosGambit
AlbinosGambit
Hi.
Is this the motion ruler tool you have in the background of the video?
I see there is more people having sliding feet issues.
We discussed the example karate kid pose problem from RL manual I try to replicate to learn.
https://forum.reallusion.com/440330/Walker-UVI-Footstep-Foley-Designer-ExperiencesHints-Tips?PageIndex=6
So, should I also try to use the reach effectors as well in my problem?
Have you finished making the motion ruler tool?
Thanks for all the help:-)
4u2ges (5/6/2020)
When you enable Reach Effectors you animate feet with Reach Effector Dummies as oppose to feet bones.
As I mentioned, it is not exactly convenient, but does fight feet slide effectively.
For this example I animated pose to pose.
If I need to lock the feet for certain number of frames between 2 poses, it is almost impossible to do with feet/leg bones
(otherwise you have to do dozens of tweaks in between frames cluttering your timeline).
Best regards
Albin
(AlbinosGambit)
Posts: 15.8K, Visits: 31.4K
I don't remember it working in iClone 2...:unsure: A button is easily added...:P
tripfreak
tripfreak
Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)
Posts: 2.0K, Visits: 2.8K
You could also go back to iclone 2: :hehe:
https://forum.reallusion.com/uploads/images/968ff25a-4332-4ea3-b266-3df1.jpg
https://forum.reallusion.com/uploads/images/9efa8a9e-ef21-42bc-a0b0-841a.jpg
Now, RL doesn't care anymore.
Posts: 5.3K, Visits: 16.8K
shadybearbklyn
shadybearbklyn
Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)
Posts: 337, Visits: 2.8K
Did you ever figure out how to fix the sliding feet issue? I’m having the same issue but I’m not sure how reach effectors would help.
Devdevdev
Devdevdev
Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)
Posts: 12, Visits: 87
Someone posted the solution and then deleted the comment - or atleast, I can't see it on the thread anymore - anyway - issue resolved:
Thank you!
https://www.youtube.com/watch?v=5NysH9_ieQE
Devdevdev
Devdevdev
Thanks for the link!
When this issue becomes overly annoying and well over the level I can tolerate, I use Reach Effectors to animate feet.
Animate all bones normally, but if you need to move/rotate feet, animate those reach effector balls.
Inconvenient and annoying - yes, but gets the job done.
