Alan_M
Alan_M
Visits: 2.9K
Hi Jennifer, I must admit I did not try QuickTime player, I still have it on my system, but you may be aware Apple announced a number of years ago they would no longer develop or support QT on the Windows platform. It is a shame as I really liked how you can scrub the video timeline in QT. Sadly that has put QuickTime onto my legacy list and I have had to stop using it day to day in favour of VLC. Undoubtedly as the years progress you will run into more and more media that may not play properly because of Apple's decision but as you have found, simply using another media player can resolve the problem, even if it take you away from your favourite player. I am working on a new iClone 7 course at the moment, should be out later in the year all being well.
Alan M
jenjon
jenjon
Last Active: 7 Years Ago
Visits: 43
Dear Alan, Good to hear that you will be creating iClone 7 tutorials!! Can I get on your mailing list to keep me posted when it is ready? I have another question for you that Reallusion has not responded to as yet. Perhaps you may have some insight into this. I am working on tutorial 103-08.12 Reach Target to Fix Hand Jitter. With Georgina selected I click on the Edit Reach Tool and no panel for this function appears. Although I can select hands or neck on Georgina with a mouse click there is no way to proceed any further without the Edit panel. (And the panel is not behind any of my windows...I checked!) Is this a software glitch at RLs end? Have you encountered this. Any input gratefully received. btw... we are fellow limeys! Jennifer
Alan_M
Alan_M
Visits: 2.9K
Hi Jennifer, Reallusion will undoubtedly be heavily marketing the course when it is released so if you have your account set to receive notifications and newsletters from Reallusion then you should not miss anything. As to your technical problem, I am afraid I cannot re-produce it. I do not have the Georgina avatar from the course assets to hand but I loaded a range of avatars from the Reallusion library all the way back to a G3 one!! In all cases I was able to get the Edit Reach Target dialog box to appear after selecting each one of the avatars. 77% of original size (was 656x19) - Click to enlarge The only things I can think of are the following. 1). Do you use a dual monitor setup? Is the dialog on a second monitor that is no longer connected. (Fix is to use the 'Window/Workspace/Reset Layout' feature) 2). CC characters have clothing and accessories, make sure the base Avater is selected in the scene manager, otherwise the Edit Reach Target button will not appear in the modify panel Finally, is this only happening with the Georgina asset? Or does it happen with any avatar from your library?
Alan M
imagination304_023567
Visits: 190
Alan_M (3/23/2017)
amy.lee-lo (3/23/2017) Did anyone else find that when they imported the warehouse extension asset for the iclone fundamentals training - that it didn't have the same amount of detail as Alan uses in the tutorial 103-03.09 navigating scene objects?
Perhaps it is because I don't have an essentials pack etc...but my cans are just solid shapes without the detail that Alan has in his tutorial...
Thanks AmyHi Amy, Alan Marques here, the course tutor. This is the way it is meant to be. If you watch the intro video for this cameras chapter of me talking to camera I explain that the warehouse asset I am using is 3rd party from Daz3D marketplace. So cannot be legally give away with the course. I made the low res proxy that exactly matches the dimensions of the Stonemason asset for the course. Some people who bought the course really liked the asset so they bought it off the Daz4D store. But the low-res one is provided with the course to allow you to complete that chapter without spending any more money. Hope that helps Hello Alan, May I ask what is the name of the low res proxy? I can't find it in the zip files. Thanks in advance
Visits: 190
According to "103-03.06 Loading the demo scene", there should be a folder "IC6 Camera Work" and a file called "Warehouse EX". 77% of original size (was 656x19) - Click to enlarge I really could not find it or its replacement. Any idea? Thanks
Alan_M
Alan_M
Visits: 2.9K
Hi imagination304_023567 Please bear with me while I check the archives as I have not watched that video for some time and will need to check it against the missing asset list. Be in touch soon.
Alan M
Alan_M
Alan_M
Visits: 2.9K
imagination304_023567 (7/22/2020)
According to "103-03.06 Loading the demo scene", there should be a folder "IC6 Camera Work" and a file called "Warehouse EX". 77% of original size (was 656x19) - Click to enlarge I really could not find it or its replacement. Any idea? Thanks Sorry for the delay in sorting this out, had to go find the offline disk archive of the iC6 Fundamentals Course-ware project. I have located the missing file, I do actual recall doing this previously for someone but for reasons I do not understand the front page of this forum thread was not updated to include it. Please note that the Dropbox links currently will not work as I have stopped using that platform on a personal basis and will be moving to a different cloud storage provider to host this content. However, having said that I have already uploaded the asset you require and provide here a link for you to download it. iC6_Fundamentals_103_Warehouse_Prop.zipThe installation method is the same as covered in the video '103-02.03 Installing the course assets.mp4', once you do the install as listed then the asset should show up as per the video. Please let me know if resolves your issue. All the best
Alan M
Visits: 190
It works now! Thanks a lot!
Alan_M
Alan_M
Visits: 2.9K
Great stuff, thanks for letting me know,
Alan M
mike.dodds.limekilns
Visits: 85
Hi Alan,
I've been working through the iClone6 Fundamentals in iClone7 and have hit a problem now I'm in 103. All of the Beer Garden projects are causing iClone7 to crash while trying to open them (as does the beer garden project in the 102 folder). Checking further it looks like the problem happened between EX-Beer Garden 003 (which I can open) and Ex-Beer Garden 004 (which causes a crash).
I'll go back to that point and build the rest of the beer garden for myself, but I was wondering if you know what might cause iClone7 to crash after this point.
Is the iClone7 course going to be available soon?
Cheers
Mike
