Alan_M
Alan_M
Visits: 2.9K
(PLEASE NOTE: UPDATE AS 2020-07-27)
Due to the fact that I have stopped using Dropbox on a personal basis I have moved all of the files and links to a different cloud service provider called MediaFire. I have also taken the opportunity to update the contents of the zip files to be more consistent and in the case of the assets files they are now correctly laid out in the iClone 6 directory hierarchy. This will make it easier to install the missing assets as you can use the same technique as show in video ‘103-02.03 Installing the course assets.mp4‘
Greetings everyone,
Although we at MakinMovies have done our best to address some issues with the technical delivery of the iClone Fundamentals course it has come to our attention that some people are still finding issues. Some of these are missing course assets others are correction to the actual videos that were identified.
I am setting up this Topic so that should anyone find a missing asset etc they can come here and download that asset from my MediaFire account.
The following is a list of zip files that cover all currently reported issues:
Table of Contents PDFs that covers all four course modules. Missing Dialogue .wav audio tracks for the 103 course. All missing assets from the F101 module. All missing assets from the F102 module. All missing assets from the F103 module. All missing and Updated Videos
As any new issues are reported I will update this list. Many thanks for your patience and understanding.
Alan M
Snarp Farkle
Snarp Farkle
Visits: 3.6K
Very good Alan, much appreciated. :)
genao87
genao87
Visits: 1.0K
i was looking for these....too late for the B Camera though.....already created a slower version.
steve_20140811193313686
Visits: 52
Thanks Alan... really learning a lot from your course... also made other online videos extremely easy now.
Alan_M
Alan_M
Visits: 2.9K
Many thanks to you both for you kind comments. I am glad you got the B camera sorted without the missing video. I we ever get to make a course like this again we will do our best not to repeat the issues with delivery. It was such a huge course that too many errors crept into the final delivery. All the best
Alan M
doubledutch
doubledutch
Visits: 4.9K
Is it possible to produce a tutorial about skin weights? Especially for skirts and how the weights must be around the hip.
RagingKylo
RagingKylo
Last Active: 9 Years Ago
Visits: 457
Hi Master Marques, I have a weird issue with 3dXchange: when I load some Daz assets in DazStudio, everything is fine. But after I export'em to 3dXchange, all the furnitures are outside the house:
How to fix this? Any suggestions will be massively appreciated! BTW, I know I can unparent all the objects in DazStudio then make them subprops in Xchange, but it's very time-consuming.
Alan_M
Alan_M
Visits: 2.9K
doubledutch (8/15/2016) Is it possible to produce a tutorial about skin weights? Especially for skirts and how the weights must be around the hip.
Hi doubledutch, I would need you to elaborate on skin weights. This type of weighting is normally set inside the core 3D app where you construct the character, such as Maya, Blender, 3dsmax, Modo etc, etc. Or are you referring to Character Creator? All the best
Alan M
Alan_M
Alan_M
Visits: 2.9K
RagingKylo (8/18/2016) Hi Master Marques, I have a weird issue with 3dXchange: when I load some Daz assets in DazStudio, everything is fine. But after I export'em to 3dXchange, all the furnitures are outside the house: How to fix this? Any suggestions will be massively appreciated! BTW, I know I can unparent all the objects in DazStudio then make them subprops in Xchange, but it's very time-consuming.Hi RagingKylo, this is a new one on me though I have experienced something different with a prop I brought into iClone that may be related. The asset came in fine but when I tried to scale it all of its constituent parts started to separate. Is this just one mesh item inside of Daz, or does it have more than one mesh item?? If it has more than one mesh item then you could try making sub-props of them inside of 3DX before your send the model through to iClone? All the best
Alan M
RagingKylo
RagingKylo
Visits: 457
More than one mesh. Yes you're right, the only way I can fix this is making subprops. So many subprops, very very time-consuming
