My mocap device is not being recognized
Posted By kcanache 14 Years Ago
kcanache
kcanache
Posted 14 Years Ago
Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)
Posts: 8, Visits: 216
I installed the mocap device plugin and connected my kinect mocap device into the usb port. I opened the Mocap Driver Plugin Program and click on Connect but I get this message:
Connecting to Mocap Device
Initiation fail. (65565:Device not found)
I checked in my PC under Device Manager/PrimeSense/Kinect Motor and apparently there is a problem with the driver:
Description:
Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39.
Files that help describe the problem:
C:\Users\kcanache\AppData\Local\Temp\DMI23A8.tmp.log.xml
C:\Windows\inf\oem98.inf
What did I do wrong? :hehe:
Thanks.
Threaded View
Threaded View
Forum Post My mocap device is not being recognized By kcanache ( 14 Years Ago )
Forum Post Is your Kinect plugged into a power outlet? The Kinect which comes... By Keith_MPS ( 14 Years Ago )
Forum Post Yes I did; I bought the stand alone kinect sensor that comes with the... By kcanache ( 14 Years Ago )
Forum Post Hi, I have the same problem after installed the included driver. I... By brand468 ( 14 Years Ago )
Forum Post I have the same problem—no drivers installed. downloaded the... By hmadden ( 14 Years Ago )
Forum Post I forgot to add— all hooked up, green light on, plug in installed—no... By hmadden ( 14 Years Ago )
Forum Post I have the same problem and messgaes By aussienat2000 ( 14 Years Ago )
Forum Post I downloaded the software mentioned above and now it operates By aussienat2000 ( 14 Years Ago )
Forum Post Thanks brand468 but still not working for me :unsure: I installed the... By kcanache ( 14 Years Ago )
Forum Post Hi, First you start "Mocap Device Plug-in v1.0" and press connect and... By brand468 ( 14 Years Ago )
Forum Post Hi kcanache, If you have the Mocap Device Plugin from Reallusion, you... By shygirl ( 14 Years Ago )
Forum Post [quote][b]shygirl (9/28/2011)[/b][hr] Hi kcanache, If you have the... By brand468 ( 14 Years Ago )
Forum Post [quote][b]shygirl (9/28/2011)[/b][hr]Hi kcanache, If you have the... By kcanache ( 14 Years Ago )
Forum Post kcanache, Check your PM box. Shy By shygirl ( 14 Years Ago )
Forum Post hi it may be your firewall , try disabling it, this is what happened... By redrubyslippers ( 14 Years Ago )
Forum Post [quote][b]connorethan1 (9/30/2011)[/b][hr]hi it may be your firewall ,... By kcanache ( 14 Years Ago )
Forum Post The light can't be a hardware issue, I just bought a brand new kinect... By malospam1 ( 14 Years Ago )
Forum Post I don't think it's hardware ether, mine is brand new also. At this... By hmadden ( 14 Years Ago )
Forum Post got it! see my post in the main thread! your welcome! By malospam1 ( 14 Years Ago )
Forum Post Hiya, i've tried everything but still getting this ' Initiation fail.... By chuboy ( 13 Years Ago )
Forum Post For all issues with the Mocap Device Plugin please first check out the... By Peter (RL) ( 13 Years Ago )
Forum Post Got it - the SDK Beta 2 driver will work with Windows 8. Plus I have... By rodneyhaun ( 12 Years Ago )
Forum Post I am using Windows 8 and all installed well and my device driver seems... By rodneyhaun ( 12 Years Ago )
Forum Post [quote][b]rodneyhaun (7/3/2013)[/b][hr]I am using Windows 8 and all... By Peter (RL) ( 12 Years Ago )
Forum Post This is extremely frustrating!!! I WAS having the same problem as the... By Dudicus ( 12 Years Ago )
Forum Post ugh, i hate when that happens!! :crazy:.....have you tried... By planetstardragon ( 12 Years Ago )
Forum Post [quote][b]Dudicus (8/23/2013)[/b][hr]This is extremely frustrating!!!... By Peter (RL) ( 12 Years Ago )
Forum Post [font=Arial][/font] Hi, i have a sample the problem,when i started... By camvan ( 10 Years Ago )
Forum Post So... had the trial version. Worked decent enough. Purchased the full... By Sp3c1alk ( 4 Years Ago )
