Posts: 23.1K,
Visits: 36.6K
Dear iClone Users,
We have now released iClone 8.22 with the new Dynamic Wrinkles for your characters. However, as with all updates there may be a few bugs, glitches or other annoying issues that remain.
Important: If you do find any bugs, issues or glitches in iClone 8.22, please can you report them first in the Feedback Tracker. Then feel free to discuss the issues in this thread but do try to include a link back to the original Feedback Tracker report or your tracker number.
As always it will help us greatly if we can keep all technical issues in the one place (this thread). This will help the development team keep track of any problems.
Please do try to provide your full system specifications and a detailed description of the problem when reporting issues and include screenshots and/or a workflow video whenever possible. If you can provide specific steps so we can try and reproduce the problem that will be even better.
Many thanks and have fun with iClone 8.
Last Active: 11 hours ago
Visits: 31.4K
I don't know yet if this is a repeatable bug, but if I try to load some older props into an existing project, I get a prompt asking me to convert the prop to make it compatible with the version of iClone. If I let it convert, it sometimes converts and sometimes the progress is at 26% and iClone crashes. I don't quite understand why I get the prompt because they are just props.
gordryd
gordryd
Last Active: 3 Months Ago
Visits: 8.1K
Yes, I've used iClone since Version 4 and this seems like the least stable release (8.2) I've ever used. iClone has crashed several times, mostly when loading a "new" or existing project while a current project is already loaded. It seems like having Motion Live window open aggravates the problem, but it isn't 100% repeatable. One time it even locked up my computer requiring a reboot.
Reallusion Certified Director / Reallusion Best Visual Award / Reallusion Certified Content Developer See all the G-Tools Plug-Ins available for iClone here: G-Tools Plug-Ins
ade.p
Visits: 256
We have a couple of licences. On one install, it crashes when you have a project loaded and try to load another project. Happens every single time, absolutely killing batch rendering! On the second computer, it won't load any of the projects created in 8.2 on the first computer. Both are up to date/patched, and have all the content assets downloaded.
These projects are 1 avatar, around 1 min long.
Computer 1 - RTX 3080 (laptop, 2022, i7 11th gen) Computer 2 - GTX something I think, (laptop, 2022, i5 11th gen)
Leowald
Leowald
Visits: 2.9K
Hello,
I've noticed some problems since the update.
1 = The face texture of my character disapear when I make a render photo or video. I think it happens when I've added a substance tool layer with the new wrinkles tool. (without the substance tool layer it's working fine but I need it for my animation)
2 = When I render a project (about 6min30 of animations) for many hours, when it's finish I get a box to tell me that's over and I can read the video. When I click "Yes" nothing happen and when I check my video it's empty (0Mo) It's very strange, because this situation is totally random (I already get this problem some months ago, but it's also working fine on others projects). I noticed that I don't get this problem anymore if I disable the compression. But for a big project, my video will be too big :blink:
3 = I still have the problem about the fact I can't read my video after 44 700 frames in 60FPS (but I can read if the project is in 30FPS)
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
Maybe I'm doing something wrong as this feature is new. However, when I tested it; The wrinkle feature is imported to UE if you export the character in fbx format. However, if you transfer the character to UE via live link, unfortunately it doesn't work.
---------------------------------------------------------------- https://www.youtube.com/yepkoo https://dev.epicgames.com/community/profile/bxvo/Yepkoo#learning
johnsongaric1
johnsongaric1
Visits: 238
just downloaded 8.21 viewing area is significantly reduced
Posts: 23.1K,
Visits: 36.6K
iClone 8.21 has been released today. Please update using the Reallusion Hub. However, if you still have issues after the update, please remember to report them in the Feedback Tracker first and then feel free to discuss here. Thanks.
Posts: 5.3K,
Visits: 16.8K
Since the release of IC8, the routine for caching Iray images has changed. In IC7, project load routine would only cache Iray images if the Iray Render Setting window is opened. Otherwise, if Iray window was closed during the project load and you bring it up later on, the caching process would start at that moment. Not the case in IC8. It would start caching Iray images regardless on all projects opening. I rarely use Iray and keep Iray Settings window closed. But on heavily textured projects, the caching takes a long time on opening and a lot of disk space. And then I suppose it does refresh Iray cache every time I change something. Extremely inefficient and unnecessary. Should be reverted back to IC7 way. Unless someone knows the setting to control Iray caching process, I will post a ticket in FT later on.... FT: https://www.reallusion.com/FeedBackTracker/Issue/Unnessesary-Iray-images-caching-on-every-project-load
ade.p
Visits: 256
Here's a new one - anybody seen this before? see https://www.reallusion.com/FeedBackTracker/Issue/Render-fails-on-final-frame-and-weirds-up-the-hairI've got an iproject file which fails to render. There is one avatar, no background (plain colour) and intricate lighting. The render is 2755 frames at 1080p60. During the render, strange lines project from behind the avatar's head.  And on the final frame, iClone just hangs or crashes out (terminates). I've tried removing the last frame, the last two frames, batch render and stand-alone render, and rendering on two different computers from different manufacturers (Gigabyte, 11th gen i7, RTX, Win11; HP, 9th gen i7, GTX, Win10). Same behaviour each time.
