Daz3d Genesis 9 Character to full cc3+ model?
Posted By Mickles Higginsby 2 Years Ago
Mickles Higginsby
Mickles Higginsby
Posted 2 Years Ago
Junior Member (234 reputation)Junior Member (234 reputation)Junior Member (234 reputation)Junior Member (234 reputation)Junior Member (234 reputation)Junior Member (234 reputation)Junior Member (234 reputation)Junior Member (234 reputation)Junior Member (234 reputation)
Posts: 2, Visits: 44
Up to this point; I am able to import Genesis 9 characters into CC4. I resculpt the eyes as they are always a blank white (an user on the daz forums helped me get this far - https://www.daz3d.com/forums/discussion/comment/7976481#Comment_7976481).
The model looks like it is ready to go but it is only a humanoid model now and seems to not be compatible with a good swath of cc4's features. Is there a way to fully convert my gen9 model to a full CC3+ model?
Procedure for exporting Daz gen9 character - Import to CC4 response from a very helpful Daz3d member.
"It is certainly possible. Before exporting your Gen 9 figure from Studio, make sure you right click on the Gen 9 figure in the Scene tab and select "All" which makes sure all your bones, clothes, hair goes over into the exported fbx.
Importing the figure into CC4, don't use Transformer, (although I guess there will be an update to correct this in future), instead import your figure as a Human-Non Standard. Close the Characterization tab. Next, open the AccuRIG tab, select Create Guides and click OK. When that finishes, select Generate Skeleton from the AccuRIG menu and let CC4 do its thing. When that finishes, select Bind Skin and let that finish.
Then you can click on Check Animation and select a Motion, to make sure everything is working fine.
The figure still has the scary white eyes, so come out of AccuRIG and go to Edit Mesh in the CC4 menu. Select Sculpt, then click on the eyeball symbol next to Brush Type. Adjust the Radius of the red circle to be the same size as the eye and click on the eyeballs. You will get the pupils back - WOO HOO!
Then click carefully on any white areas still visible around the eyes, including the surrounding whites and also the "tear" area, adjusting the radius as needed. This is a bit fiddly, but worth spending a bit of time getting this right. You can go out of Edit Mesh mode to check what it looks like, go back in to have another tweak if you need - it might take a few goes to get everything covered.
 After that, you should be good to go. "
Threaded View
Threaded View
Forum Post Daz3d Genesis 9 Character to full cc3+ model? By Mickles Higginsby ( 2 Years Ago )
Forum Post Thanks for sharing your workflow. This will help others looking to... By Peter (RL) ( 2 Years Ago )
Forum Post any idea when Transformer will be updated ? I like to put G9 clothing... By Jbowdoin ( 2 Years Ago )
Forum Post I would like to also know if it's coming, and when :) By anandadivine108 ( 2 Years Ago )
Forum Post [quote][b]anandadivine108 (6/8/2023)[/b][hr]I would like to also know... By Peter (RL) ( 2 Years Ago )
Forum Post [quote][b]Jbowdoin (5/25/2023)[/b][hr]any idea when Transformer will... By Peter (RL) ( 2 Years Ago )
Forum Post UPDATE: After checking, support for Genesis 9 characters should be... By Peter (RL) ( 2 Years Ago )
Forum Post Thanks for the update Peter. Looking forward to testing it out. By Leodegrance ( 2 Years Ago )
Forum Post Is there an updated Genesis 9 Male and Female DUF file for facial... By kungphu ( 2 Years Ago )
Forum Post WOOT WOOT! THANK YOU! By Mickles Higginsby ( 2 Years Ago )
Forum Post I just patched the update and did a quick test - Genesis 9 now comes... By amckenzie ( 2 Years Ago )
Forum Post [quote][b]amckenzie (6/19/2023)[/b][hr]I just patched the update and... By revenger681 ( 2 Years Ago )
Forum Post Yeah, did a quick test of importing a Genesis 9 character. It came... By Leodegrance ( 2 Years Ago )
Forum Post [quote][b]Leodegrance (6/19/2023)[/b][hr]Yeah, did a quick test of... By Peter (RL) ( 2 Years Ago )
Forum Post when will the uv transfer tools/files for genesis 9 be available? By edmark ( 2 Years Ago )
Forum Post [quote][b]edmark (6/23/2023)[/b][hr]when will the uv transfer... By Peter (RL) ( 2 Years Ago )
Forum Post These files sir.. we need the daz genesis 9 version of these By edmark ( 2 Years Ago )
Forum Post [quote][b]edmark (6/23/2023)[/b][hr]These files sir.. we need the daz... By Peter (RL) ( 2 Years Ago )
Forum Post The instructions in the manual are out of date for conversions.... By animatedbeing ( 2 Years Ago )
Forum Post [quote][b]animatedbeing (6/24/2023)[/b][hr] The instructions in the... By Peter (RL) ( 2 Years Ago )
Forum Post Has there been a facial profile for Genesis 9 made for the Daz... By hoodtronik ( 2 Years Ago )
Forum Post [quote][b]ilyas.nashid (7/7/2023)[/b][hr]Has there been a facial... By Peter (RL) ( 2 Years Ago )
Forum Post I would like to know that as well. I can't make any facial profile for... By st180492 ( 2 Years Ago )
Forum Post [quote][b]Peter (RL) (7/10/2023)[/b][hr][quote][b]ilyas.nashid... By R Ham ( Last Year )
Forum Post I've been working with the import process above. I tried a fat man... By R Ham ( Last Year )
Forum Post [quote]Then I tried a lion head G9. In both cases, they came in as a... By 4u2ges ( Last Year )
Forum Post Hi was the Genesis 9 import capability suspended? I'm on CC 4.51 and... By jay.simtrip ( Last Year )
Forum Post [quote][b]jay.simtrip (11/24/2024)[/b][hr]Hi was the Genesis 9 import... By Peter (RL) ( Last Year )
Forum Post Thanks Peter I can't remember on top of my head, but I tried several... By jay.simtrip ( Last Year )
