TempAvatar.. Why?!
Posted By Mana.Lucine 4 Years Ago
Mana.Lucine
Mana.Lucine
Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)
Posts: 99, Visits: 399
Hello..
Why just right after exporting to IC my CC file name changes to TempAvatar ?!!!
Thanks
michaelrbarton
michaelrbarton
Posts: 974, Visits: 11.2K
The only thing I can think of to do is just rename it from tempavatar to insert name .iavatar
Mana.Lucine
Mana.Lucine
Thank you for your reply, although I didn't exactly understand it.. So why CC changes the original name?!
michaelrbarton
michaelrbarton
When you save a character in CC, it is called a .ccAvatar.
When you export to IC, it is saved as an .iAvatar.
It is just called a tempAvatar until you change the name.
If you don't change the name, it will be tempAvatar 1,
tempAvatar 2 and so on.
General Picture Animation
Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)
Posts: 335, Visits: 6.6K
(1) Create a new avatar in CC and export it as NAME.iAvatar.
(2) The project name turns to NAME.ccProject.
(3) Export the avatar to iClone and the avatar name changes to TempAvatar, also changing the default name for saving the project again.
(4) Update TempAvatar with any changes and try to update the file using Export.
(5) You can't automatically update NAME.iAvatar--you must write over "TempAvatar.iAvatar" in the dialog box.
The poster is asking anyone to explain why this is desirable, let alone logical.
It pretty much violates the file standards for every other Windows app.
Animating now to life itself --Walt Whitman
Mana.Lucine
Mana.Lucine
Thank you Michael and GPA for your detailed responses, very interesting to know. However, in my case -as most CC users- I design my own character in CC, there's a button in the menu to send my character to IC.. Here I want to test it animating in IC while I want to keep working on it.. This is impossible as CC changes the file name to 'TempAvatar' right after sending it to IC.. I have no option but to reopen it again or save it as the original name.
Last Active: 5 Months Ago
The best way to avoid this, I think, is to save the avatar first in CC as iAvatar, in which case it will have its assigned name, which is the name it is given in CC (assuming that it has been given a name).
By sending it directly to iClone it is considered a temporary file and is given some generic name. You would still have to save it in iClone to have it saved. I hardly ever use the send directly to iClone option, so I don't encounter this problem.
Still waiting for a response to this:
General Picture Animation (1/1/2023)
So in my case the following happens:
1) I create a new avatar using headshot (the default name at that point is the name of the base character).
2) I save it as NAME.iAvatar, the name in the title bar is now NAME.iAvatar.
3) I save it locally as a CC character, clicking Save in the Avatar panel: I get prompted for a name.
4) I save it locally as a CC project, clicking Save in the Project panel: I get prompted for a name.
5) I export again, now as NAME2.iAvatar, the name in the title bar is now NAME2.iAvatar.
I don't like that the name of the iAvatar is shown in the title bar (it should keep the project name), but I don't get TempAvatar at any pont.
Mana.Lucine
Mana.Lucine
animagic (1/5/2023)
I did this but CC strangely still changing my character file name to TempAvatar whenever I click on send to IC
