TempAvatar.. Why?!
Posted By Mana.Lucine 4 Years Ago
Mana.Lucine
Mana.Lucine
Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)
Posts: 99, Visits: 399
Hello..
Why just right after exporting to IC my CC file name changes to TempAvatar ?!!!
Thanks
Threaded View
Threaded View
Forum Post TempAvatar.. Why?! By Mana.Lucine ( 4 Years Ago )
Forum Post The only thing I can think of to do is just rename it from tempavatar... By michaelrbarton ( 3 Years Ago )
Forum Post Thank you for your reply, although I didn't exactly understand it.. So... By Mana.Lucine ( 3 Years Ago )
Forum Post When you save a character in CC, it is called a .ccAvatar. When you... By michaelrbarton ( 3 Years Ago )
Forum Post (1) Create a new avatar in CC and export it as NAME.iAvatar. (2) The... By General Picture Animation ( 3 Years Ago )
Forum Post Still waiting for a response to this: [quote][b]General Picture... By General Picture Animation ( 3 Years Ago )
Forum Post I am still encountering the same weird problem after I tried all... By Mana.Lucine ( 3 Years Ago )
Forum Post Thank you Michael and GPA for your detailed responses, very... By Mana.Lucine ( 3 Years Ago )
Forum Post The best way to avoid this, I think, is to save the avatar first in CC... By animagic ( 3 Years Ago )
Forum Post [quote][b]animagic (1/5/2023)[/b][hr]So in my case the following... By Mana.Lucine ( 3 Years Ago )
Forum Post So in my case the following happens: 1) I create a new avatar using... By animagic ( 3 Years Ago )
Forum Post I have not been able to repeat it in my workflow. By animagic ( 3 Years Ago )
Forum Post [quote][b]animagic (1/9/2023)[/b][hr]I have not been able to repeat it... By toystorylab ( 3 Years Ago )
Forum Post OK. I hardly ever use "Send to iClone" because it doesn't give control... By animagic ( 3 Years Ago )
Forum Post Okidoki, was just wondering it did not do this on your side when you... By toystorylab ( 3 Years Ago )
Forum Post Hmm, I just sent Camilla, and it even becomes... By animagic ( 3 Years Ago )
Forum Post Yeah, it all does not make much sense... When you add Kevin ("CC4... By toystorylab ( 3 Years Ago )
Forum Post I won’t argue that any of that is not annoying, but I will ad I’ve... By bad_character ( 3 Years Ago )
