TempAvatar.. Why?!
https://forum.reallusion.com/Topic530179.aspx
Print Topic | Close Window
By Mana.Lucine - 4 Years Ago
Hello..
Why just right after exporting to IC my CC file name changes to TempAvatar ?!!!
Thanks
By michaelrbarton - 3 Years Ago
The only thing I can think of to do is just rename it from tempavatar to insert name .iavatar
By Mana.Lucine - 3 Years Ago
Thank you for your reply, although I didn't exactly understand it.. So why CC changes the original name?!
When you save a character in CC, it is called a .ccAvatar.
When you export to IC, it is saved as an .iAvatar.
It is just called a tempAvatar until you change the name.
If you don't change the name, it will be tempAvatar 1,
tempAvatar 2 and so on.
By General Picture Animation - 3 Years Ago
(1) Create a new avatar in CC and export it as NAME.iAvatar.
(2) The project name turns to NAME.ccProject.
(3) Export the avatar to iClone and the avatar name changes to TempAvatar, also changing the default name for saving the project again.
(4) Update TempAvatar with any changes and try to update the file using Export.
(5) You can't automatically update NAME.iAvatar--you must write over "TempAvatar.iAvatar" in the dialog box.
The poster is asking anyone to explain why this is desirable, let alone logical.
It pretty much violates the file standards for every other Windows app.
Thank you Michael and GPA for your detailed responses, very interesting to know. However, in my case -as most CC users- I design my own character in CC, there's a button in the menu to send my character to IC.. Here I want to test it animating in IC while I want to keep working on it.. This is impossible as CC changes the file name to 'TempAvatar' right after sending it to IC.. I have no option but to reopen it again or save it as the original name.
By animagic - 3 Years Ago
The best way to avoid this, I think, is to save the avatar first in CC as iAvatar, in which case it will have its assigned name, which is the name it is given in CC (assuming that it has been given a name).
By sending it directly to iClone it is considered a temporary file and is given some generic name. You would still have to save it in iClone to have it saved. I hardly ever use the send directly to iClone option, so I don't encounter this problem.
Still waiting for a response to this:
General Picture Animation (1/1/2023)
So in my case the following happens:
1) I create a new avatar using headshot (the default name at that point is the name of the base character).
2) I save it as NAME.iAvatar, the name in the title bar is now NAME.iAvatar.
3) I save it locally as a CC character, clicking Save in the Avatar panel: I get prompted for a name.
4) I save it locally as a CC project, clicking Save in the Project panel: I get prompted for a name.
5) I export again, now as NAME2.iAvatar, the name in the title bar is now NAME2.iAvatar.
I don't like that the name of the iAvatar is shown in the title bar (it should keep the project name), but I don't get TempAvatar at any pont.
animagic (1/5/2023)
I did this but CC strangely still changing my character file name to TempAvatar whenever I click on send to IC
I am still encountering the same weird problem after I tried all this.. Until now I don't understand what makes RL have this 'option' in CC to change the file names after sending to IC?! Both apps are standalone, so why this TempAvatar why?!! It consumes time as well as forcing the user to revert to the original file after every IC export.
I have not been able to repeat it in my workflow.
By toystorylab - 3 Years Ago
animagic (1/9/2023)
Did you use "send to iClone" button in CC4??
When doing so, CC4 always reverts file name to "TempAvatar.iAvatar" on my side...
But if you use "export iAvatar" it won't do so.
No big deal as I mostly save under correct name before using "send to iClone" button,
but it would be cool if CC wouldn't do this...
OK. I hardly ever use "Send to iClone" because it doesn't give control over the export parameters.
If it is desirable for this behavior to be changed, there is FT. Some questions posed here get ignored...:unsure:
Okidoki, was just wondering it did not do this on your side when you use send to iClone...
Hmm, I just sent Camilla, and it even becomes TempAvatarWithMotionPlus. Curious...:unsure:
This brings up something related that happens when you save as iAvatar. I would expect the file name in the title bar to remain NAME.ccAvatar, instead it is now NAME.iAvatar.
Yeah, it all does not make much sense...
When you add Kevin ("CC4 Kevin.ccAvatar" from built in characters pack in IC8) to IC8 and "send to CC4" , file name in CC4 is "TempAvatar,iAvatar"
If you send it back to IC8 file name in CC4 changes to "TempAvatarWithMotionPlus,iAvatar"
Unless it has a crucial reason, I guess some coding could stop this nonsense.
Cause when I load "CC4 Kevin" from the built in characters within CC4, file name is "CC4 Kevin.ccAvatar"
When I load same Kevin in IC8 and send to CC4, why not simply also call it "CC4 Kevin.ccAvatar"?
By bad_character - 3 Years Ago
I won’t argue that any of that is not annoying, but I will ad I’ve always hated and ran into problems with how this works at an even more core level.
If I make a .cc project and work on a character, then I send to iClone - I shouldn’t now have some different iavatar project in character creator. Keep that implementation garbage to yourself. An iavatar should be sent to iClone, deal with that and don’t involve me, and in character creator I should be looking at my .cc project. I didn’t create a new project. I didn’t convert anything to anything. I exported my character to iClone. I’ve never seen something so unintuitive and the opposite of useful to me every damn time.
