MP4 rendering consistent crash at saving
Posted By Amper Sand 4 Years Ago
Amper Sand
Amper Sand
Posts: 731, Visits: 5.2K
I just installed IC8 in a total separate folder structure than IC7, loaded my current IC7 project (15000 frames), everything went pretty smooth, I started rendering as MP4, I cancelled, but when I chose "Save" the IC crashed. Tried the same three times in a row, three crashes in a row. IC7 is having no problem. Pretty exciting start for the money :D
P.S "Optimize with Fullscreen rendering" has gone in IC8?!?
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
sungod
sungod
Posts: 249, Visits: 3.7K
Can you try a smaller project ?
Also you can turn on hardware rendering.
I am so busy , didn't get to try but rendered once without issues in MP4
I used cc4 to make a 4 k avatar and sent it to Iclone 8 and rendered a high resolution MP4 video.
Amper Sand
Amper Sand
I'm not interested in Hardware rendering since long time ago, on comparation I liked more IC's software rendering.
For MP4s, since I'm using them for fast previews, I'm rendering in 2K @ 30fps, the final rendering I'm doing in 4K PNG sequence.
sungod
sungod
Amper Sand (5/13/2022)
For me it didnot crash in either with or without .
Can you try a new character from CC4 ?
Amper Sand
Amper Sand
I didn't install yet the CC4 - even with IC8 I won't count on it too much, I'm expecting RL will came with a patch in a month, me I'm happy it didn't affect the IC7 so I can continue there on my clip :P
sungod
sungod
No worries just try a default character a new one from ic 8 maybe 🙂
Amper Sand
Amper Sand
@Peter You may close/remove this topic, the crash no longer occurs - don't know why, maybe because I just restarted the computer meantime.
Amper Sand
Amper Sand
@Peter, you may reopen this topic :D
It seems I've been superficial in checking - the crash indeed occurs consistently and for sure is related to avatar's hair. I've tried to replace the avatar with others to which I attached in CC4 the same hair, yes, it's crashing. If I'm replacing the hair with another one, there's no crash. Crash doesn't seem to be related with the MP4 encoder - app crash no matter if I use hardware/software encoder.
Also, crash doesn't seem to be related with a particular last frame - no matter how long I set the timeline, IC crash at the last frame.
It might be related with a particular rendering - light or physics - condition in the project, since the same avatar used in other projects doesn't make IC to crash.
I will try to simplify as much as possible the project to make a small one to be tested here by who's willing to.
P.S the hair is native RL "Chic bun medium" - both the one in Hair/HairStyle and the one in Hair/HairGroup/Hair, but I don't think it's necessarily its fault, rathen than IC's.
Last Active: 3 days ago
I have seen this today already: https://forum.reallusion.com/FindPost515760.aspx
Seems consistent now...
Update: OUCH! Tried rendering 29 frames of large project I rendered successfully in IC7 in the past. Crashed at frame 27!
https://forum.reallusion.com/uploads/images/9a2c7451-f857-431c-b9fa-e6a6.jpg
If you have already stripped your project, please open an FT ticket and attach it there. I am too lazy to strip mine :w00t:
Amper Sand
Amper Sand
OK, I minimized the project as much as possible and I replaced the character with IC8 "native" Camilla to which I applied in CC4 the (assumed) "troubling" hair "Chic bun medium".
I downloaded the zip (78MB) myself to be sure the project still crash (and it's crashing) so please have a check yourself to see if it's crashing on your IC8 too, so we can send it "safely" to Feedback Tracker.
Thanks!
https://www.dropbox.com/s/yg70875ectnj9ur/crash_on_video_render_last_frame.zip?dl=0
