MP4 rendering consistent crash at saving
Posted By Amper Sand 4 Years Ago
Amper Sand
Amper Sand
Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)
Posts: 731, Visits: 5.2K
I just installed IC8 in a total separate folder structure than IC7, loaded my current IC7 project (15000 frames), everything went pretty smooth, I started rendering as MP4, I cancelled, but when I chose "Save" the IC crashed. Tried the same three times in a row, three crashes in a row. IC7 is having no problem. Pretty exciting start for the money :D
P.S "Optimize with Fullscreen rendering" has gone in IC8?!?
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
sungod
sungod
Posts: 249, Visits: 3.7K
Can you try a smaller project ?
Also you can turn on hardware rendering.
I am so busy , didn't get to try but rendered once without issues in MP4
I used cc4 to make a 4 k avatar and sent it to Iclone 8 and rendered a high resolution MP4 video.
Amper Sand
Amper Sand
I'm not interested in Hardware rendering since long time ago, on comparation I liked more IC's software rendering.
For MP4s, since I'm using them for fast previews, I'm rendering in 2K @ 30fps, the final rendering I'm doing in 4K PNG sequence.
sungod
sungod
Amper Sand (5/13/2022)
For me it didnot crash in either with or without .
Can you try a new character from CC4 ?
Amper Sand
Amper Sand
I didn't install yet the CC4 - even with IC8 I won't count on it too much, I'm expecting RL will came with a patch in a month, me I'm happy it didn't affect the IC7 so I can continue there on my clip :P
sungod
sungod
No worries just try a default character a new one from ic 8 maybe 🙂
Amper Sand
Amper Sand
@Peter You may close/remove this topic, the crash no longer occurs - don't know why, maybe because I just restarted the computer meantime.
Amper Sand
Amper Sand
@Peter, you may reopen this topic :D
It seems I've been superficial in checking - the crash indeed occurs consistently and for sure is related to avatar's hair. I've tried to replace the avatar with others to which I attached in CC4 the same hair, yes, it's crashing. If I'm replacing the hair with another one, there's no crash. Crash doesn't seem to be related with the MP4 encoder - app crash no matter if I use hardware/software encoder.
Also, crash doesn't seem to be related with a particular last frame - no matter how long I set the timeline, IC crash at the last frame.
It might be related with a particular rendering - light or physics - condition in the project, since the same avatar used in other projects doesn't make IC to crash.
I will try to simplify as much as possible the project to make a small one to be tested here by who's willing to.
P.S the hair is native RL "Chic bun medium" - both the one in Hair/HairStyle and the one in Hair/HairGroup/Hair, but I don't think it's necessarily its fault, rathen than IC's.
Posts: 5.3K, Visits: 16.8K
I have seen this today already: https://forum.reallusion.com/FindPost515760.aspx
Seems consistent now...
Update: OUCH! Tried rendering 29 frames of large project I rendered successfully in IC7 in the past. Crashed at frame 27!
https://forum.reallusion.com/uploads/images/9a2c7451-f857-431c-b9fa-e6a6.jpg
If you have already stripped your project, please open an FT ticket and attach it there. I am too lazy to strip mine :w00t:
Amper Sand
Amper Sand
OK, I minimized the project as much as possible and I replaced the character with IC8 "native" Camilla to which I applied in CC4 the (assumed) "troubling" hair "Chic bun medium".
I downloaded the zip (78MB) myself to be sure the project still crash (and it's crashing) so please have a check yourself to see if it's crashing on your IC8 too, so we can send it "safely" to Feedback Tracker.
Thanks!
https://www.dropbox.com/s/yg70875ectnj9ur/crash_on_video_render_last_frame.zip?dl=0
