Character jumps back to zero key after applying animation.
Posted By salesmanager 6 Years Ago
salesmanager
salesmanager
Veteran Member (988 reputation)Veteran Member (988 reputation)Veteran Member (988 reputation)Veteran Member (988 reputation)Veteran Member (988 reputation)Veteran Member (988 reputation)Veteran Member (988 reputation)Veteran Member (988 reputation)Veteran Member (988 reputation)
Posts: 13, Visits: 130
That did the trick! Thank you so much!
siryn30
siryn30
Junior Member (106 reputation)Junior Member (106 reputation)Junior Member (106 reputation)Junior Member (106 reputation)Junior Member (106 reputation)Junior Member (106 reputation)Junior Member (106 reputation)Junior Member (106 reputation)Junior Member (106 reputation)
Posts: 5, Visits: 40
Thank you. I have figured it out.
KanoEder
KanoEder
Junior Member (154 reputation)Junior Member (154 reputation)Junior Member (154 reputation)Junior Member (154 reputation)Junior Member (154 reputation)Junior Member (154 reputation)Junior Member (154 reputation)Junior Member (154 reputation)Junior Member (154 reputation)
Posts: 20, Visits: 248
salesmanager (8/19/2020)
I created a video to show what is happening. I don't know if this is a bug or if there is something I am not doing correctly to stop the behavior. Here is the video:
https://www.youtube.com/watch?v=9kxwPk2cpW4
Scenario: I place a character on the canvas. Then, I move the timeline a bit followed by moving the character to the right.
Then, I try to apply predefined animations (also does it for custom animations). The character jumps back to the zero key before doing the animation. Is there a way to stop this behavior?
Thanks,
Jim
Hi Jim,
You can try to uncheck the "Align with previous motion" settings.
https://forum.reallusion.com/uploads/images/0aed93e9-dbfd-4250-8082-e5d6.gif
salesmanager
salesmanager
I can actually help you with your issue. Instead of looping, double click on the animation again for the second iteration (or third, or fourth iteration, etc). Of course, make sure the character is selected before double clicking.
ramses47
ramses47
Veteran Member (791 reputation)Veteran Member (791 reputation)Veteran Member (791 reputation)Veteran Member (791 reputation)Veteran Member (791 reputation)Veteran Member (791 reputation)Veteran Member (791 reputation)Veteran Member (791 reputation)Veteran Member (791 reputation)
Posts: 29, Visits: 121
Veuillez  préciser les nom des motions? faire une copie d'écran peu être...
``Sinon contacter le service assistance"
bonnes étude et courage
siryn30
siryn30
I HAVE THE SAME ISSUE WITH MOVING ANIMATIONS LIKE WALK, RUN ,CLIMB STAIRS AND SO FORTH . WHEN I TRY TO LOOP THE 2ND LOOP ANIMATION IT JUMPS BACK TO THE ROOT SPOT. OR IF I USE THE COMPLETE ANIMATION CYCLE 1,2, AND 3 AND TRY TO ADDANOTHER ANIMATION IT JUMPS BACK TO THE ROOT WHERE #1 STARTED.
ramses47
ramses47
Vérifier près des touches avance arrière un vrai, si vous ne faites pas une boucle
salesmanager
salesmanager
Thanks,
Jim
