salesmanager
salesmanager
Visits: 130
That did the trick! Thank you so much!
siryn30
siryn30
Visits: 40
Thank you. I have figured it out.
KanoEder
KanoEder
Visits: 248
salesmanager (8/19/2020)
I created a video to show what is happening. I don't know if this is a bug or if there is something I am not doing correctly to stop the behavior. Here is the video: https://www.youtube.com/watch?v=9kxwPk2cpW4Scenario: I place a character on the canvas. Then, I move the timeline a bit followed by moving the character to the right. Then, I try to apply predefined animations (also does it for custom animations). The character jumps back to the zero key before doing the animation. Is there a way to stop this behavior? Thanks, Jim Hi Jim, You can try to uncheck the "Align with previous motion" settings.
salesmanager
salesmanager
Visits: 130
I can actually help you with your issue. Instead of looping, double click on the animation again for the second iteration (or third, or fourth iteration, etc). Of course, make sure the character is selected before double clicking.
ramses47
ramses47
Visits: 121
Veuillez préciser les nom des motions? faire une copie d'écran peu être... ``Sinon contacter le service assistance" bonnes étude et courage
siryn30
siryn30
Visits: 40
I HAVE THE SAME ISSUE WITH MOVING ANIMATIONS LIKE WALK, RUN ,CLIMB STAIRS AND SO FORTH . WHEN I TRY TO LOOP THE 2ND LOOP ANIMATION IT JUMPS BACK TO THE ROOT SPOT. OR IF I USE THE COMPLETE ANIMATION CYCLE 1,2, AND 3 AND TRY TO ADDANOTHER ANIMATION IT JUMPS BACK TO THE ROOT WHERE #1 STARTED.
ramses47
ramses47
Visits: 121
Vérifier près des touches avance arrière un vrai, si vous ne faites pas une boucle
salesmanager
salesmanager
Visits: 130
