mrtobycook (2/2/2020)
This is so helpful, thanks so much! I just went in and deactivated the software, then restarted, and tried to install once again.
But yeah exactly the same thing happened. It's weird cause with Iclone installer it gets past the "verifying serial number" part fine - it's just when it gets to "configuring product information" ("Setting up product information, please wait...") it then crashes out (well, it entirely disappears).
Same thing happens with Character Creator 3 installer...Back up any project files you have before doing anything.
Do you have any virus software loaded like Nortons or macafee...make sure that is disabled.
Im starting to think it could be system related make sure windows it up to date,
also make sure the system clock and date are set correctly. Do this step...
Its a pain but you have to make sure everything is gone for a clean install.
manual cleaning hunt all the files ...
ok try this go to
C drive ...users/ public/ public documents/ see if there is a reallusion folder there delete it
go to C drive / program folders/ get rid of any reallusion folders....
go to C drive / program files (x86) get rid of any reallusion folders.
C drive : temp folder check if any reallusion related items.
Check This PC: documents folder/ for any RL. documents or files delete it
go to control panel make sure no reallusion anything shows up in the uninstall list.
if you are good with windows you can go to windows search and type, "event viewer" and take a look at your logged errors.
this can tell you lots of information .
make sure virus software is off..
once you have everything deleted try installing again in administrator mode.
if none of that works ....
There could be some windows or hard drive directory errors you are having. I have used system mechanic for years
do you have anything like
system mechanic ? you can do a free scan but you have to own it to fix stuff but
it can tell you what might be going on or any listed errors. Other then that contact tech support.
Free scan
Freelance Artist Kevin.S
Email: animatemyart@gmail.com - Web Site: www.animatemyart.com
