Posts: 10.8K,
Visits: 40.2K
I have not understand how to create displacement maps , the "big feature" since iClone 6 . I have even buy a tutoria,l but not working for me That Tut is more confusing than helfull What is the secret of this feature ? How can I create such a map in Zbrush for iClone in easy steps? I think why it is not so popular, because nowbody know how to make.this Maybe someone can change this ?
I would realy know how it works
Rockoloco666
Rockoloco666
Group: Banned Members
Visits: 2.0K
The easiest method to create a displacement map is to convert the diffuse map into a greyscale image and tweak the contrast and brightness. Like bump maps but less detailed. I would also recommend awesome bump it is freeware and it can create any map you want based on any image you give it, kinda like bitmap2material which is included in the substance supertools.
Tesselation is a little bit tricky since it needs two things to work properly with grayscale displacement maps: a decent uv map unlike the uv maps sketchup autogenerates, and some decent polycount.
Also there are the vector displacement maps which look like normal maps, and are intended to be used on low poly objects to create a lot of detail using tesselation but i dont remember how to create them, i guess you can bake them in zbrush somehow
Posts: 10.8K,
Visits: 40.2K
I can't believe that is no easy to follow way to get a displacemnt map from zbush that work
I follow a pay tutorial , but it is was waste of moneyI :crazy:
Posts: 10.8K,
Visits: 40.2K
The easiest method to create a displacement map is to convert the diffuse map into a greyscale image and tweak the contrast and brightness. I want bake a map from sculpt als VD , therefore that is not what I looking for
Posts: 10.8K,
Visits: 40.2K
I would be interested to know if anyone ever created Vector Displacement Maps from zbrush like HD detailed Maps in DAZ and How? For what is this feature when nobody know how to create ? There are so many possibles with VD, and iclone can make it happen, but without concrete information it is not possible for me . Anyway, I can not get on
Rockoloco666
Rockoloco666
Visits: 2.0K
Posts: 10.8K,
Visits: 40.2K
I know how to create in Zbrush , but what I want to know how I import it corectly in iClone that it works
Posts: 10.8K,
Visits: 40.2K
BTW from this guide There are 48 possible combinations of export settings located in the Import Export Preferences, such as NormalMapFlipX or NormalMapFlipYZ that's like guesswork :hehe:
