GOZ Problem
Posted By vidi 7 Years Ago
ruscular
ruscular
Junior Member (161 reputation)Junior Member (161 reputation)Junior Member (161 reputation)Junior Member (161 reputation)Junior Member (161 reputation)Junior Member (161 reputation)Junior Member (161 reputation)Junior Member (161 reputation)Junior Member (161 reputation)
Posts: 32, Visits: 798
I also have revo uninstaller, so I did delete my CC3.4 and reinstall everything and it still shows up not activated on my account page, and Zbrush still says that it cant find CC3.4
But just out of curiosity I try using it and everything works. morph the object and sent it back to CC3.4 and it took. ?!?!?!? what can I say? Maybe Zbrush2021 is still too new and haven't work everything out? or that there is a bug in somewhere?
lianchiu
lianchiu
Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)
Posts: 214, Visits: 1.5K
https://forum.reallusion.com/uploads/images/b8338d3d-18e6-4ecd-98ef-a132.png
try this
Dan@3DIM (3/24/2021)
Same! I just start use goZ. Its broken again after update to 2021
Dan@3DIM
Dan@3DIM
Posts: 69, Visits: 791
3Divo
3Divo
New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)
Posts: 2, Visits: 21
I know this is an old post, but I have now encountered exactly the same after problem after upgrading to 3.32 and ZBrush 2021 (I upgraded both at the same time - stupid me:crazy:). I hadn't used this workflow for more than a year, but it worked fine as far as I remember.
What was the outcome of this , sylwester? Or has anyone recently had the same problem?
@ Peter: I am using my administrator account...
sylwester.hejduk (12/8/2019)
Anyone had any luck with that? Without GoZ CC 3.2 is not worth buying for me. I'm on Zbrush 2020, but it seems with 2019 it didn't work as well...
I've been wondering, why GoZ_Info file data looks so weird:
GOZ_OBJECT_LIST =   "../../GoZBrush/GoZ_ObjectList.txt"
GOZ_OBJECT_PATH =   "../../GoZBrush/GoZ_ObjectPath.txt"
MAKEOBJECTPATH_COMMAND = "../../GoZBrush/GoZMakeObjectPath.exe"
plus, batch file GoZLocateCC also mentions weird path: \GoZBrush\GoZLocateApp.exe
What the heck is GoZBrush\GoZLocateApp.exe ? I doubt there's such thing in Zbrush 2020. There was however, in 2018, I think. This is the key I guess - whenever I force Zbrush to update paths to CC, it works untill it runs the goddamn batch file looking for non-existing GoZLocateApp.exe.
Can someone from the devs let us know how to clear this out? I guess this batch process for CC 3.2 has not been properly updated to use with Zbrush 2020.
Please help!
Hi...
Sorry to hear you are having problems.
Please do ensure you have installed and are using ZBrush with an Administrator account. Most problems stem from this issue, but if you continue to have this issue please contact our Technical Support department using the link below. They will be able to advise you further. Thanks.
vidi
vidi
Last Active: 3 Weeks Ago
Posts: 10.8K, Visits: 40.2K
https://forum.reallusion.com/uploads/images/930f6ce5-56eb-4825-838a-1808.png
liebe Grüße vidi
sylwester.hejduk
sylwester.hejduk
New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)
Last Active: 3 Months Ago
Posts: 2, Visits: 18
vidi (12/8/2019)
Like I say in my  post above , it works for me now
Have you upgraded Zbrush to 2020? Regardless of that, please kindly share the contents of your folder:
C:\Users\Public\Pixologic\GoZApps\CharacterCreator
And maybe the contents of the presumably wrong batch file, GoZLocateCC  (if it's still there, in above mentioned folder).
Thanks!
vidi
vidi
liebe Grüße vidi
sylwester.hejduk
sylwester.hejduk
Please help!
Thanks.
Dan@3DIM
Dan@3DIM
Just did it three time in row. Don’t work. Bahhh
