Skydome and ground using Dome prop and FlowScape 360 image
Posted By 3dtester 6 Years Ago
3dtester
3dtester
Distinguished Member (5.1K reputation)Distinguished Member (5.1K reputation)Distinguished Member (5.1K reputation)Distinguished Member (5.1K reputation)Distinguished Member (5.1K reputation)Distinguished Member (5.1K reputation)Distinguished Member (5.1K reputation)Distinguished Member (5.1K reputation)Distinguished Member (5.1K reputation)
Last Active: 6 Months Ago
Posts: 999, Visits: 2.2K
I am trying to use 360 images generated from FlowScape as a sky in iClone.
For this test i am using a Dome prop, and applied a 360 image, exported from FlowScape using Ansel.
It is very likely that i'm doing something wrong, because the plants are not really visible.
Maybe the Dome is too small, which i was not able to fix for now, since it is already scaled to the max.
The texture size is 8K (also set at iClone preferences).
So here is a test video:
And here is the 360 image as a reference.
https://forum.reallusion.com/uploads/images/0ad8abf5-ec78-421d-a364-588b.jpg
As i said, i must be doing something wrong.
Threaded View
Threaded View
Forum Post Skydome and ground using Dome prop and FlowScape 360 image By 3dtester ( 6 Years Ago )
Forum Post Just did a very quick experiment. I created a sky and dragged and... By Galfridus ( 6 Years Ago )
Forum Post Geoff, I'm curious whether Zane's shadow appeared on the 'sky' or if... By gordryd ( 6 Years Ago )
Forum Post [quote][b]gordryd (8/6/2019)[/b][hr]Geoff, I'm curious whether Zane's... By Galfridus ( 6 Years Ago )
Forum Post [quote][b]Galfridus (8/6/2019)[/b][hr] Edit: Done a further quick... By 3dtester ( 6 Years Ago )
Forum Post Thanks! I just tried both variants (the Sky and the HDR / iBL slot).... By 3dtester ( 6 Years Ago )
Forum Post 3DTester, How big was your 360 file from Ansel? When I tried it, the... By gordryd ( 6 Years Ago )
Forum Post [quote][b]gordryd (8/6/2019)[/b][hr]3DTester, How big was your 360... By 3dtester ( 6 Years Ago )
Forum Post I'm not quite sure what kind of Dome prop you used, and what you... By tripfreak ( 6 Years Ago )
Forum Post Hi tipfreak, i used 'Dans Dome'. Seems you also used that in your... By 3dtester ( 6 Years Ago )
Forum Post This is my last test for now ;) HDRi / IBL Sky, Camera: 50mm lens Some... By 3dtester ( 6 Years Ago )
Forum Post Is there a way to set the resolution of the sky? Even though I'm... By gordryd ( 6 Years Ago )
Forum Post [quote][b]gordryd (8/7/2019)[/b][hr]Is there a way to set the... By animagic ( 6 Years Ago )
Forum Post [quote][b]animagic (8/7/2019)[/b][hr][quote][b]gordryd... By gordryd ( 6 Years Ago )
Forum Post I don't know if it is related, but i always have to uncheck 'Image' at... By 3dtester ( 6 Years Ago )
Forum Post I just realized that there are endless possibilities :laugh: Most... By 3dtester ( 6 Years Ago )
Forum Post [quote]At first i wanted to try the 'HDRI stage', converted for... By tripfreak ( 6 Years Ago )
Forum Post Thanks tipfreak. The 360Stage works pretty good! I like it :) By 3dtester ( 6 Years Ago )
