Audio Driven (July Sample Script)
Posted By Tony (RL) 7 Years Ago
3
Tony (RL)
Tony (RL)
Posts: 222, Visits: 1.7K
Hi Andreas,
Thank you so much for the submission.
We will review the plug-in and let you know the result.
The-any-Key (8/5/2019)
Ok. Finally finished my contribution to this mod contest.
https://marketplace.reallusion.com/music-move---trial
You can load music and it will get the beat. You can then make it do various animations when the beat come. Ex:
Tony
Product Marketing Manager
The-any-Key
The-any-Key
Posts: 356, Visits: 1.9K
iClone 7, 3DXchange 7 Pipeline, CC3 Pipeline, CT8 Pipeline, Iray, Live Face, iPhone Xr, Win 10, i9 9900K ~5GHz, Nvidia RTX 2080 8GB, 16GB Ram, M.2 SSD
I believe there might be a problem with RRgb class assigning a color value to the material.
I have a routine to create a smooth transition between Red, Green and Blue for the prop and I am getting random frames with Black color assigned instead of the designated color.
There is a lot of them...
2 screenshots of frames 8 and 9 (with color values dump into console).
Frame 8 - right color is assigned:
https://forum.reallusion.com/uploads/images/5eab7926-d1c9-4589-9e6c-f455.jpg
Frame 9 - black color is assigned out of nowhere:
https://forum.reallusion.com/uploads/images/a61ce0d0-15dc-4df1-88cf-44bf.jpg
    diffuse_color = RLPy.RRgb(r, g, b).Normalize()
    material_component.AddDiffuseKey(key, mesh_name, material_name, diffuse_color)
BTW, I am surprised there is no Case statement available in Python :ermm:
UPDATE: Suppose something is wrong with
Normalize()
I divided everything by 255 and ditched
Normalize(). Working just fine!
Multiplying color power is great BTW
So here, I used Audio Driven core to put together scripts, which drove some of the props for the visual response:
Chuck (RL) (7/17/2019)
4u2ges (7/17/2019)
(Sorry for the long post)
It says there: "# Derive frequency domain from a segment of 160 signals"
What does that mean? And why 160? Where that number comes from?
Let me take a stab at this, although disclaimer: I'm not a sound wave expert!  So take my explanation with a pinch of salt.
Even when audio is sampled at 44,100 Hz or higher, the human ear can only hear 20 Hz to 20 kHz.  Modern sampling rate goes as high as 192,000 Hz, so let's just assume that the max audible range is 19,200 Hz a nice factor of the max mechanical sampling rate.  19,200 divided by 60 iClone fps is 320 and since we only take the positive side of the amplitude we cut that in half to give us 160.
Thanks Chuck. Let's see if the rest would make sense when I continue *disassembling* it tonight.
Chuck (RL)
Chuck (RL)
Trainer
Trainer (1.2K reputation)Trainer (1.2K reputation)Trainer (1.2K reputation)Trainer (1.2K reputation)Trainer (1.2K reputation)Trainer (1.2K reputation)Trainer (1.2K reputation)Trainer (1.2K reputation)Trainer (1.2K reputation)
Posts: 227, Visits: 2.1K
4u2ges (7/17/2019)
Yesterday I tried to dig into Audio Driven script in attempt to create something different for myself and I am bit overwhelmed.
There are 2 crucial functions which I need from the script:
1. audio_to_spectrogram
2. spectrogram_to_value
I am OK with the first one (well, more or less). Though I lost it with fft signal processing.
But suppose I do not need to know HOW audio_spectrogram is built, because it is probably standard for ANY further value assignments.
What I really need, is to understand the audio_spectrogram array structure so I can create a simple routine:
Filter 2 frequency ranges - a "Hard beat" (probably between 20 and 200 Hz)  and a "Smooth Wave" (around 16 - 20 kHz) (I do not need a mid-range at all)
And then translate those 2 ranges amplitudes separately to some scale (0-100 for instance).
In attempt to better understand the structure I dumped to the Console the following from the loop (sort of reverse engineering):
    print(fft_abs)
Result is 106 groups of numbers (for 1.773 sec wav is about right number of iClone frames)
Here is a single sampled frame content:
[0.11150956 0.25723062 0.08865806 0.14261947 0.35034164 0.95271861
 0.77180765 1.18902709 4.77695489 3.19351255 2.43299415 1.42882515
 2.89056719 3.23675144 0.46677106 0.76576112 0.50855    1.04769554
 3.24744908 0.82136079 0.52342382 0.8870013  0.77720837 1.27814819
 1.75291115 1.5230229  2.40762168 2.12467929 2.04437209 1.19796097
 0.14390374 0.48898827 0.77696653 0.65896997 0.84872364 2.77168353
 0.62182953 0.0840715  0.59363135 0.05420146 1.06631399 0.56239089
 1.85929132 2.31630288 1.03320651 0.39651085 0.24630279 0.28349139
 0.2120239  0.13484599 0.11559678 0.10468502 0.0954504  0.06083779
 0.15067458 0.12987788 0.1691395  0.33406639 0.16874957 0.45563993
 0.33092178 0.38230812 0.17556105 0.70744437 0.2467003  1.03477113
 0.63736083 0.71204789 0.52903696 0.23563739 0.11254837 0.24727394
 0.37085328 0.49383915 0.21563008 0.28507491 0.54850175 2.77919332
 1.56778496 1.34671397 0.70773272 0.21522238 0.59130217 1.07373824
 0.24710162 0.53101785 1.00014957 0.38657898 0.67077908 0.52113286
 1.75167786 0.80068758 0.9005741  0.276603   1.7392084  1.82330498
 0.77034732 1.06487673 0.38866614 0.26912587 0.31042891 1.77936532
 0.64409742 0.52655199 0.49242897 1.08934718 0.50919374 3.1518447
 1.11932983 1.08887643 0.15766056 0.22869077 0.29967342 1.77338149
 0.56163879 1.39084035 1.80432576 1.46165834 0.83674582 0.27736511
 0.63598491 1.47150863 0.5986844  0.19184856 0.4096564  0.37384439
 0.63514997 0.18030894 0.40751641 0.12279016 0.21885917 0.24109634
 0.68227292 0.16547404 0.6008949  0.29243988 0.15307243 0.35350271
 0.73112761 0.08970516 0.21179237 0.13587826 0.10938051 0.13771398
 0.58163572 0.34767222 0.24000406 0.16353447 0.18655791 0.45121205
 0.13052829 0.12671041 0.31687109 0.57070711 0.15643487 0.44449939
 0.24323215 0.28844307 0.11622413 0.04674734 0.22112062 0.30112983
 0.23626635 0.09739269 0.22203083 0.10051502 0.19820335 0.1683452
 0.33237137 0.33166428 0.08851533 0.43111514 0.20603584 0.0973033
 0.09174958 0.08245126 0.02493859 0.29208872 0.25614368 0.15274507
 0.1494195  0.02537298 0.03503722 0.04417663 0.01018429 0.02329054
 0.08388038 0.24216378 0.07371142 0.21777574 0.08832298 0.04154081
 0.10838715 0.17016504 0.08851597 0.08117208 0.18640594 0.19730835
 0.22404092 0.13889349 0.36618105 0.2982956  0.27594938 0.14094833
 0.25682853 0.10210291 0.06375692 0.08733063 0.01776444 0.0504968
 0.14075256 0.02556287 0.25705788 0.01771428 0.01066642 0.03975817
 0.09502241 0.22844293 0.08399003 0.02156999 0.03714909 0.04872499
 0.23168574 0.17439931 0.12584799 0.00548699 0.02107726 0.01491974
 0.08920536 0.11376578 0.06185278 0.04880594 0.0498625  0.01610776
 0.04961902 0.03622142 0.03234377 0.02982717 0.08341837 0.06429129
 0.04581403 0.06817268 0.03275356 0.02889231 0.04015762 0.03917378
 0.07482373 0.07681092 0.04184848 0.00596598 0.05676727 0.09020718
 0.06368601 0.21919096 0.0733701  0.04725462 0.06236765 0.04885768
 0.0373921  0.01421165 0.04765336 0.03694735 0.03303088 0.03086083
 0.030988   0.02921685 0.03095408 0.03055253 0.02982576 0.02991376
 0.02973645 0.02922301 0.02922083 0.02879407 0.029383   0.02931702
 0.02803401 0.02849017 0.02858922 0.0292728  0.02858342 0.02882736
 0.02896087 0.02853854 0.02829262 0.02868207 0.02861265 0.02874227
 0.02907272 0.02851239 0.02835951 0.02847763 0.02803881 0.02801584
 0.02831999 0.02839959 0.02799038 0.0285909  0.02875205 0.02800037
 0.02794852 0.02811474 0.02756481 0.02795735 0.02820274 0.02811454
 0.02817428 0.02792826 0.0276992  0.0283763  0.02781939 0.02810712
 0.02851885 0.02817769 0.02776258 0.02811209 0.02806366 0.02765051
 0.02751835 0.02729862 0.02701069 0.02749094 0.02812452 0.02819064
 0.02712007 0.02700188 0.02714349 0.02754664 0.02724389 0.0274406
 0.02806957 0.0276     0.02738082 0.02737823 0.02726042 0.0268806
 0.02707177 0.02732006 0.02734533 0.02731668 0.02724605 0.02762236
 0.02808626 0.02649266 0.02660802 0.02743208 0.02786796 0.02820454
 0.02777062 0.02713335 0.0272746  0.02720932 0.02732232 0.02755141
 0.02735785 0.0268071  0.02775384 0.02786173 0.02847259 0.02768545
 0.02680469 0.02740702 0.02695009 0.02701072 0.02783906 0.02660854]
There are 366 numbers in a single frame group. Each number represents an amplitude. Right?
So the question is, how frequencies range is distributed across the group? What is the total range?
Does it cover standard 20 Hz - 20 kHz (given high quality audio clip)?
Feel free to elaborate. Thanks.
Last Active: 5 Months Ago
toystorylab (7/16/2019)
Though I noticed that "Audio Driven" does not accept every .wav-file.
And those which did not work were professional commercial files...
Is it possible that the naming of a .wav-file: "D#_Sniper (150)" causes the problem??
The process remained at 0%...
Check the sample rate: 48k is the maximum that iClone accepts. Some professional files are now 96k. You can easily convert this with Audacity.
The name should be OK, but you can always rename.
duchess110
duchess110
Posts: 2.0K, Visits: 15.5K
Back in 2017 I managed to create something similar using audio float and bringing into iClone as an iprop.
It was when we were beta testing the curve editor I believe and up until now they have been hidden on YouTube so
I thought I would share with you now.
Update by duchess110 had a tidy up on You Tube and I have removed these videos.
Duchess Designs Store
toystorylab
toystorylab
Posts: 4.6K, Visits: 29.9K
Thanx again, it works ;)
rosuckmedia
rosuckmedia
Posts: 3.2K, Visits: 4.8K
@The-any- Key
Here is my example Greetings Robert
3
