By Tony (RL) - 7 Years Ago
1. Audio Driven - Sample Script of July 2019
In the last Python of the Month, the Reallusion Python Team introduced Smooth Camera Follow and related Python courses, teaching you to create Transformation Methods, Float Slider Widget, and other basic iClone functionalities with the Python API.
This time we'd like to bring out another sample script - Audio Driven, and five fundamental courses for you. Through the script and courses, you can learn how to create an Audio Visualizer, clone props, and build UI like a Color Picker and Progress Bar.
The Audio Driven Script can let users pick an audio file in wave format and apply an interpretation of it in movement to a selection of props. - You can Download the script from the Marketplace.
- To explore how it works, please visit our Python Wiki
- To get the source code, please visit our GitHub
Important Notice: iClone 7.5 is Required PS: If you have any questions about the plug-in and its code, please feel free to let us know by replying to this post
2. Related Fundamental Courses
Please be sure to start from the fundamental courses if you are interested to know how this sample code works
- Progress Bar- this article will go over the creation of a progress bar as one of the fundamental building blocks of a functional user interface.
- Animated Material - in this article, we'll go over the steps required to create a flashing light material.
- Audio Visualizer - how to make an audio visualizer, including UI, Audio Bit-Depth, Plotting the Signals, and Reading the Audio File.
- File Path - oftentimes, you'll need to handle external files in the form of loading, writing and reading. This article will go over doing just that with Python scripting.
- Color Picker - this article will go over the creation of a color picker and how we can leverage Qt in dealing with the color hex data.
For more courses, please visit Here
3. Ultimate Script Mod Contest
 Reallusion is offering some rewards to encourage iClone developers who are able to creatively modify the Audio Driven script and submit it in the Marketplace.
There is no limitation of the modification, so please leverage your creativity to make the script better, such as adding new functions or making the UI more user-friendly.
The contest will end on 8/31.
The standard for evaluation of a rewarded plug-in:
- Practicality - 50%
- Degrees of Perfection - 30%
- Creativity - 20%
Reward - We will reward $300 USD to those who develop plug-ins that meet our standard of excellence.
- We will reward 10,000 DA points to those who develop plug-ins that meet the basic standard.
Sign Up - You need to first register in the Reallusion Developer Center to become a plug-in developer.
- After a successful registration, you can follow the guideline in the Developer Center to submit plug-in(s) in the Marketplace.
Important: acceptable plug-in files for uploading are; .py, .pyd, or .zip format. - After the submission, please post the links to your plug-ins in this thread to officially join the Showcase Collection Program.
- We will send you a Forum private message to give you information on your reward once your plug-in(s) reach the standards.
Start to Create Your Own iClone Plug-in
Interested in customizing and expanding iClone features by yourself? Check out iClone OPEN for related links and resources.
By The-any-Key - 7 Years Ago
Got a great idea for this one :-)
By toystorylab - 7 Years Ago
My first step into Python... (I am still on 7.3)
Smooth Camera works, Audio Driven does not appear in the Python Samples, though saved at the same place as Smooth Camera:
Any idea what could cause this??
toystorylab (7/11/2019)
My first step into Python... (I am still on 7.3) Smooth Camera works, Audio Driven does not appear in the Python Samples, though saved at the same place as Smooth Camera:   Any idea what could cause this?? You need to install the nesseary python modules that the audio driven sample use.
By rosuckmedia - 7 Years Ago
@ The-any-Key Ican not do that either, what are the necessary Python modules? Use the Devloper version. Greetings Robert
Same here, not sure what to "install", use latest dev-version...
By Kelleytoons - 7 Years Ago
I'm sure "Key" will reply but in the meantime you can always tell what you need by looking at the "import" section (normally located at the top of the script).
RLPy is standard, so no problem there. And some other stuff like os and PySide2 is standard. But things like:
import PIL
or in the case of audio:
import soundfile import wave
you may need to load external modules in. You will get an error at the appropriate line to tell you what's missing (I'll look at it this afternoon if Key hasn't yet responded).
You need to install
numpy scipy
@ Kellytoons Thank you @ The-any-Key That with her auto installer worked, but with the command prompt, because I prefer to read the fingers away, I have no desire to shoot my system. All other plugins are working Nevertheless, many thanks for your effort. Greetings Robert
The-any-Key (7/11/2019) Hmm. Maybe I should update my autoplugin so you can type in what modules you want to automatically install. As i am a technical laggard and very cautious with "command prompt" i did not do it :blush: So, if your autoplugin could do that, would be cool... How many of those "installs" would be needed for everything based on Python?? Would it make sense to install all those (with your "Auto Plugin ;)) at once?
The-any-Key (7/11/2019) Hmm. Maybe I should update my autoplugin so you can type in what modules you want to automatically install.As i am a technical laggard and very cautious with "command prompt" i did not do it :blush:So, if your autoplugin could do that, would be cool... How many of those "installs" would be needed for everything based on Python?? Would it make sense to install all those (with your "Auto Plugin ;)) at once? It would be more like: 1# start iClone in admin mode 2# start auto install plugin 3# type in module name to install (in this case numpy and then scipy) 4# click install 5# done
The problem is you can't install "everything" -- there will always be more modules and there isn't any point in installing ones you do not need (some are esoteric). You might want to install some of the more commonly used ones, but even there you will find diversity of opinions.
I have about five installed and have not needed any more -- but there are dozens of good ones (hundreds?).
The-any-Key (7/11/2019) It would be more like: 1# start iClone in admin mode 2# start auto install plugin 3# type in module name to install (in this case numpy and then scipy) 4# click install 5# done Sounds good ;)
Kelleytoons (7/11/2019) The problem is you can't install "everything" -- there will always be more modules and there isn't any point in installing ones you do not need (some are esoteric). You might want to install some of the more commonly used ones, but even there you will find diversity of opinions. I have about five installed and have not needed any more -- but there are dozens of good ones (hundreds?). Thanx for explaining... As already said, I'm not a "technic-guy" and never used Python (regular IC is still 7.3) but usefull "ready-made" plugins based on Python used in a standalone Dev-Version are welcome :D
@ The-any-Key That would be nice, then I would try again. Greetings Robert:)
Intel i9-9900K 5,0 GHz, Nvidia Geforce MSI RTX 2080 8GB, 16GB DDR 4 RAM-3000 Mhz, 500 SSD+ 2 Terrabite HDD.
The-any-Key (7/11/2019) It would be more like: 1# start iClone in admin mode 2# start auto install plugin 3# type in module name to install (in this case numpy and then scipy) 4# click install 5# doneSounds good ;) Fixed: https://marketplace.reallusion.com/auto-install https://the-any-key.itch.io/auto-install-pip-in-iclone
@ The-any-key, Great, thank you very much,-and the developer of this plugin. Greetings Robert
Thanx a lot! Will try this out in the next hour...
@The-any- Key Here is my example Greetings Robert
Thanx again, it works ;)
Though I noticed that "Audio Driven" does not accept every .wav-file. And those which did not work were professional commercial files... Is it possible that the naming of a .wav-file: "D#_Sniper (150)" causes the problem?? The process remained at 0%...
By duchess110 - 7 Years Ago
Back in 2017 I managed to create something similar using audio float and bringing into iClone as an iprop. It was when we were beta testing the curve editor I believe and up until now they have been hidden on YouTube so I thought I would share with you now.
Update by duchess110 had a tidy up on You Tube and I have removed these videos.
By animagic - 7 Years Ago
toystorylab (7/16/2019) Though I noticed that "Audio Driven" does not accept every .wav-file. And those which did not work were professional commercial files... Is it possible that the naming of a .wav-file: "D#_Sniper (150)" causes the problem?? The process remained at 0%...
Check the sample rate: 48k is the maximum that iClone accepts. Some professional files are now 96k. You can easily convert this with Audacity.
The name should be OK, but you can always rename.
By 4u2ges - 7 Years Ago
(Sorry for the long post)
Yesterday I tried to dig into Audio Driven script in attempt to create something different for myself and I am bit overwhelmed.
There are 2 crucial functions which I need from the script: 1. audio_to_spectrogram 2. spectrogram_to_value
I am OK with the first one (well, more or less). Though I lost it with fft signal processing. It says there: "# Derive frequency domain from a segment of 160 signals" What does that mean? And why 160? Where that number comes from? But suppose I do not need to know HOW audio_spectrogram is built, because it is probably standard for ANY further value assignments.
What I really need, is to understand the audio_spectrogram array structure so I can create a simple routine: Filter 2 frequency ranges - a "Hard beat" (probably between 20 and 200 Hz) and a "Smooth Wave" (around 16 - 20 kHz) (I do not need a mid-range at all) And then translate those 2 ranges amplitudes separately to some scale (0-100 for instance).
In attempt to better understand the structure I dumped to the Console the following from the loop (sort of reverse engineering): print(fft_abs)
Result is 106 groups of numbers (for 1.773 sec wav is about right number of iClone frames) Here is a single sampled frame content: -------------------------------------------- [0.11150956 0.25723062 0.08865806 0.14261947 0.35034164 0.95271861 0.77180765 1.18902709 4.77695489 3.19351255 2.43299415 1.42882515 2.89056719 3.23675144 0.46677106 0.76576112 0.50855 1.04769554 3.24744908 0.82136079 0.52342382 0.8870013 0.77720837 1.27814819 1.75291115 1.5230229 2.40762168 2.12467929 2.04437209 1.19796097 0.14390374 0.48898827 0.77696653 0.65896997 0.84872364 2.77168353 0.62182953 0.0840715 0.59363135 0.05420146 1.06631399 0.56239089 1.85929132 2.31630288 1.03320651 0.39651085 0.24630279 0.28349139 0.2120239 0.13484599 0.11559678 0.10468502 0.0954504 0.06083779 0.15067458 0.12987788 0.1691395 0.33406639 0.16874957 0.45563993 0.33092178 0.38230812 0.17556105 0.70744437 0.2467003 1.03477113 0.63736083 0.71204789 0.52903696 0.23563739 0.11254837 0.24727394 0.37085328 0.49383915 0.21563008 0.28507491 0.54850175 2.77919332 1.56778496 1.34671397 0.70773272 0.21522238 0.59130217 1.07373824 0.24710162 0.53101785 1.00014957 0.38657898 0.67077908 0.52113286 1.75167786 0.80068758 0.9005741 0.276603 1.7392084 1.82330498 0.77034732 1.06487673 0.38866614 0.26912587 0.31042891 1.77936532 0.64409742 0.52655199 0.49242897 1.08934718 0.50919374 3.1518447 1.11932983 1.08887643 0.15766056 0.22869077 0.29967342 1.77338149 0.56163879 1.39084035 1.80432576 1.46165834 0.83674582 0.27736511 0.63598491 1.47150863 0.5986844 0.19184856 0.4096564 0.37384439 0.63514997 0.18030894 0.40751641 0.12279016 0.21885917 0.24109634 0.68227292 0.16547404 0.6008949 0.29243988 0.15307243 0.35350271 0.73112761 0.08970516 0.21179237 0.13587826 0.10938051 0.13771398 0.58163572 0.34767222 0.24000406 0.16353447 0.18655791 0.45121205 0.13052829 0.12671041 0.31687109 0.57070711 0.15643487 0.44449939 0.24323215 0.28844307 0.11622413 0.04674734 0.22112062 0.30112983 0.23626635 0.09739269 0.22203083 0.10051502 0.19820335 0.1683452 0.33237137 0.33166428 0.08851533 0.43111514 0.20603584 0.0973033 0.09174958 0.08245126 0.02493859 0.29208872 0.25614368 0.15274507 0.1494195 0.02537298 0.03503722 0.04417663 0.01018429 0.02329054 0.08388038 0.24216378 0.07371142 0.21777574 0.08832298 0.04154081 0.10838715 0.17016504 0.08851597 0.08117208 0.18640594 0.19730835 0.22404092 0.13889349 0.36618105 0.2982956 0.27594938 0.14094833 0.25682853 0.10210291 0.06375692 0.08733063 0.01776444 0.0504968 0.14075256 0.02556287 0.25705788 0.01771428 0.01066642 0.03975817 0.09502241 0.22844293 0.08399003 0.02156999 0.03714909 0.04872499 0.23168574 0.17439931 0.12584799 0.00548699 0.02107726 0.01491974 0.08920536 0.11376578 0.06185278 0.04880594 0.0498625 0.01610776 0.04961902 0.03622142 0.03234377 0.02982717 0.08341837 0.06429129 0.04581403 0.06817268 0.03275356 0.02889231 0.04015762 0.03917378 0.07482373 0.07681092 0.04184848 0.00596598 0.05676727 0.09020718 0.06368601 0.21919096 0.0733701 0.04725462 0.06236765 0.04885768 0.0373921 0.01421165 0.04765336 0.03694735 0.03303088 0.03086083 0.030988 0.02921685 0.03095408 0.03055253 0.02982576 0.02991376 0.02973645 0.02922301 0.02922083 0.02879407 0.029383 0.02931702 0.02803401 0.02849017 0.02858922 0.0292728 0.02858342 0.02882736 0.02896087 0.02853854 0.02829262 0.02868207 0.02861265 0.02874227 0.02907272 0.02851239 0.02835951 0.02847763 0.02803881 0.02801584 0.02831999 0.02839959 0.02799038 0.0285909 0.02875205 0.02800037 0.02794852 0.02811474 0.02756481 0.02795735 0.02820274 0.02811454 0.02817428 0.02792826 0.0276992 0.0283763 0.02781939 0.02810712 0.02851885 0.02817769 0.02776258 0.02811209 0.02806366 0.02765051 0.02751835 0.02729862 0.02701069 0.02749094 0.02812452 0.02819064 0.02712007 0.02700188 0.02714349 0.02754664 0.02724389 0.0274406 0.02806957 0.0276 0.02738082 0.02737823 0.02726042 0.0268806 0.02707177 0.02732006 0.02734533 0.02731668 0.02724605 0.02762236 0.02808626 0.02649266 0.02660802 0.02743208 0.02786796 0.02820454 0.02777062 0.02713335 0.0272746 0.02720932 0.02732232 0.02755141 0.02735785 0.0268071 0.02775384 0.02786173 0.02847259 0.02768545 0.02680469 0.02740702 0.02695009 0.02701072 0.02783906 0.02660854] -------------------------------------------- There are 366 numbers in a single frame group. Each number represents an amplitude. Right? So the question is, how frequencies range is distributed across the group? What is the total range? Does it cover standard 20 Hz - 20 kHz (given high quality audio clip)? Feel free to elaborate. Thanks.
By Chuck (RL) - 7 Years Ago
4u2ges (7/17/2019) (Sorry for the long post)
Let me take a stab at this, although disclaimer: I'm not a sound wave expert! So take my explanation with a pinch of salt.
Even when audio is sampled at 44,100 Hz or higher, the human ear can only hear 20 Hz to 20 kHz. Modern sampling rate goes as high as 192,000 Hz, so let's just assume that the max audible range is 19,200 Hz a nice factor of the max mechanical sampling rate. 19,200 divided by 60 iClone fps is 320 and since we only take the positive side of the amplitude we cut that in half to give us 160.
Chuck (RL) (7/17/2019)
Let me take a stab at this, although disclaimer: I'm not a sound wave expert! So take my explanation with a pinch of salt. Even when audio is sampled at 44,100 Hz or higher, the human ear can only hear 20 Hz to 20 kHz. Modern sampling rate goes as high as 192,000 Hz, so let's just assume that the max audible range is 19,200 Hz a nice factor of the max mechanical sampling rate. 19,200 divided by 60 iClone fps is 320 and since we only take the positive side of the amplitude we cut that in half to give us 160. Thanks Chuck. Let's see if the rest would make sense when I continue *disassembling* it tonight.
I believe there might be a problem with RRgb class assigning a color value to the material. I have a routine to create a smooth transition between Red, Green and Blue for the prop and I am getting random frames with Black color assigned instead of the designated color. There is a lot of them...
2 screenshots of frames 8 and 9 (with color values dump into console).
Frame 8 - right color is assigned:
Frame 9 - black color is assigned out of nowhere:
diffuse_color = RLPy.RRgb(r, g, b).Normalize() material_component.AddDiffuseKey(key, mesh_name, material_name, diffuse_color)
BTW, I am surprised there is no Case statement available in Python :ermm:
UPDATE: Suppose something is wrong with Normalize() I divided everything by 255 and ditched Normalize(). Working just fine!
Multiplying color power is great BTW =================================
So here, I used Audio Driven core to put together scripts, which drove some of the props for the visual response:
Ok. Finally finished my contribution to this mod contest. https://marketplace.reallusion.com/music-move---trial
You can load music and it will get the beat. You can then make it do various animations when the beat come. Ex:
Hi Andreas,
Thank you so much for the submission.
We will review the plug-in and let you know the result.
