toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Thanx a lot! Will try this out in the next hour...
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
@ The-any-key, Great, thank you very much,-and the developer of this plugin. Greetings Robert
The-any-Key
The-any-Key
Visits: 1.9K
toystorylab (7/11/2019)
The-any-Key (7/11/2019) It would be more like: 1# start iClone in admin mode 2# start auto install plugin 3# type in module name to install (in this case numpy and then scipy) 4# click install 5# doneSounds good ;) Fixed: https://marketplace.reallusion.com/auto-installhttps://the-any-key.itch.io/auto-install-pip-in-iclone
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
Hmm. Maybe I should update my autoplugin so you can type in what modules you want to automatically install.
@ The-any-Key That would be nice, then I would try again. Greetings Robert:)
Intel i9-9900K 5,0 GHz, Nvidia Geforce MSI RTX 2080 8GB, 16GB DDR 4 RAM-3000 Mhz, 500 SSD+ 2 Terrabite HDD.
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Kelleytoons (7/11/2019) The problem is you can't install "everything" -- there will always be more modules and there isn't any point in installing ones you do not need (some are esoteric). You might want to install some of the more commonly used ones, but even there you will find diversity of opinions. I have about five installed and have not needed any more -- but there are dozens of good ones (hundreds?).Thanx for explaining... As already said, I'm not a "technic-guy" and never used Python (regular IC is still 7.3) but usefull "ready-made" plugins based on Python used in a standalone Dev-Version are welcome :D
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Visits: 22.1K
The-any-Key
The-any-Key
Visits: 1.9K
The-any-Key (7/11/2019) Hmm. Maybe I should update my autoplugin so you can type in what modules you want to automatically install.As i am a technical laggard and very cautious with "command prompt" i did not do it :blush:So, if your autoplugin could do that, would be cool... How many of those "installs" would be needed for everything based on Python?? Would it make sense to install all those (with your "Auto Plugin ;)) at once? It would be more like: 1# start iClone in admin mode 2# start auto install plugin 3# type in module name to install (in this case numpy and then scipy) 4# click install 5# done
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
@ Kellytoons Thank you @ The-any-Key That with her auto installer worked, but with the command prompt, because I prefer to read the fingers away, I have no desire to shoot my system. All other plugins are working Nevertheless, many thanks for your effort. Greetings Robert
