TopOneTone
TopOneTone
Visits: 3.2K
I have a vague recollection that this issue has been raised before, so I hope someone can help me solve this. I have a scene where I have used one of the terrains "Danube Riverside" from "Terrains of the world" when I load any CC character, the characters clothing distorts as per image. When I delete the terrain and bring the character back in there is no distortion. If I then add the terrain back in, the character does not distort, but if I add a new character that will distort. Ok I think I've now been able to establish that the glitch is in that specific terrain as when I load another terrain from the pack the problem doesn't seem to exist. Still curious to know if anyone knows if there is a solution...in the meantime I'll use another terrain.
Last Active: 10 days ago
Posts: 8.2K,
Visits: 62.6K
It happens with any terrain. It seems to be partially solved. I have it happen if I load a terrain that is above the grid. Try putting your terrain below the grid. As for the height-map terrain, you just have work around it as your doing.
mr_vidius
mr_vidius
Last Active: 6 days ago
Visits: 6.1K
this should be fixed in iclone 7. heh, heh, heh....
TopOneTone
TopOneTone
Visits: 3.2K
Weird Science....thanks!
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
This error has already been fixed. He has been back since the last IC update. He is concerned again only the CC-Avatare (no matter whether Natalie and Christian or himself created) and mainly Highmap terrain. (No matter whether present or self-made) The tip of Rampa works and is perfectly correct .. It is synonymous, if you load the Avtare before and then the terrain. It's a pity that some mistakes just appear again and again and seem to be irredeemable. Therefore, in the feedback tracker a tread to open up I think therefore quite meaningless.
Likewise, some older Avatars IC 6 simply mercilessly crash.E.g. Santa Clause from this package (The girls work)"Christmas character" http://www.reallusion.com/ContentStore/csproduct.aspx?contentid=AIC300DIENU010620081114001 Whoever has it can even try it himself. Too bad the part is already "Uralt" but always gladly used (especially for the coming Christmas season). I still have some "old Haudegen (G2 - G3) which cause the same problem.
Greetings from Germany Postfrosch (Werner)
taceterry
taceterry
Last Active: 8 Years Ago
Visits: 34
Fixed by iclone 7. I will never tell you but........
Visits: 31.4K
OK, I ran into that too. It definitely was fixed, but is broken again...:crazy: BTW, you can't blame the Feedback Tracker, it is a way to report these things and get noticed.
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
I put it in the feedback tracker Greetings from Postfrosch http://www.reallusion.com/FeedBackTracker/Issue/CC-Avatar-clothing-is-destroyed-when-loading-on-a-terrain
Visits: 31.4K
As it was deemed unreproducible by RL, I have added precise steps in a comment. I also remembered the workaround we (I think Rampa) came up with. Load your CC character (without a terrain present) uncheck Foot Contact, and resave. The problem only seems to occur when Foot Contact is checked for the CC character when it's loaded.
Visits: 31.4K
As a follow up, RL could now reproduce the issue, and a fix has been announced for IC 6.52.
