CC Character & Terrain Issue
Posted By TopOneTone 10 Years Ago
TopOneTone
TopOneTone
Posted 10 Years Ago
Posts: 329, Visits: 3.2K
I have a vague recollection that this issue has been raised before, so I hope someone can help me solve this.
I have a scene where I have used one of the terrains "Danube Riverside" from "Terrains of the world" when I load any CC character, the characters clothing distorts as per image. When I delete the terrain and bring the character back in there is no distortion. If I then add the terrain back in, the character does not distort, but if I add a new character that will distort. https://forum.reallusion.com/uploads/images/bc94e0ab-34f3-40cc-85cf-e989.jpg
Ok I think I've now been able to establish that the glitch is in that specific terrain as when I load another terrain from the pack the problem doesn't seem to exist. Still curious to know if anyone knows if there is a solution...in the meantime I'll use another terrain.
Posted 10 Years Ago
Posts: 8.2K, Visits: 62.6K
It happens with any terrain. It seems to be partially solved. I have it happen if I load a terrain that is above the grid. Try putting your terrain below the grid. As for the height-map terrain, you just have work around it as your doing.
mr_vidius
mr_vidius
Posted 10 Years Ago
Posts: 433, Visits: 6.1K
this should be fixed in iclone 7. heh, heh, heh....
TopOneTone
TopOneTone
Posted 10 Years Ago
Weird Science....thanks!
Postfrosch
Postfrosch
Posted 10 Years Ago
Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)
Posts: 6.9K, Visits: 18.4K
This error has already been fixed. He has been back since the last IC update.
He is concerned again only the CC-Avatare (no matter whether Natalie and Christian or himself created) and mainly Highmap terrain. (No matter whether present or self-made) The tip of Rampa works and is perfectly correct .. It is synonymous, if you load the Avtare before and then the terrain.
It's a pity that some mistakes just appear again and again and seem to be irredeemable. Therefore, in the feedback tracker a tread to open up I think therefore quite meaningless.
Likewise, some older Avatars IC 6 simply mercilessly crash.E.g. Santa Clause from this package (The girls work)"Christmas character"
http://www.reallusion.com/ContentStore/csproduct.aspx?contentid=AIC300DIENU010620081114001
Whoever has it can even try it himself. Too bad the part is already "Uralt" but always gladly used (especially for the coming Christmas season). I still have some "old Haudegen (G2 - G3) which cause the same problem.
Greetings from Germany
Postfrosch (Werner)
taceterry
taceterry
Posted 10 Years Ago
Senior Member (415 reputation)Senior Member (415 reputation)Senior Member (415 reputation)Senior Member (415 reputation)Senior Member (415 reputation)Senior Member (415 reputation)Senior Member (415 reputation)Senior Member (415 reputation)Senior Member (415 reputation)
Last Active: 8 Years Ago
Posts: 16, Visits: 34
Fixed by iclone 7. I will never tell you but........
Posted 10 Years Ago
Posts: 15.8K, Visits: 31.4K
OK, I ran into that too. It definitely was fixed, but is broken again...:crazy: BTW, you can't blame the Feedback Tracker, it is a way to report these things and get noticed.
Postfrosch
Postfrosch
Posted 10 Years Ago
I put it in the feedback tracker
Greetings from Postfrosch
http://www.reallusion.com/FeedBackTracker/Issue/CC-Avatar-clothing-is-destroyed-when-loading-on-a-terrain
Posted 10 Years Ago
As it was deemed unreproducible by RL, I have added precise steps in a comment.
I also remembered the workaround we (I think Rampa) came up with. Load your CC character (without a terrain present) uncheck Foot Contact, and resave. The problem only seems to occur when Foot Contact is checked for the CC character when it's loaded.
Posted 10 Years Ago
As a follow up, RL could now reproduce the issue, and a fix has been announced for IC 6.52.
