Simple Bodysuit With Blender Tutorial
Posted By Rampa 10 Years Ago
Rated 5 stars based on 4 votes.
3
4
5
6
7
8
Last Active: 4 days ago
This method still works as a way to rig your clothing to a CC base, but there is another option now if you have CC3 Pipeline.
That clothing would have either been some experiment that I did not keep, or some purchased content. So no, not available from me. Sorry.
I have experimented with a couple clothing creation applications. Not being one to spring for Marvelous Designer, I got a Blender plugin for sewing clothing called "Blender Garment Tool".
ryanmm
ryanmm
Posts: 1, Visits: 14
Thanks for the great info. I have successfully created the body suit. I was wondering if you were able to offer guidance on how you created the top and pants that can be seen in your accessory tab in the video. Or better yet, supply the files for this?
https://forum.reallusion.com/uploads/images/cda52b06-7724-4e03-965b-49b3.jpg
Your getting really close! :)
Lord Ashes
Lord Ashes
Last Active: 6 Months Ago
Posts: 1.3K, Visits: 1.6K
I have followed the tutorial but when I get to the Transfer Weights my Blender (v 2.77) has somewhat different options. It seems that the defaults are not the correct settings because after I Transfer Weights (from the CC Body to my Cloth) then when I pose the character (as per the tutorial) the Cloth does not move with the rig (bones).
https://forum.reallusion.com/uploads/images/c2fb7ced-33ba-4111-b6ea-de45.png
Any idea what the Blender 2.77 settings should be?
UPDATE: I got it working. I am not sure if my problem was that I was selecting multiple CC meshes for the Weight Transfer or that the setting needs to be changed to "Source: By Name, Dest: All Layers".
Lord Ashes
Lord Ashes
Thanks for the quick reply. I will review the provided tutorial and hopefully that will resolve my issue. Thanks.
You need to parent with empty groups instead, and then transfer the weights from the body mesh.
Lord Ashes
Lord Ashes
I have followed the Bodysuit tutorial and was able to reproduce the results with no issue. Excellent tutorial.
However, the one key point which that tutorial dodges, which is eluding me, is that the mesh does not need to be added to the armature because copying the mesh from the original character mesh (which was already attached to the armature) causes the new mesh to also be attached to the armature. This is great if you want to make body tight clothing like the bodysuit but in most cases you want to use a custom mesh which you would attach to the CC character armature.
I am a Blender newbie but I searched the internet for the steps on how to do this using Blander's auto weight function.
As such, I did:
1. Imported CC template FXB file into Blender
2. Imported my custom mesh as an OBJ into Blender
3. Selected the custom mesh and shift selected the armature
4. Used CTRL+P and selected Armature with Auto Weights
This produced an armature with the custom mesh attached to it. Using the wrench icon, I verified that the custom mesh now had a armature modifier (same as the tutorial for the bodysuit).
The problem that I have run into is that when I exported the results using the same settings as the bodysuit tutorial, the resulting FXB will not import into CC. It keeps giving me a "Failed To Load The File" error. From the fact that the bodysuit tutorial worked for me, it seems that there is some issue with the mapping of the mesh to the armature using the automatic weights function. Of course, being a Blender newbie it could be an issue with my process as opposed to an actual problem with Blender.
Has anyone been able to do this in blender? If so, is there something in my steps that I am doing incorrectly?
Any assistance in resolving this issue would be greatly appreciated.
Cary B
Cary B
Last Active: 5 Months Ago
Posts: 478, Visits: 3.8K
Thanks Rampa. I now have another question about Character Creator, probably something simple I am overlooking.
I watched a tutorial for the mesh editing in CC, using the calibration poses. It worked fine in the tutorial. But when I try to edit a mesh in a calibration pose, it reverts automatically to the T-pose. What am I doing wrong?
https://forum.reallusion.com/uploads/images/848c8492-ac67-42c2-9d27-461e.jpg
Shadoesword (8/25/2016)
I have also had issues with CC crashing when I try to bring in the fbx file from Blender. One weird thing I noticed is that the fbx templates from RL do not show the armature or the skeleton in Blender. It is there there in your tutorial, but not when I open them in Blender. The scene tree shows it, but clicking the little eyeball does nothing to turn it on or off.
Just in case those pesky bones go hiding again, there is an option to set them to X-ray. That is what makes them show through the body and clothing.
Oh, and glad the tutorial is helpful! :)
https://forum.reallusion.com/uploads/images/35ef7335-8ca7-4f80-acb8-c92a.jpg
Cary B
Cary B
The new version version of Blender seems to have solved my crashing problems as well. I just want to say thanks, Rampa, for this tutorial and all your other great help to inexperienced users like myself.
3
4
5
6
7
8
