urbanlamb
urbanlamb
Posted 11 Years Ago
Posts: 1.2K,
Visits: 3.5K
here is a bug ..basicaly i can't use iclone right now as a result the tilt/rotate button icons and the numerical pad that opens up on the face puppet .. wont toggle off and you can't type any numbers. Its only of course on the one i am using.. the custom 3dexchange button menu's for putting in expressions. I also put in a support ticket .. as basically it makes the face puppet useless unless you like head rotations.. You try to click to turn it off or type in numbers and it unselects the icon that your using under custom.
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "You have brains in your head. You have feet in your shoes. You can steer yourself in any direction you choose. You're on your own, and you know what you know. And you are the guy who'll decide where to go." Dr. Seuss
Dragonskunk
Dragonskunk
Posted 11 Years Ago
Visits: 1.4K
Mouse visibility isn't showing but you can see the gimbal snaps whenever the arm is moved. Joint rotation glitch:
Dragonskunk
Dragonskunk
Posted 11 Years Ago
Visits: 1.4K
The Look at Camera constraint doesn't seem to be working properly. What I know is not working properly: The character forgets to look at the camera or the character looks at the camera when it is in Set Free mode, the character needs a reminder every 3 seconds then you have to toggle to Set Free then toggle again to Look at Camera again just to keep the character looking at the camera. Same for the Set Free mode, when the head suddenly snaps to the camera then you have to toggle Look at Camera then Set Free just to keep it Set Free. What I'm not sure but doesn't seem to make sense so I'll mention it: When you have a camera but viewing in preview mode when you toggle in the timeline to Look at Camera the character looks at the preview camera instead of the camera.
Dragonskunk
Dragonskunk
Posted 11 Years Ago
Visits: 1.4K
Still getting joint rotation glitch with the shoulders and elbows, thigh and knee, when you rotate. As soon as it moves it snaps to another angle until you mouse up after a rotation. Only the gimbal snap rotates but not the bone. G5 = operates properly G6 = glitch Non standard = glitch
thebiz.movies
thebiz.movies
Posted 11 Years Ago
Posts: 2.1K,
Visits: 42.3K
I have updated to 6.11. The iCone icon in my start menu says I'm still at version 6.02.
Alien Maniac
Alien Maniac
Posted 11 Years Ago
Visits: 2.1K
RLD Missing in Win 10 after reinstall of IC 6
Anyone? I can not download any files with "only the RLD option" now using Win 10...???? ALSO When I installed IC6 again it did not use the path for the templates as I chose....all were in normal dir.
After my Win 10 upgrade.... I installed a new Samsung 840 EVO SSD 500gb and cloned my 750GB (2nd drive now) and then added my new 32GB Ram and then re-installed IC6 WOW...what speed in IC6 now!!!! Still checking for any problems and re-downloading my Speedtree files.
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
Cricky
Cricky
Posted 11 Years Ago
Posts: 2.8K,
Visits: 13.8K
https://www.youtube.com/watch?v=2U_0r1o7S1Q&feature=youtu.beThis is a definite error. It appears using the Camera Switch and a Preview Camera at the same time causes a recording of KEY Frames for the Preview Camera; This should not be happening.
F.Y.I. Still running Win7 Ultimate as before. Reported to Support also.
SKYPE ID: rc.650
johnmuscutt
johnmuscutt
Posted 11 Years Ago
Visits: 99
I need help! I cannot get a satisfactory answer to a question I asked support over a week ago. I am working on a follow up to a video I did a few weeks ago. It is fairly busy with about 60 avatars dancing but my computer has coped well without slowing down too much. After about a weeks work, saving to new files every hour or so, I shut down my computer and went out. When I came back the last three files refused to load. The problem has persisted and I have been unable to load anything I have done since! I have upgraded to a decent nvida card and 16 Gb of RAM. I got rid of anything I didn't need like 'realtime smooth' trees and grass but it hasn't helped. Is there a 'bug'? Am I the only one? I wouldn't mind if the program crashed WHILST I was working on it to warn me I was trying to do too much but losing work has demoralised me to the point of wanting to give up!
Posted 11 Years Ago
Posts: 8.2K,
Visits: 62.6K
There does seem to be some issues with Speedtree with the Windows 10 upgrade which brings DirectX 12.
Another user is getting an error message saying the Speedtrees need DirectX 11, while they do load for me, but have no wind effects.
Let there be stillness! Ommmmmmmmm..........
Posted 11 Years Ago
Last Active: 3 Weeks Ago
Visits: 31.4K
Dragonskunk (7/25/2015)
animagic (7/25/2015) There actually is a particle bounding box, that works for fog as well. To bring it up select the Show/hide icon in the Scene Manager.
I mean the fog in the Visual section. OK, I see. It would indeed be useful to have an indication.
