Digital Soul 100+ for iClone 8 & CC4 - Now Available
Posted By Peter (RL) 4 Years Ago
Rated 5 stars based on 3 votes.
Smit_R
Smit_R
Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)
Posts: 83, Visits: 5.5K
roger4038_039037 (5/27/2022)
Yesterday I purchased Digital Soul 100+ and I have tested it by dragging a "soul animation" called "Look front.iTalk" from Content to a character in iClone 8. The animation is short but works. How do I turn it into a loop? Or how do I add several "soul animations" after one another? I can't find the "soul animation" on the Timeline in iClone 8. Where exactly is it?
You have to check 'Expression' in the dropdown arrow next to your character in the timeline.
The expression timeline is now added so you can add/mix/loop extra expression animations.
roger4038_039037
roger4038_039037
Junior Member (175 reputation)Junior Member (175 reputation)Junior Member (175 reputation)Junior Member (175 reputation)Junior Member (175 reputation)Junior Member (175 reputation)Junior Member (175 reputation)Junior Member (175 reputation)Junior Member (175 reputation)
Posts: 19, Visits: 218
Thank you. Now I can find the character's soul  ;-)
Rocketlazor
Rocketlazor
Junior Member (143 reputation)Junior Member (143 reputation)Junior Member (143 reputation)Junior Member (143 reputation)Junior Member (143 reputation)Junior Member (143 reputation)Junior Member (143 reputation)Junior Member (143 reputation)Junior Member (143 reputation)
Last Active: 5 Months Ago
Posts: 10, Visits: 543
Do these expressions work with imported characters? Like a Genesis 8 character for example? So any rig that has the "Traditional" face profile? Or do they only work with CC characters?
Posts: 9.2K, Visits: 22.1K
If you bring the character in via Transformer it becomes a CC character.  If you bring it in as a non-standard human you will need to "hook up" all the various facial animation parts (blinks, eyebrow raise, etc) to the morphs you have imported and once you do that then facial animations like these should work on it.
Mike "ex-genius" Kelley
dazvfx
dazvfx
New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)
Posts: 1, Visits: 81
Hi.. does this pack works with CC3 stylize cartoony model bought from marketplace?
dazvfx (6/4/2023)
I'm not sure which cartoony character you mean, but providing you are using CC4 then you can use the Digital Soul pack with any Standard CC3+ Characters. However, due to the fact that stylized characters have exaggerated facial features you may need to tweak some expressions a little to get perfect results.
halfdorkstudios
halfdorkstudios
New Member (41 reputation)New Member (41 reputation)New Member (41 reputation)New Member (41 reputation)New Member (41 reputation)New Member (41 reputation)New Member (41 reputation)New Member (41 reputation)New Member (41 reputation)
Posts: 1, Visits: 216
hey all, first post in the forums.
I've been experimenting with different Export settings trying to get the bulk of the 100+ Digital Soul facial expressions into Unity 3D.
Through my couple hours of testing I found that only when using the "Current Animation" selection of the Export FBX settings was I able to import the facial expressions in their full glory.
Using the "Custom" export of bulk .italk animations (at the time of this writing) does not export the facial expressions properly.
Just wanted to report my findings if anyone else was trying to do the same.
To recreate this bug;
Export multiple .italk animations using the "Custom" selection of Export FBX.
Current fix;
Export facial .italk animations one at a time through the Export FBX using "Current Animation."
halfdorkstudios (7/8/2023)
Current fix;
Hi...
If you think you have found a bug, please can you report it in the Feedback Tracker. The tracker is monitored directly by the dev teams who will investigate the issue and give you a status update there. The tracker is the best way to get issues looked into and fixed.
To use the Feedback Tracker, please click the link below.
Thanks.
dan.goyette
dan.goyette
Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)
Posts: 83, Visits: 379
The Reallusion Content Store doesn't appear to allow users to leave reviews for products for some reason, so I'll leave my feedback here. This is both to give other users some additional information on this package, and also to possibly affect future updates to this package that might improve what I considered to be the weaker elements.
First, I should explain the way I'm using this package, since I expect it will have a big impact on my impressions of it. I'm using iClone to create lip-sync animations by combining AccuLips Visemes with Expression to add emotion to the performance. I then export these into Unity. Importantly, within Unity, I'm manually controlling Head rotation, Eye look direction, and Eye blink on the characters. (That's important here because the Digital Soul animations also control those elements.) So what I was mainly looking for was to add just facial expressions (not Head/Eye rotations) to my Lip Sync clips. In short, I was hoping for an upgraded version of the Expression_Loop clips included with CC4/iClone.
My overall evaluation of this package is that while it does have a fair number of purely facial expressions, most of the animations achieve most of their expressiveness through head and eye rotations, as opposed to purely facial animations. This means that if you're only interested in expressions that can be applied with blend shapes (instead of bone rotations), the expressiveness is fairly limited.
In order to use these in my project, it was necessary for me to remove the Head and Eye animations. Otherwise, there were many artifacts that led to strange-looking expressions. For example, if the animation itself has the character look down, that has a strong impact on the characters eyelids. If I override the look direction in my game, the eyelid movement would still be applied, which looks very strange. By disabling Head and Eye animation on these clips, it removes those artifacts. Unfortunately, for the majority of the animations in this package, removing the Head and Eye rotations pretty much left a character with a fairly blank look on their face. Again, for most clips, the expressiveness was mostly driven by the head and eye rotations, not the facial expressions.
I made a short reference video for myself to show what these expressions look like on the default male CC4 character. These clips were created by Sampling the digital soul clips, and deleting all key frames for Head and Eye, leaving only Muscle and Eye Blink. These were also using the CC4 Standard 60+ facial profile.
Overall, I was a bit disappointed here to see just how much of the performance in these clips came down to head movement mocap, rather than facial mocap. On the plus side, the mocap itself is very high quality (very cleaned-up), without any problems or noise in the animations themselves.
Here are some suggestions for similar future packages:
 - Provide stronger mocap performances for facial muscles, rather than head/eye rotations. Having most of the expressiveness coming from head rotations is really disappointing when I'm controlling head animation with other tools.
 - Ideally provide versions of the clips that don't have Head and Eye movement included. Just the character looking forward, with a variety of facial expressions. It took me a long time to manually go through, sampling all clips, removing Head and Eye, and saving a custom version of all the clips.
 - And please don't include random eye blinking in these animations. Eye blinking is something that is generally added/controlled in various ways, and having it baked into these clips is extremely awkward.
dan.goyette (4/11/2024)
Hi Dan,
Thank you for taking the time to share your feedback.
Please remember that you can make suggestions for improvements and make requests for new packs in the Feedback Tracker. The tracker is monitored directly by the relevant product teams. In addition, it allows other users to support your request with the most requested suggestions normally getting higher priority.
Thanks.
