revenger681
revenger681
Visits: 36
amckenzie (6/19/2023) I just patched the update and did a quick test - Genesis 9 now comes through Transformer. Exciting.Awesome! Can't wait to try it out!
Leodegrance
Leodegrance
Visits: 3.7K
Yeah, did a quick test of importing a Genesis 9 character. It came through the transformer without any issues and applying test animations and expressions worked really well. I was able to replace the teeth with CC4 base character teeth (looks like the Daz version still comes through really white like previous Genesis models) However, when trying to change the eyes to CC4 eyes, this happened
Leodegrance (6/19/2023)
Yeah, did a quick test of importing a Genesis 9 character. It came through the transformer without any issues and applying test animations and expressions worked really well. I was able to replace the teeth with CC4 base character teeth (looks like the Daz version still comes through really white like previous Genesis models) However, when trying to change the eyes to CC4 eyes, this happened  Under the Modify Panel > Morphs tab > Head > Eye just use the Eyeball Scale and Eyeball Depth sliders to correct the size problem.
edmark
edmark
Visits: 2.9K
when will the uv transfer tools/files for genesis 9 be available?
edmark (6/23/2023) when will the uv transfer tools/files for genesis 9 be available?Which transfer tools do you mean? Support for Genesis 9 is already available in CC 4.3 using Transformer. You don't need any other tools.
edmark
edmark
Visits: 2.9K
These files sir.. we need the daz genesis 9 version of these
animatedbeing
animatedbeing
Visits: 1.8K
I found the DAZ resource folder in C:\Program Files\Reallusion\Character Creator 4\Program\Assets\ExternalFiles\DazResource Not in C:\Users\Public\Documents\Reallusion\Template\Character Creator 3 Template\DazResource\T_Pose I did not find any A-pose or T-pose files for Genesis 9. Should we use the default pose?
edmark (6/23/2023)
These files sir.. we need the daz genesis 9 version of these  Thanks for clarifying. I will check the situation regarding the SkinGen Daz Tools and update again when I know more.
animatedbeing (6/24/2023)
I found the DAZ resource folder in C:\Program Files\Reallusion\Character Creator 4\Program\Assets\ExternalFiles\DazResource Not in C:\Users\Public\Documents\Reallusion\Template\Character Creator 3 Template\DazResource\T_Pose I did not find any A-pose or T-pose files for Genesis 9. Should we use the default pose? Thanks for pointing out the outdated information in the online manual. We will try to get this corrected as soon as possible. With regards to the Genesis 9 A-Pose, for now you can use the default pose which should work fine. If a dedicated A-Pose is found to be required for Transformer then we add them in a future update.
hoodtronik
hoodtronik
Visits: 299
Has there been a facial profile for Genesis 9 made for the Daz Resource? If so, where can I find the updated folder?
