Character Creator 4.0 Official Issues Thread
Posted By Peter (RL) 3 Years Ago
Rated 3.7 stars based on 3 votes.
MBusch
MBusch
Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)
Posts: 7, Visits: 926
Using Transformer in Advanced mode in CC4 to bake textures gives a weird result. I tried a couple of times with different DAZ characters always with bad results.
93% of original size (was 538x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/df65a9f8-3fd1-47d6-8060-d2da.jpg
The same FBX file with the same Texture INI profile in CC3 gives the correct result
93% of original size (was 538x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/1d639a32-052e-4236-8467-4117.jpg
I hope this can be fixed soon.
Feedback Tracker issue 8508
mcmikexx
mcmikexx
Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)
Posts: 24, Visits: 349
Not sure if this is a bug or not. When I use some sliders for eyes or mouth, the character jumps up a little. I have only noticed the behavior in those two areas, there may be others.
If the Headshot face matching tool is open, the image and the character become misaligned. My workaround is to open an editing session by making a tiny adjustment on one of the affected sliders and immediately hitting the Bake button and then open the matching tool. That seems to lock the character for the rest of the edit session.
paro_3453
paro_3453
New Member (64 reputation)New Member (64 reputation)New Member (64 reputation)New Member (64 reputation)New Member (64 reputation)New Member (64 reputation)New Member (64 reputation)New Member (64 reputation)New Member (64 reputation)
Posts: 10, Visits: 94
Veteran Member (944 reputation)Veteran Member (944 reputation)Veteran Member (944 reputation)Veteran Member (944 reputation)Veteran Member (944 reputation)Veteran Member (944 reputation)Veteran Member (944 reputation)Veteran Member (944 reputation)Veteran Member (944 reputation)
Last Active: 4 hours ago
Posts: 116, Visits: 499
Hi Everyone
I installed CC4and none of the content template files loaded during the installation. I get the 'Not found any content in "Update" filter' message when I click on any of the items in the template list.
Please Advice.
Thank you
See attached
25% of original size (was 2000x1088) - Click to enlargehttps://forum.reallusion.com/uploads/images/ab65a40d-986f-4bc6-9771-5ee0.png
Hi wssessoms,
Try selecting the button (yellow arrow), then select All  (red arrow). I suspect you may have Update selected rather than All.
Make sure to refresh Content Manager after doing this by preesing the button to the left of the yellow arrow. Hope thsi helps.93% of original size (was 538x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/a544f542-4e80-45b8-9781-6fa7.png
OB1Flow
OB1Flow
Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)
Posts: 44, Visits: 222
MBusch (5/20/2022)
I have seen this too.  Primarily torso texture or face.  I've also imported as non-standard and only some of the textures come in.  Non-standard the eyes do not come at all, they are white.
wsessoms
wsessoms
Posts: 117, Visits: 508
paro_3453 (5/20/2022)
Hi Everyone
Please Advice.
Thank you
See attached
Hi wssessoms,
Thanks Paro,
I figured it out. I had moved the content from the c drive to my e drive to gain more space on my c drive with CC3. So I had to move the files from the e drive to the c drive so the CC4 could find it and change the path in setup to the c drive. Now everything is showing up as it should. May want to move files back to my e drive for space issue later but for now it's time to play with the new software. So impressed with Reallusion''s software!
Dell Precision T5500; Windows 10 Pro; Dual Xeon 5687 3.60GHz Processors; 72GB Ram; NVIDIA GeForce RTX 3080; Samsung 1TB SSD; Seagate 2TB 7200RPM HDD; Wacom Intuos Tablet; ASUS Dual Monitors
SyrDoN
SyrDoN
New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)
Posts: 6, Visits: 29
I have surprisingly few issues with the new versions.   I have come across a problem though that repeats every time.
I searched the forums but couldn't find anything related to this.   My apologies if there is a reply already.
I am using Camilla Character.   Using curly_fringe hair.   I have physx on for the hair.   If I render out images, no problem.   If I render out as a video, it will do the entire render.   At the very end of the render I get an error dialog that states an instruction referenced meory that could not be read.    The only thing that I have done different is add a custom decal on the face.   Actually 2 decals (both are the same - one is smaller than the other).
SyrDoN
SyrDoN
I get this error also.    But, I only get this problem with one scene so far.   The rest are all fine.
Last Active: 9 days ago
Posts: 5.3K, Visits: 16.7K
Every time you try to open CC1 base characters in newly started CC4, it takes nearly 3 min to open.
It's getting stuck on "Update Morph Data" event.
93% of original size (was 538x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/0a194498-629a-430b-b4dd-b483.jpg
Each consecutive attempt however only takes 10-15 seconds.
There was no such a problem in CC3.
FT: https://www.reallusion.com/FeedBackTracker/Issue/It-takes-nearly-3-min-to-load-CC1-base-characters-in-newly-opened-CC4
And then this:
93% of original size (was 538x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/3e159762-b7b3-4655-b974-56f4.jpg
I am not sure what to make of it. Is this "one time" operation should run every time CC4 starts?
Edward (RL)
Edward (RL)
Posts: 301, Visits: 4.9K
Thanks Paro,I figured it out. I had moved the content from the c drive to my e drive to gain more space on my c drive with CC3. So I had to move the files from the e drive to the c drive so the CC4 could find it and change the path in setup to the c drive. Now everything is showing up as it should. May want to move files back to my e drive for space issue later but for now it's time to play with the new software. So impressed with Reallusion''s software!
Hello,
You may try to right-click the pack you want to move and then choose "Move Location" in the menu
lau.ho.tin
lau.ho.tin
New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)
Posts: 1, Visits: 128
Issue 8527
Cannot apply check pose after drag the pose to character
Steps:
1. Import new clothes and apply skin weight
2. Select the check pose and drag to the character
Actual Result:
Character pose did not change to the selected check pose
Expected Result:
Character should changed to the selected pose for skin weight checking
