xmonster0
xmonster0
Visits: 26
when will this be compatible with 2021 unity? or will this remain a stone age tool?
Sekker2k4
Sekker2k4
Visits: 26
jerome.dipietro (4/9/2021)
I tried it on a couple of characters (one with the new beard content). Going into Unity 2018.4.20 using AutoSetup 1.01 (as it's the last version to support 2018) and it worked surprisingly well. Beard transparency is particularly impressive (what a relief!) There was an error/warning message mentioning that I wasn't using the correct version of AutoSetup for the Character Creator mesh, but I didn't notice any major problems. On one character the Body_Head metallic map wasn't generated but I usually have to do a few workarounds with materials any way.  Hi! Do you mean cc3.4 works in unity 2018? i won´t use that old version because i want to focus on HDRP. and it have lower version. Will be awesome atleast if RL make a proper Bridge for exporting into unity. thank you for sharing your pictures
jerome.dipietro
jerome.dipietro
Visits: 1.1K
Hi @Sekker2k4 yes, I was just answering @dassoubarna's question about importing CC3.4 using AutoSetup. At the time I'd only tried into 2018, but I've since been working on a 2019 project and that's ok too. I'm guessing you're on 2020 for HDRP? Any problems there? I totally agree... we really need a proper 'bridge' into Unity, I just hope it's not crazy expensive like Unreal Live Link :ermm:
274421595
274421595
Visits: 9
Hello, can you support Unity2020.3 HDRP?
romeo.rivoire
romeo.rivoire
Visits: 78
There is even the Unity 2021.1 now... An update to the auto setup would be greatly appreciated.
Rowlan09
Rowlan09
Visits: 84
Obviously Reallusion doesn't fix the Unity importer, it's been broken for months now. Could you please provide the source instead of a dll, so that we can at least fix it ourselves? Thank you!
Rowlan09
Rowlan09
Visits: 84
Bladepup (2/20/2021) Honestly it's worth it, yes it's annoying the tool isn't updated but you can manual do it all yourself, they even have the steps for what the auto plugin will do, Overall CC3 is awesome, it's more just annoying we don't get the update, and honestly if you going for quality you most likely gonna be using custom shaders so gonna have to plugin things yourself anyhow, really for 2020.2.5 using HDRP 10, I just import into a 2019.4 unity, get all the right values and settings, then export that as package and take that into my HDRP 10 project, then you just have to add the diffusion profile for the skin otherwise it'll be green, otherwise it's almost all setup for ya.
so yah overall I would say CC is still worth using even with this issue.
Edit, tried to reply to your message about unity and this, but apparently i'm a noob with the forums :D
You are defending something that's clearly not working and unsupported. Why should every single one of us waste their time to manually fix issues that should be automated? I can't recommend CC3 at all for Unity: https://forum.unity.com/threads/character-creator-3-tutorial-part-1-exporting-a-cc3-character-base-to-unity.599911/#post-7122614
We have now made an announcement on the plans for Unity Auto Setup. Please click the link below to view it.
ty.xanders
ty.xanders
Visits: 114
Peter (RL) (5/13/2021)
Peter is there a way to set up some direct communication with you/the tech team on this? As my team and I believe we may have solved the auto set-up situation everyone's been having. We've had great success for us using HDRP and 2020.3 of late and I personally don't think you guys have as big an issue as you may fear. I didn't want to post the information publicly on this yet because I wanted to run it through you all first to ensure this is certainly the case. looking forward to hearing back All the best
Hi Ty Please feel free to send me a private message about this and I can relay the information to the Character Creator team. :)
