Eric C (RL)
Eric C (RL)
Visits: 6.0K
kungphu (3/24/2021) Wow! The timing of this is incredible. I was just trying to get a pipeline for expanding the expressions and getting breed lip sync. Was going to go with a brute force papagayo route. No need now! Thanks RL, this is amazing.Yes come stick to the AccuLips!! Just a teaser that we will have a fun campaign coming soon. Stay tuned!
Eric C (RL)
Eric C (RL)
Visits: 6.0K
joel.lovell (3/25/2021) The tokomotiondemo is not loading, it moves you to smart gallery and doesnt load.Hi Joel,
You can submit your question here and please try to be as precise as possible. Would also appreciate if you send us a screen recording to help us better identify the issue, thanks! https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
Eric C (RL)
Eric C (RL)
Visits: 6.0K
cvnicoell (3/25/2021) Will there be an update to the Python API to automate the new options of AccuLips like it is possible with the current LipSync of VisemeComponents? The current AccuLips can handle many tasks to speed up the process of auto lip sync animation. It is dictionary-based and we suggest you can go over all four tutorials and webpage first to see if we can fulfill your request
If the above resources does not work and you would still need more Python API to work, you can submit an iClone 7.9 feedback tracker and we will take a look. You can also send me a private message, too. Thanks!
Eric C (RL)
Eric C (RL)
Visits: 6.0K
Hi everyone,
Sharing this post of Hotfix for those who have new hair install issue.
Please read the "HowTo.txt" in the .zip before updating. And if you keep the Smart Gallery in Offline mode when updating to CC3.4/IC7.9. The hotfix install flow should be: 1. Switch the Smart Gallery to Online mode. 2. Close program 3. Run the Hotfix .bat 4. Open the program and click Refresh manually.
cvnicoell
cvnicoell
Visits: 42
Thank you very much for the answer. Unfortunately we are working with a much higher amount of lines that we need to lip-sync. I'll reach out to you in a PM.
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Hi everyone, iClone has been updated to version 7.91 to be compatible with Smart Gallery 1.2. Please check your Reallusion Hub and install the new version. Thanks! Reallusion Team
bexley
bexley
Visits: 375
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Hi bexley, sorry that I didn't see your comment. I don't think this issue was fixed, but I've highlighted it to Dev Team.
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Hi everyone, iClone version 7.91 was repacked today to fix the Morph Creator malfunction issue. Please check your Hub to update to the latest version. Fixed: Morph Creator not launching when a prop is selected and Modify > Animation > Morph Creator button is pressed. (FT #7808, #7812, #7836)Build number for two versions: - April 12th: v7.91 (7.91.5208.1)
- May 3rd: v7.91 (7.91.5223.1)
Miranda (RL) (4/12/2021)
