vidi
Posts: 10.8K,
Visits: 40.2K
Looks like the OBJ. have not properly UV maps
Lord Ashes
Lord Ashes
Last Active: 7 Months Ago
Posts: 1.3K,
Visits: 1.6K
vidi (2/2/2021) Looks like the OBJ. have not properly UV maps As you can see in the videos, the content does have correctly set UVs because the material/texture is correct when the content is pushed to 3DXChange from iClone which is what can be seen at the beginning of the video. However, as you indicated, when the content is exported then it looks like it is mixing up the material and/or UVs (Video #2) as well as sometimes dropping parts of the mesh itself (Video #1 but also seen a bit in Video #2).
"We often compare ourselves to the U.S. and often they come out the best, but they only have the right to bear arms while we have the right to bare breasts" Bowser and Blue, Busting The Breast
vidi
Posts: 10.8K,
Visits: 40.2K
As you can see in the videos, the content does have correctly set UVs For that I need to see the UV maps. General, Only properly created UV maps are without trouble if you want share Objects The most sketchup models are troublemaker, because only Material IDs with assign Texture but not right UV mapped Maybe you can upload your file for analyzed ?
vidi
Posts: 10.8K,
Visits: 40.2K
Have you interested in an analysis? If not why ?
tvwk2013
tvwk2013
Visits: 139
I have an issue with targeting the bones for the Non Standard character in 3DEchange, the window is hiding the part of the left hand and I am not able to move it or resize the screen, may be somebody can help
Last Active: 11 days ago
Posts: 5.7K,
You appear to be using an unusual screen resolution and that may be causing the sizing problem. Have you tried clicking the "Restore Down" icon and then adjusting the size by dragging the outer window edges to increase the size?
tvwk2013
tvwk2013
Visits: 139
I was trying to do it, but it didn't helped ( the size of this small window is not changing (
tvwk2013
tvwk2013
Visits: 139
