richard666
richard666
Visits: 425
Peter, please please can you push up the line the growing frustration that we all have with C.C 3. Yes it is potentially a great product but as people who i recommended to point out without the ability to use the Appearance Editor for CC3 avatars or the ability to use the CT8 photo to 3D character facility direct to CC3 what use is it to a great many people. Peter i have been very loyal in my continued use of the reallusion products but even i am now looking to try other products. I note your request to use the technical issues submission route which i also will do. regards richard
richard666 (1/29/2019) Peter, please please can you push up the line the growing frustration that we all have with C.C 3. Yes it is potentially a great product but as people who i recommended to point out without the ability to use the Appearance Editor for CC3 avatars or the ability to use the CT8 photo to 3D character facility direct to CC3 what use is it to a great many people.
regards richard
Hi Richard Unfortunately, Appearance Editor support for CC3 Base Characters is still some way off but it is coming in the 3.1 update later in the year. However, you can already use CrazyTalk 8 Pipeline to send 3D heads to Character Creator 3. Just export as an RLHead from CT8 and then apply that head to a CC1 Base Character in CC3. Then optionally you can convert the CC1 character to a CC3 character from the Modify Panel in CC3.
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Unfortunately, Appearance Editor support for CC3 Base Characters is still some way off but it is coming in the 3.1 update later in the year. Hello Peter, that should not be a complaint but What does CC 3.1 appear later in 2019? The update was released in November / December 2018 CC 3.1 will be released in the first quarter of 2019 (at the end of March 2019 at the latest) OK, that was a long but manageable time since the release of CC 3 and also visible to the customers. Now it's suddenly called "later in 2019". this can also mean that the update CC 3.1 also appears first in the 2nd or 3rd quarter of 2019. Maybe also only at the end of the year 2019. What should be set up (can you)? I'm also synonymous to the possibility of exporting the LOD avatars as iAvatere to IClone 7th (is not possible now because you need the export license for RL clothing if you want to export it as fbx) Clarification Seitesn RL would be glauzbe I in the sense of RL customers. Greetings from Germany Postfrosch (Werner)
-------------------------------------------------------------- 76% of original size (was 663x19) - Click to enlarge
Postfrosch (1/29/2019)
Hi Postfrosch There are a lot of big changes coming in the 3.1 update but this has unfortunately meant that it will be released later in the year than originally planned. There are smaller updates planned before that, but the next major update will be 3.1. At the present time, I don't have a date for when 3.1 will be ready but we are sadly looking past the original Q1 2019 timeframe.
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Hi Peter thanks for your answer even if I do not like it :unsure::crying::pinch: Greets from Germany Postfrosch
TopOneTone
TopOneTone
Visits: 3.2K
Can someone please clarify this for me. Based on the comments here, it appears that the Appearance Editor does not work with the CC3 characters, but does work with CC1 characters. I have opened each of the 3 versions of CC and found that using the default character in each only CC1 gives access to the Activate Appearance Editor. So am I right in thinking this issue was also present in CC2, which I thought used different character model from CC3? Thanks, Tony
TopOneTone
TopOneTone
Visits: 3.2K
I had the same problem and eventually I think I managed to download it manually. However, I don't really know what these resources are that it was adding, to be able to check it worked. Can someone confirm? I can see that there are some basic items of clothing etc, but all the previous items I had have gone. Do I need to download them again separately? I'm sure I'm missing stuff that was in the original CC3 release. I'm so confused with the multiple versions and updates, that I now end up importing each resource separately as I need it from the previous versions. Wish it was more like DAZ and automatically retained all your assets in your library.
Any advice?
Tony
TopOneTone (2/23/2019) Can someone please clarify this for me. Based on the comments here, it appears that the Appearance Editor does not work with the CC3 characters, but does work with CC1 characters. I have opened each of the 3 versions of CC and found that using the default character in each only CC1 gives access to the Activate Appearance Editor. So am I right in thinking this issue was also present in CC2, which I thought used different character model from CC3? Thanks, Tony Hi Tony Character Creator 2 still used CC1 characters (actually designated as 1.5). There were no CC2 characters as such. In Character Creator 3 we have a new and improved character model which we refer to as CC3. So basically you only have CC1 and CC3 type characters available.
TopOneTone (2/23/2019) I had the same problem and eventually I think I managed to download it manually. However, I don't really know what these resources are that it was adding, to be able to check it worked. Can someone confirm? I can see that there are some basic items of clothing etc, but all the previous items I had have gone. Do I need to download them again separately? I'm sure I'm missing stuff that was in the original CC3 release. I'm so confused with the multiple versions and updates, that I now end up importing each resource separately as I need it from the previous versions. Wish it was more like DAZ and automatically retained all your assets in your library.
Any advice?
Tony
If you think you have some default content missing, try downloading the Resource Pack again and install that. You can download it from your Member Account > Registration page. Just click the Download link for CC3 to find it. For Content Packs, you can install them again and they will go into CC3 by default. All Content Store purchases can be found on your account Order History page and Marketplace purchases from your Marketplace Inventory page.
Dear Character Creator Users, We have now released the 3.04 update for Character Creator 3. Please continue to post any bugs or issues you find in the Feedback Tracker and then feel free to discuss here. Thank you.
